Quantcast My first vehicle, a 91' YJ - Page 3 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > My first vehicle, a 91' YJ
Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJRUBICON EXPRESS Lift Kits and Accessories Available at BasTruck-Lite's New LED Headlamp Series
Old 02-13-2009, 10:25 AM   #31
YJake
YJake's Avatar
Originally Posted by mudcrawler90 View Post
how r you holding the shovel in the frame?
That big rope wrapped around the bumper keeps a good amount of pressure on it. I've gone 70mph on the interstate and it never budged.
If you don't have a big *** rope, you could shove an old rag or shirt in on each side to hold it in place nice and snug if you're worried about it or you could loop a rope around the neck below the head then tie it off onto the frame. Possibilities are endless really.
I also found a place to put my Axe! Might come in handy while camping plus once I had to turn around on a trail because of a downed tree, looks like I'll chop through next time
I have a string holding the handle in place so that it doesn't fall off of the fan shroud. However, I don't think the string is really neccissary because the airbox and it's hoses holds it in place. Oh well, the string just makes me fell better about having an axe resting on my fan shroud while going 70mph on the interstate or hiting bumps on the trail
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline   Reply With Quote
Old 02-13-2009, 10:49 PM   #32
YJake
YJake's Avatar
Updated the current pic to this as of Feb 13, 2009.
I also ordered an H4 headlight conversion kit with a better harness off ebay. The total for both + shipping was about $70. I can't wait to get that baby hooked up so that I can light up the night!
/l , [____],
()_) ()_)==@=)_)
Old 02-19-2009, 01:23 PM   #33
YJake
YJake's Avatar
Got my H4 conversion kit as well as the new harness and installed them both last night.
I'm kinda underwheled over the H4 performance. I was expecting more out of it but Hell, I only paid 40$ for the conversion housings and bulbs so I guess I got what I paid for.
They are brighter and seem to have a higher and wider beam on low but down't shoot out in front of me as far as normal bulbs. On Hi they are like a freaking lazer beam and shoot straight and far ahead unlike before, where the beam just widened and went a little further ahead. Even trade off I guess.
Maybe some FatBoy light bulbs would brighten things up?
/l , [____],
()_) ()_)==@=)_)
Old 02-24-2009, 12:22 PM   #34
YJake
YJake's Avatar
I finally got around to doing the 20Gal. tank mod!
Unbolted and unplugged the filler.
Pulled the inner tubing out of the hole closest to the back of the vehicle.
Now it holds 20Galons! It sits at full longer since the measurer was only meant for the 15gal tank but that's okay, makes me feel better when it stays at full
/l , [____],
()_) ()_)==@=)_)
Old 03-23-2009, 09:21 PM   #35
BobA
Is the shroud strong enough to bolt a hoop type thing to and slide the axe handle through it to hold it instead of string?
01 TJ Sahara
6cyl. 5spd, D30 Aussie/D44 LSD,4.56 gears, RC2.5" lift, RC1.25" body lift, 33's
BobA is offline   Reply With Quote
Old 03-25-2009, 08:32 PM   #36
YJake
YJake's Avatar
Good question...
If I can get the Heep to run good again I'll try that out.
The first cylinder currently isen't firing.
/l , [____],
()_) ()_)==@=)_)
Old 05-01-2009, 07:45 AM   #37
greenmanalishi
whats my wife doing in your jeep???
greenmanalishi is offline   Reply With Quote
Old 06-15-2009, 12:33 AM   #38
YJake
YJake's Avatar
And as an update, the Jeep still only runs on 3 cylinders and caught fire while driving a month ago.
/l , [____],
()_) ()_)==@=)_)
Old 07-07-2009, 01:28 PM   #39
YJake
YJake's Avatar
The Jeep is running great again! But other things have since happened. I'll do some quick update posts.
I Snorked my Heep.
Used some 14Guage 3" galvanized pipe and bent up a snorkel.
Before
Afters.
So far it has saved me over $30 worth of new air filters. Plus I think it looks nice as well.
/l , [____],
()_) ()_)==@=)_)
Old 07-07-2009, 01:37 PM   #40
YJake
YJake's Avatar
After the snork I went wheeling a lot!
Unfortunately a few days after that video I ran over a 2ft wide by 2ft deep trench running through a grassy field while driving off-road. It ended up shearing the passenger side engine bracket clear off of the engine block. This caused the whole drive line to shift rupturing my oil filter, cracking my fan shroud, and causing my rear driveshaft to grind against the bottom of the tub.
