My Girl... a Boston Jeep Build - Page 66 - JeepForum.com
post #976 of 1986 Old 02-18-2012, 12:15 PM
Kenbo-Slice
Bend the rod coming off the tubing, or cut it off and re weld a better shaped one on in order to gain the clearance you need.
Jeep build up...ONGOING
Kenbo-Slice is offline
post #977 of 1986 Old 02-18-2012, 12:37 PM
2003X
Looking at your pics and I know my tail pipe has always rubbed against my shock tube. Not sure why its so close to the muffler. I think the L bracket idea may work.
My Build
2003X is offline
post #978 of 1986 Old 02-18-2012, 04:26 PM Thread Starter
djflyy
Okay so I took the grinder to the tail pipe and cut off the old bracket. Then went to Advance Auto and bought a multi-hole exhaust hanger that would allow me to adjust the length of the front hanger. Once I had it at about the right height to line up with the muffler/cat output, I marked where the J hanger would go on the back. Quick welds on both sides of the hanger and it was fine.
All that remains is affixing the muffler to the fail pipe, and pressing the gusset between the cat and the muffler.
Thanks to Geoff for swinging by.
djflyy is offline
post #979 of 1986 Old 02-18-2012, 04:42 PM
Cowboyup94
Let's see the clearance now.
Cowboyup94 is offline
post #980 of 1986 Old 02-19-2012, 03:25 AM
CrawlingForward
What are the various sizes that need to be mated again?
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #981 of 1986 Old 02-19-2012, 06:52 AM Thread Starter
djflyy
The OD of the muffler is 2.75 inches, the ID of the catalytic is 2.25 inches. I do believe I found the solution last night though, in the box that the cat came with. It included a rubber-like material "doughnut" that fits around the cat, and that is tight, but most likely possible to fit inside the Banks muffler. This would seal that off (pending an exhaust clamp over it). Meaning all that's left is fitting the tail pipe back into the muffler.
djflyy is offline
post #982 of 1986 Old 02-19-2012, 09:22 AM
Amills
I hope you got it figured out! I hope those pics i sent helped a little haha. When i did mine, i had to buy new exhaust hangers to tighten it up because it hit my trailer hitch every two seconds, not it only occasionally hits when im in first gear and make a sharp turn and my RPM's get kinda low. I think i might take the tip off and see how it is.
Amills is offline
post #983 of 1986 Old 02-20-2012, 06:38 PM Thread Starter
djflyy
Work continued yesterday on the single most annoying project I've ever done. I HATE EXHAUSTS.
I rented the "exhaust flanger" from AutoZone for freeeeee which spread the muffler output open far enough for me to get it back onto the tail pipe smoothly. Well worth the time to do it, and a VERY cool tool. Then, since there were no adaptors to get from the muffler to the cat at Advance or Auto Zone, I made one. Bought 2 different ones that fit each part respectively, cut them and re-welded them together. I was then finally able to get the two to bolt up, and am now only waiting for the O2 sensors.
djflyy is offline
post #984 of 1986 Old 02-20-2012, 06:52 PM
2003X
Sweet
My Build
2003X is offline
post #985 of 1986 Old 02-20-2012, 06:59 PM Thread Starter
djflyy
Originally Posted by 2003X View Post
Sweet
Ain't it?
djflyy is offline
post #986 of 1986 Old 02-21-2012, 06:48 AM
NBFarmboy
Oh c'mon exhaust is fun lol
If hair pulling, swearing about how something is welded wrong by the manufacturer, and generally hating how as soon as its all done its going to get crushed on a rock is fun to you
RAYS 4X4, an Official MCE dealer, Pm me for prices
"Redneck Rooster" 98 TJ with 5.3 Vortec, 4 speed, 37"s
Wifes "Ladybug" 95 YJ 2.5, 3.5" fenders, 33's, 1" body lift, 1" deep skid pan, york OBA 1" shackle lift
"Bullfrog" 88 XJ 4.0, Doorless, 2" lift, 33-10.5 tires, very cut fenders...
NBFarmboy is offline
post #987 of 1986 Old 02-21-2012, 09:57 AM
2003X
Something so simple as "bolt on", turned into a real customized project.
My Build
2003X is offline
post #988 of 1986 Old 02-22-2012, 07:53 PM
2003X
http://www.jeepforum.com/forum/f149/...works-1332688/
In case you want something!
My Build
2003X is offline
post #989 of 1986 Old 02-22-2012, 08:58 PM
CrawlingForward
Originally Posted by emanuelcabre93
Looks good.Love it..
What kind of car is this?
Spam?
post #990 of 1986 Old 02-22-2012, 09:06 PM Thread Starter
djflyy
Spam?
Haha I had the same thought! How's FL?
djflyy is offline
35s , boston , built tj , chili pepper pearl , north shore jeeps
First Jeep Build Bosefus Jeep Builds 4 06-20-2012 09:35 PM
03 TJ - Boston Osmosiz Jeep Builds 174 11-22-2010 10:50 PM
Pics of your girl with or without your jeep. Mitchin Jeep Picture Requests 55 11-22-2009 01:18 AM
My jeep build.... 91jeepkidd Jeep Builds 1 01-26-2009 09:16 PM
my jeep girl climbing toke Jeep Builds 1 11-10-2007 08:16 AM
