My first full build - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > My first full build
Component speaker deal for your dash - NalinMFGIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSteering and more from Ruffstuff!
Unread 05-09-2014, 05:24 AM   #1
jkbunch
My first full build
Well sold my 99 wrangler other day to pay of some loans then with what's left over I got a 2003 wrangler that is going to need a little well maybe a lot of TLC it will be my first full build because as of now it's all stock well what's left of it
jkbunch is offline   Reply With Quote
Unread 05-09-2014, 06:01 AM   #2
AngryRedBird
AngryRedBird is offline   Reply With Quote
Unread 05-09-2014, 09:13 AM   #3
jkbunch
Any body got any ideas for where I can get a grill pretty cheap
Unread 05-10-2014, 12:20 PM   #4
jkbunch
Well I know it wasn't the top priority but couldn't pass on the deal I got for some beadlocks and tires
Unread 05-13-2014, 01:01 PM   #5
jkbunch
Not sure if this is the best place to put this but just seeing if you guys could help. I think that my axel has shifted to the passenger side please help
Unread 05-13-2014, 01:12 PM   #6
AngryRedBird
wow a couple of rusty quick disconnects.. Grill.. best I can tell you is there are several jeep places in and around TN.. I want to say on the outskirts of Johnson City, been there just can't recall the names.. also.. the junk yard.. thou might be tight.. cause typically the most common parts are stripped early.. but you might have better luck if you hire out one of those that frequent the yard..
One thing those wheels have an extreme offset.. sticking way out beyond the point of no return.
Unread 05-13-2014, 05:05 PM   #7
jkbunch
I know on the off sent I like that but the passenger is much Further than the driver and it's also turned outward while other is strait
Unread 05-13-2014, 11:00 PM   #8
jeepwrangler97
You should take a look at how straight (or bent) the tierod is & look at the lower control arm mounts.
Congrats on the new jeep! I love these rebuild builds.
Edit: you need to turbo it, eventually
Sent from AutoGuide.com Free App
jeepwrangler97 is offline   Reply With Quote
Unread 05-14-2014, 11:25 AM   #9
jkbunch
I plan to but tie rod doesn't look bent but how can I tell for sure
Unread 06-03-2014, 06:37 PM   #10
jkbunch
Well finally got hood and fender in then got jeep sent off to paint today
Unread 06-28-2014, 03:49 PM   #11
jkbunch
Well it's been a while but sence paint I found that my frame was diamond a little so had to go get frame pulled then was on vacation and just now getting home trying to figure out where everything goes on the fender
Unread 07-09-2014, 08:54 PM   #12
jkbunch
Just a few updates put in 10hrs in last 2 days but now I have a problem with my wheels not sure what it is but they are sitting like / \ any help
Unread 07-09-2014, 09:08 PM   #13
Altimeter
1997 XJ Cherokee
Your camber is off (negative). Have you had it aligned since you've done all of this work?
1997 Sport XJ - DD
Gone:
1990 MJ, 1998 XJ Sport, 1977 CJ5, 1993 ZJ, 2006 TJ
Altimeter is offline   Reply With Quote
Unread 07-09-2014, 09:23 PM   #14
jkbunch
No still haven't drove it but I thought u can just adjust the toe on these jeeps
Unread 07-10-2014, 06:51 AM   #15
Altimeter
1997 XJ Cherokee
Toe and camber are two different things. If you are sitting in the drivers seat then the following is true:
Toe in is the front of the tires are pointed towards the middle of the vehicle. Camber is the top of the tires are leaned in towards the center of the vehicle.
Getting a professional alignment is ALMOST always required after you do suspension work. It is recommended that you ALWAYS do it.
1997 Sport XJ - DD
Gone:
