My Girl... a Boston Jeep Build - Page 21 - JeepForum.com
post #301 of 1986 Old 06-11-2011, 07:49 AM Thread Starter
djflyy
Finally got around to installing my SRC rear bumper... this is the one I might make a tire carrier out of this summer. It looks a million times better than the stock, IMHO. I've got 2 shackles being painted the same red as the front for the back now, too.
djflyy is offline
post #302 of 1986 Old 06-11-2011, 09:30 PM Thread Starter
djflyy
Okay JeepForum... I have a legitimate question that I would appreciate answers to. Offroading today, and engaging 4LO, the t-case shifter broke off and left me stuck in neutral in the pouring rain in mud. After being dragged back out to the main road, I crawled under her and with a small river of rain running down my shirt, I manually engaged 2 hi so that I could get home.
What is the fix for this? Surely there's no way I'm the first person to have had it happen. What's the solution? The circle should be attached where the tip of the arrow is.
..... and some more pics
djflyy is offline
post #303 of 1986 Old 06-11-2011, 09:33 PM
2003X
FIX:
http://www.novak-adapt.com/catalog/shifters/sk2xc.htm
Here is a pic of my set up.
My Build
2003X is offline
post #304 of 1986 Old 06-11-2011, 09:45 PM
2003X
bushing kit
My Build
2003X is offline
post #305 of 1986 Old 06-12-2011, 06:54 AM
midnight_f150
I want to upgrade to the Novak Cable Shifter like this http://shop.savvyoffroad.com/product...&categoryId=13
midnight_f150 is offline
post #306 of 1986 Old 06-13-2011, 07:26 PM Thread Starter
djflyy
Looks like the Novak is what it's going to be... I'm going to wait a little though since the TJ is currently under the knife and I need to make sure everything's set up for that before dumping money elsewhere. SaxManClay and I spent today removing the D35 from under the TJ. Took us just under 2 hours not counting the water and food breaks. Honestly, factoring in the fact that the axle hasn't been removed since it was put in there in the first place, it all went extraordinarily smoothly. I think the brake lines were the most annoying part, but I disconnected the hard lines at the T-block, and ended up just cutting through the e-brake lines since the 8.8 came with its own.
Tomorrow, we'll be taking the D30 out of the front, and she'll be up entirely on jacks. At that point all of the components will be stripped and painted with Chassis Saver as well as the frame and tub itself. That should take a day or two in total, enough for the base coat and a top coat with some Rustoleum enamel on top, and then everything can go back under. During the paint and dry time, I'll order the ZJ steering components, and have the 35s mounted and balanced so they're ready to go under. All in all it should be pretty easy.
Here are a million pictures!
djflyy is offline
post #307 of 1986 Old 06-13-2011, 09:28 PM
2003X
Looks awesome. I called you back to give you some advice before you cut those lines off. Are you doing the install at your house?
My Build
2003X is offline
post #308 of 1986 Old 06-13-2011, 09:37 PM Thread Starter
djflyy
Got your message, my phone had been on silent on the porch. Got the brake lines off at the T-block on the axle itself. And yeah, at the house in Reading. You're more than welcome to swing by when you're free, Clay and I should be working on the front tomorrow if the weather cooperates.
djflyy is offline
post #309 of 1986 Old 06-13-2011, 09:57 PM
2003X
Hopefully the weather will hold out for you. Did ECGS give you a new "T-Block", or are you re-using the one from the D35?
My Build
2003X is offline
post #310 of 1986 Old 06-13-2011, 10:15 PM
kyle_craig
Saw progress in the "what did you do to your TJ today" thread and had to subscribe. Cool Jeep...
kyle_craig is offline
post #311 of 1986 Old 06-14-2011, 05:33 AM Thread Starter
djflyy
They didn't give me a new one... did they give you one? It's greasy as hell.
Thanks! It's good to have someone new following, it's usually just a few of us shootin' the sh*t!
djflyy is offline
post #312 of 1986 Old 06-14-2011, 07:06 AM
2003X
No, i reused it from the d35.
My Build
2003X is offline
post #313 of 1986 Old 06-14-2011, 10:09 AM
jeepin82
I love the skateboard
Go slow go far go fast never last.
jeepin82 is offline
post #314 of 1986 Old 06-14-2011, 12:27 PM Thread Starter
djflyy
Glad someone noticed my hydraulic jack didn't work so I needed to improvise. Had to wash it of brake fluid afterwords but it did what it needed to!
djflyy is offline
post #315 of 1986 Old 06-14-2011, 09:00 PM
2003X
Any updated pics?
My Build
2003X is offline
35s , boston , built tj , chili pepper pearl , north shore jeeps
First Jeep Build Bosefus Jeep Builds 4 06-20-2012 09:35 PM
03 TJ - Boston Osmosiz Jeep Builds 174 11-22-2010 10:50 PM
Pics of your girl with or without your jeep. Mitchin Jeep Picture Requests 55 11-22-2009 01:18 AM
My jeep build.... 91jeepkidd Jeep Builds 1 01-26-2009 09:16 PM
my jeep girl climbing toke Jeep Builds 1 11-10-2007 08:16 AM
