My first Jeep 1996 XJ - JeepForum.com
post #1 of 2 Old 02-07-2012, 02:11 PM Thread Starter
jackel44
I have a 96 XJ 2.5 5 speed, that I bought from an impound yard. The front drive shaft was missing. I changed the engine oil, flushed the radiator, replaced the thermostat, changed the transfer case fluid, and check oil levels on the diffs.
The problems it had was the previous owner removed all the heater controls, to make room for his huge stereo. It had also the floor rusted completely through.
The only thing that is not stock, is 225 75 r16 tires. I plan on using it for a daily driver, the only time I would use the 4 wheel drive is in the winter time and when I put my jet ski in the water at a sandy beach. I will do some small amount of off-roading when I go hunting.
jackel44 is offline
post #2 of 2 Old 02-07-2012, 02:26 PM Thread Starter
jackel44
I went to the junkyard and got a new dash trim piece and heater controls. When I had the dash apart I noticed that the heater wires were toasted. I wired the circuit with a set of relays, so the amperage does not go through the selector switch. I can draw up the schematic if anyone is interested.
Since I had the dash out I removed the seats and carpet and ground out all the rust on the floor boards. I sheeted it with anodized aluminum sheet metal and screwed and glued it in.
Sorry no pictures.
jackel44 is offline
jeep cherokee 1996 jc96 Jeep Picture Requests 3 09-07-2012 08:11 AM
1996 Jeep Cherokee allen_cavalier Jeep Builds 16 09-07-2012 08:11 AM
1996 Jeep Cherokee Sport dsarraf Jeep Picture Requests 1 09-07-2012 08:10 AM
PLZ Help... 1996 Jeep ZJ Tire Clearance --> DrRyAaGnON Jeep Builds 2 01-04-2011 11:31 PM
1996 Jeep Cherokee geewally9 Jeep Builds 21 12-06-2010 11:42 PM