My windshield also cracked really bad. Luckily that is free to replace with insurance here in Florida
I've ordered a whole new set including Motor Mounts, Cradles, and Engine Brackets from Brown Dog Inustries.They should be in by the time I get back from vacation in mid-July. One less thing to worry about breaking!
/l , [____],
()_) ()_)==@=)_)
Old 09-28-2009, 03:42 PM   #41
johnroot01
i like that snorkel write-up. im gonna try that one. how much did it set you back?
95 YJ: 4" RC, 1" booms, 1" BL, 33x13.50x15 SS TSLs, 15" RCX steelies, minus sway and trac bars
ONLY IN A
|_Jeep_|
([ ]lllllll[ ])
johnroot01 is offline   Reply With Quote
Old 10-06-2009, 09:18 AM   #42
YJake
YJake's Avatar
Cost me exactly $97 in the end. I recently lost my snorkel cap while wheelin' so I'll have to find another somewhere. Thinking about using the intake cap off of a tractor or small diesel engine.
Wow, I really let this thread go.. I'll update some stuff.
/l , [____],
()_) ()_)==@=)_)
Old 10-06-2009, 09:26 AM   #43
YJake
YJake's Avatar
After the motor mount/engine bracket incident I replaced all of the mounting stuff with a complete BrownDog set. They are VERY beefy and I have total faith in them. I got the poly ones so there is a lot more vibration at idle but that's okay with me, it's a Heep.
My windshield frame was very rusted out so I had to order a new frame as well. It ran me $150 shipped from eBay for a new galvanized replacement. The windshield was free due to insurance in Florida so that was no big deal.
In August I went wheeling with some fellow JeepForum folks and had a blast. Unfortunately I ended up inverting a shackle while I was there and had to drive 80miles back home on an inverted shackle : Funny thing is, it rode just as well with an inverted shackle as it did normally Only in a YJ
/l , [____],
()_) ()_)==@=)_)
Old 10-06-2009, 09:36 AM   #44
YJake
YJake's Avatar
Luckily a fellow JeepForum member offered to give me a free leaf spring if I came to pick it up and since I was going on vacation in Pompano that week I decided to do a big loop and pick it up on the way home.
I drove from Orlando to Pompano/Miami to Ft. Myers to Tampa to Orlando on an inverted shackle
While I was on vacation I went to their local U-Pull-It yard. (yeah, even on vacation I bring all of my tools and visit junkyards for fun ) I cam back with a 4.0TB and Ford Taurus fan. The 4.0TB cost me 20 bones and went on smooth, it gave me more throttle response so not a bad deal over all.
The fan took me a whole night to get set up (stupid clutch fan bolts didn't want to come out) but I did it! I have it wired to come on with the ignition and also have a toggle on the dash for when I decide to go underwater (or to save energy while on the interstate). It also freed up some more HP and the little Heep is faster off of the line now, also seems to start quicker now that it doesn't have to turn that clutch fan.
/l , [____],
()_) ()_)==@=)_)
Old 11-22-2009, 08:28 AM   #45
justin816
Gas price???
Could you send me gas at that price if I sends 50 GAL barrel!!
[COLOR="Olive"]1988 YJ[/COLOR] RC 4" lift, booms, smittybuilt, Hi-Lift, Police scanner, Maxxis Mudders, Hella, Bestop, trails every weekend!!! Always looking for fun.
[COLOR="White"]TOW RIG=[/COLOR]
2006 Dodge Ram 1500 Big Horn, ProCharger, Magna Flow, Cortex, Bullydog, AEM, 22" Boss, 456 gears, tons o audio!
There is only one question in life. Did I hesitate?
[FONT="Impact"][SIZE="4"][COLOR="DarkGreen"]Visit my 88 YJ, "GI JOE" build thread[/COLOR][/SIZE][/FONT]
[COLOR="Olive"]][FONT="Impact"][url]http://www.jeepforum.com/forum/f12[/url] /88-yj-4-2-auto-gi-joe-first-time- build-where-will-forum-take-me-899 516/[/FONT]][/COLOR]
[URL="http://www.facebook.com/profile.php?ref=profile&id=1777673616""]
justin816 is offline   Reply With Quote
Glock Forum
