My high school TJ build - Page 4 - JeepForum.com
post #46 of 244 Old 01-02-2012, 09:28 PM Thread Starter
Mikez
Originally Posted by ctorres018
Haha oh, I wanna do something with my interior cuz I have a ripped drivers seat, no stereo, it didn't even have carpet. And since my tj didn't come with doors either I bought them after and the door panels don't match the dash lol
Looks like you need seat covers and a lot of time and spray paint!!
Mikez is offline
post #47 of 244 Old 01-02-2012, 09:29 PM Thread Starter
Mikez
I'm running 32's and a front locke my 35has a open diff
Mikez is offline
post #48 of 244 Old 01-02-2012, 09:39 PM
Irongrave
not a bad rig but whats up with the spacers for 32 11.5s?
Current
2002 WJ 2wd DD
Irongrave is offline
post #49 of 244 Old 01-02-2012, 10:21 PM Thread Starter
Mikez
I'm not sure why there's spacers but it's a really stable jeep with them. And it does not even have a front sway bar.
I was told the spacers shouldn't hurt anything, was this wrong? I know there talk about poorly
Mikez is offline
post #50 of 244 Old 01-03-2012, 02:04 PM Thread Starter
Mikez
finally got my christmas gifts from my girlfriend on! Its the funniest sticker ive seen yet!
Mikez is offline
post #51 of 244 Old 01-04-2012, 03:36 AM
rozco
Nooooo I wanted that no problem one. Now I can't get it lol. I'll have to find something similiar
93' ZJ - 5.2L. 4.5" IRO lift. front long arms rear short adjustables. bilsteins. daystar bumps. 33" KM2's. rancho ss. rc quick discos. flowmaster 10 series.
rozco is offline
post #52 of 244 Old 01-04-2012, 03:41 AM
rozco
The spacers are probably there so your tires don't rub the control arms or any other components when turned and compressed. They look fine to me. I'm runnin spacers too on 33x10.5
rozco is offline
post #53 of 244 Old 01-04-2012, 12:01 PM Thread Starter
Mikez
Hahaha you can still get it no worries rozco
Mikez is offline
post #54 of 244 Old 01-05-2012, 03:10 PM Thread Starter
Mikez
I got my trans. cooler on yesterday!
I also am installing a temp. gauge
So I had someone weld in a bung then I started the install on that replacing my trans filter and gasket on the way
Mikez is offline
post #55 of 244 Old 01-05-2012, 03:16 PM Thread Starter
Mikez
i also found about a mm of silty metetal coating my magnet in my oil pan. Is that a bad sign? Also i found a few metal chunks at the bottom of the pan none of them were bigger than the tip of a needle though.
Mikez is offline
post #56 of 244 Old 01-08-2012, 09:49 PM Thread Starter
Mikez
I put on a new ss today as well as finishing my trans. tem. gauge!
Mikez is offline
post #57 of 244 Old 01-09-2012, 12:40 AM
rozco
That's sick. How hard was it to put the trans temp gauge in? I would love to get one too
rozco is offline
post #58 of 244 Old 01-09-2012, 08:37 AM Thread Starter
Mikez
The gauge itself wasn't too bad but getting off the oil pan and and getting the bung welded in and putting it back together with a new seal was a messy possess.
I would give it like 2 stars for difficulty and 4 for messiness
Mikez is offline
post #59 of 244 Old 01-09-2012, 10:44 PM Thread Starter
Mikez
My shop who I had give my car a onece over a while back said I have a bad front driver wheel bearing. So I took it out and its not horribly loose but the bearing itself has one to two mm of movement. Does this mean time to replace?
The reason I'm even bothering with this is because when I am at highway speed and I let off the gas my front end wanders side to side.
Things I've tried...
Tightened up all the front end
Alignment
Checked bushings
I would appreciate anyones help
I've been reading old forums to find things to help but just thought there's somthing I'm missing
I am not running a front sway bar either but this is a recent problem and I have never had a front sway bar
My only out of speck alignment is 6.0 caster
Mikez is offline
post #60 of 244 Old 01-10-2012, 11:14 AM
mcannon111
YES if it moves at all it needs replacing. just go to autozone and get a new one they are really easy to fix. if you dont fix it the tire can fall off while your driving! haha and then someone can sue you cause your 33 inch tire went through there car and hurt them haha.
no doors, no top, no problems
live in sc? join OffroadSC.com
mcannon111 is offline
99 red high school build up jackattack Jeep Builds 40 06-15-2012 03:26 PM
97 tj broke high school build austonreeves Jeep Builds 126 06-05-2012 02:33 AM
High school TJ build amber324 Jeep Builds 7 06-16-2011 10:49 PM
My high school build up Speed911 Jeep Builds 29 08-22-2008 09:20 AM
