My Girl... a Boston Jeep Build - Page 23 - JeepForum.com
post #331 of 1986 Old 06-20-2011, 05:41 AM Thread Starter
djflyy
Painted the axles with Chassis Saver yesterday as well as touched up the springs and the bumpers with another layer of it. Then used some aerosol black spray paint over the top just to make it a little less glossy. I also went up to AutoZone and picked up everything I need for the ZJ V8 tie rod, as well as 2 new Duralast U-Joints for the front DS and rear DS. A CV shaft is in the plans, but I figure while I have access I should put in a new U-joint at each axle yoke. Total cost out the door was $101 for all of those parts, with numbers referenced off of Stu's site.
Today, Clay & I will be installing the rear axle. Can't wait! I took a mock up photo the other day of what it "looked" like on 31s and what it will look like on 35s. This thing is bad ***!
Mock Up w/ 31s
Mock Up w/ 35s
djflyy is offline
post #332 of 1986 Old 06-20-2011, 09:14 AM
95riograndeman
2015 JK Wrangler
Lookin good...Can't wait to see them all on there.
2015 Jeep Wrangler Sport
SOLD: 1995 Jeep Wrangler
95riograndeman is offline
post #333 of 1986 Old 06-20-2011, 09:13 PM Thread Starter
djflyy
Spent today with SaxMan installing the 8.8 in the rear. Had some hang ups getting the lower control arms to work, but we made it happen. Also had to take out and adjust the uppers 'cause they were set for a 4" lift and my pinion angle (more importantly the shock mount angle) were way off. So after some PB blaster some Anti-Seize and a bolted down vice grip, we got them adjusted for 3" of lift and bolted back in. Only things left are loosening the e-brake cable to get it around the mount, bolting in the t-bracket of the brake lines, and getting the track bar up in place. For some reason we weren't able to easily get the rear track bar to bolt in.
35s were also mounted up and bolted on in the rear! This thing is a beast! The lower lip of the full door's windows is at my shoulder, and the step up on the rockers is now too high for my leg to lift up to! Woohoo!
Anyway, here are the photos. Tomorrow is the HP install.
djflyy is offline
post #334 of 1986 Old 06-20-2011, 09:55 PM
2003X
Looks awesome.
My Build
2003X is offline
post #335 of 1986 Old 06-21-2011, 05:20 AM
VACJ5
I noticed the pics of the lightbar reinstalled... did the new brackets work out? Looks good man!
79 CJ5 Silver Anniversary Edition... revived & sold *sniff
91 YJ 4.0 L, with some stuff bolted to it...
91 2 door Cherocar... in progress
Custom CNC cut Jeep parts & more
VACJ5 is offline
post #336 of 1986 Old 06-21-2011, 05:20 AM Thread Starter
djflyy
Originally Posted by 2003X View Post
Looks awesome.
Thank you, sir! Now she can be parked next to your TJ and not look like a midget!
My only concern is raking, as I'm not sure how much lift the rear axle added and whether or not I'll need spacers. I don't have any around and driving to Canton today is NOT in the cards. Do any places like AutoZone or Advanced Auto Parts or NAPA carry coil spacers? Like... real coil spacers?
djflyy is offline
post #337 of 1986 Old 06-21-2011, 05:21 AM Thread Starter
djflyy
Travis, the new brackets worked perfectly. Can't say enough about your products and service! I'll send you some close ups once the Jeep is back on the road and the bar is lit up. Thanks again!
djflyy is offline
post #338 of 1986 Old 06-22-2011, 03:30 PM Thread Starter
djflyy
So yesterday Sax and I worked on the axle with some help from 2003x. We got the new tie rod in, the new steering stabilizer mounted, the axle up on jacks underneath, and ONE of the LCAs off the old axle. The other one wouldn't budge (we actually snapped a Craftsman 3/8" socket in half trying to get the nut loose). So I saw-zalled it off and we took the bushing to an compressed-air hammer, and bashed it out. Replaced it with a new bushing and the LCAs are fine.
The other interesting thing was as I was wiring the lights, I managed to completely drain the battery. The guy from AAA said he'd never seen a battery so dead. We ended up finally getting it started, but it would die without my foot on the gas pedal. Anyway, he said I'd need my foot on there for about an hour so we rigged some bricks on the gas pedal to keep it idling at 2,000 RPMs.
Photos from the last 2 days....
djflyy is offline
post #339 of 1986 Old 06-22-2011, 04:19 PM
Amills
Lookin good Dj!
Amills is offline
post #340 of 1986 Old 06-22-2011, 05:38 PM
2003X
Almost there!!
My Build
2003X is offline
post #341 of 1986 Old 06-22-2011, 08:42 PM Thread Starter
djflyy
Almost there!!
Seriously man. At this point I'm just itching to drive it again.
djflyy is offline
post #342 of 1986 Old 06-22-2011, 08:46 PM
2003X
I think the main problem was the rust and the rusted bolts.
My Build
2003X is offline
post #343 of 1986 Old 06-22-2011, 08:49 PM Thread Starter
djflyy
Yeah. That and not working on it every day. Hopefully if this rain stops I can finish tomorrow. All that's left is bolting up one of the LCAs, putting the springs in, shocks, driveshaft, brakes, and rear track bar. Might be able to sqeeze that out tomorrow and have her drivable and aligned by Friday afternoon. In a perfect world.
djflyy is offline
post #344 of 1986 Old 06-22-2011, 08:59 PM
2003X
What did you end up doing for the lower control arm?
My Build
2003X is offline
post #345 of 1986 Old 06-23-2011, 05:33 AM Thread Starter
djflyy
I pried the LCA off of the axle with the bushing and bolt still in it. Then I took a drill bit and drilled out the old bushing. Then Clay and I took the air-hammer to it and bashed the **** out of the bushing. And then we took a sawzall to it and cut it into 4 pieces. Then installed the new one, with a $6 bushing from AutoZone and some grease.
djflyy is offline
35s , boston , built tj , chili pepper pearl , north shore jeeps
First Jeep Build Bosefus Jeep Builds 4 06-20-2012 09:35 PM
03 TJ - Boston Osmosiz Jeep Builds 174 11-22-2010 10:50 PM
Pics of your girl with or without your jeep. Mitchin Jeep Picture Requests 55 11-22-2009 01:18 AM
My jeep build.... 91jeepkidd Jeep Builds 1 01-26-2009 09:16 PM
my jeep girl climbing toke Jeep Builds 1 11-10-2007 08:16 AM
