My Girl... a Boston Jeep Build - Page 58 - JeepForum.com
post #856 of 1985 Old 01-11-2012, 08:52 AM
CrawlingForward
Awesome! Yup, I'll be there if we're still planning on this weekend.
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #857 of 1985 Old 01-11-2012, 11:02 AM Thread Starter
djflyy
Monday, being the holiday! We can do it here.
djflyy is offline
post #858 of 1985 Old 01-11-2012, 10:02 PM Thread Starter
djflyy
Okay guys so I finally had time to get a quick video of the engine compartment with this problem occurring. Noise is high pitched, and gets louder with accelerations while I'm driving. Guys on the forum that had read my post (pre video) suggested maybe the idler pulley/bearing, which it may be. Just recently started, and is plain old annoying more than anything else.
Sorry it's out of focus, I was shooting with my DSLR and didn't bother to adjust while holding my flashlight with my chin. Noise is occasional while driving, but does get louder than in this video.
Thoughts appreciated from anyone.
djflyy is offline
post #859 of 1985 Old 01-12-2012, 10:01 AM
CrawlingForward
Have you tried shooting lubricant into the various points, one at a time, to see if it affects the noise?
Not as a cure, but if you shoot it into idler bearing and the noise changes, you can confirm it.
If you do it one at a time, you may be able to do a process of elimination.
post #860 of 1985 Old 01-12-2012, 09:41 PM
kvesi122
fan clutch?
kvesi122 is offline
post #861 of 1985 Old 01-13-2012, 01:58 PM Thread Starter
djflyy
Well I put in a new idler pulley (the 3", not the 3.5") from AutoZone for $19. The main noise has gone away as far as I can tell, but there is a noise left that sounds more belt-like. I suppose I'll replace that this weekend, too. Did the swap in the AutoZone parking lot in North Reading since I carry a socket set in the TJ, but the wind nearly blew the hood down on me.
Also met a nice guy with a 2012 JKU Rubicon while under the hood of mine, and told him about NSJ. Said he'd be interested in meeting up with us at some point.
Photos of the old pulley, and new one installed.
Also a photo of the TJ in yesterday's mini snow fall. Best 'snow' picture I've got so far this winter
djflyy is offline
post #862 of 1985 Old 01-15-2012, 10:05 PM Thread Starter
djflyy
SYE install tomorrow! Shout out to my girlfriend's dad for the use of his heated garage. Current outside temp is 5 degrees.
djflyy is offline
post #863 of 1985 Old 01-15-2012, 10:15 PM
2003X
When did you guys get snow? lol
My Build
2003X is offline
post #864 of 1985 Old 01-15-2012, 10:15 PM
2003X
I'd hope he would let you use it.
My Build
2003X is offline
post #865 of 1985 Old 01-16-2012, 07:10 AM Thread Starter
djflyy
Snow was Thursday morning I believe. Crazy that you're 5 miles away and got none.....?
And yes. Very grateful.
djflyy is offline
post #866 of 1985 Old 01-16-2012, 09:04 AM
2003X
Didnt get any snow at all. I wont be able to help with the sye, I got called for OT. Take alot of pics.
My Build
2003X is offline
post #867 of 1985 Old 01-16-2012, 10:00 PM Thread Starter
djflyy
First off, a MASSIVE thanks to Clayton and Geoff for spending their day under my TJ today.
Second off, a MASSIVE thanks to my girlfriend's dad for letting me use his heated (70 degrees!) garage. Worked in jeans and a tee-shirt all day. What an awesome thing, considering the temperatures outside.
We started around 10 and worked until 4:30 (including a 1 hour AutoZone/lunch break) and successfully ripped apart my transfer case and removed the extra long output shaft and Slip Yoke. It's great to finally have completed this mod that I have been avoiding for years.
We started off by debating whether or not to put the TJ on ramps in the rear for working room. Due to my suspension characteristics and tire size, this was unnecessary as we had plenty of room to work under there. Then it was a simple process of jacking the transmission, lowering the skid, draining the transfer case, removing driveshafts, removing the harmonic balancer (rent the freakin' tool from AutoZone. Took care of this in literally 1 minute). Then crack the tail housing off, crack the case in half, remove the splined output shafts from front and back, and swap the shaft!
Re-assembly time was quick, and we spent a while waiting for Clayton's (rightfully) excessive RTV gasket job seal. No leaks to be seen here! Filled 'er up, and she is good to go! The needed tools list write up at 4x4explor was worth it's weight in gold for this project.
All that remains now is for me to remove the welded on TC drop brackets, and fab up some new nuts to mount in the frame so that I can have a flush mounted tc skid! Soon enough I'll be building my own, but that's not happening this week.
P.S. it's snowing! Real, sticky snow. Driveway, streets, houses, lawns, (jeeps), everything's covered!
Pics...
And what needs to be fixed with the TC skid drop... we'll see how far I get tomorrow.
djflyy is offline
post #868 of 1985 Old 01-16-2012, 10:05 PM Thread Starter
djflyy
And just for comparison, the "proper angle" photo from Tom Woods' site, with my current set up. Should be spot on once the TC drop is removed.
djflyy is offline
post #869 of 1985 Old 01-17-2012, 07:53 AM
SaxManClay
That's a beautiful RTV job.
Also, I ate about 3 pounds of pasta when I got home. I told you I was hungry!
My Jeeps name is TUG!
What I'm all about.
SaxManClay is offline
post #870 of 1985 Old 01-17-2012, 07:55 AM
NBFarmboy
Looks like it went very well
Slip yoke eliminators are really a fun job to do
Your going to love your flat skid when you get it
It's like a whole different rig after you do it
RAYS 4X4, an Official MCE dealer, Pm me for prices
"Redneck Rooster" 98 TJ with 5.3 Vortec, 4 speed, 37"s
Wifes "Ladybug" 95 YJ 2.5, 3.5" fenders, 33's, 1" body lift, 1" deep skid pan, york OBA 1" shackle lift
"Bullfrog" 88 XJ 4.0, Doorless, 2" lift, 33-10.5 tires, very cut fenders...
NBFarmboy is offline
35s , boston , built tj , chili pepper pearl , north shore jeeps
First Jeep Build Bosefus Jeep Builds 4 06-20-2012 10:35 PM
03 TJ - Boston Osmosiz Jeep Builds 174 11-22-2010 11:50 PM
Pics of your girl with or without your jeep. Mitchin Jeep Picture Requests 55 11-22-2009 02:18 AM
My jeep build.... 91jeepkidd Jeep Builds 1 01-26-2009 10:16 PM
my jeep girl climbing toke Jeep Builds 1 11-10-2007 09:16 AM
