My CJ2A build - Page 3 - JeepForum.com
post #31 of 72 Old 04-27-2013, 08:30 AM
tofuzeppelin
tofuzeppelin's Avatar
good work man
01 TJ with some stuff
77 SJ Cruzer
Lifes to short for bad coffee and bald tires
tofuzeppelin is offline
post #32 of 72 Old 07-28-2013, 09:08 PM Thread Starter
berettajeep
1947 CJ2A
Slow progress. Body bolted on. Drive shafts installed. Motor was frozen so I took the head off and used a combination of WD-40, PB Blaster and ATF. Nothing.
My girlfriends ex husband told me to go find some Corrosion Block at a Marine store. So I did.
$20 for 12 ounces. Sprayed everything on top and side. Plus crankshaft and camshaft from underneath. Skip to not quite 24 hours I go outside and hit the key and I get a little bit of movement.
So I spray more of the Corrosion Block on the motor and walk away for 2 hours. I come back and with the long socket wrench and breaker bar I turn the motor over
No pictures yet, have to get gaskets and button up the motor and go from there.
'74 Cherokee 401
berettajeep is offline
post #33 of 72 Old 07-29-2013, 07:15 PM
lovett86
that jeep is awesome, keep up the good work
its a rusty one
http://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #34 of 72 Old 08-09-2013, 05:04 PM Thread Starter
berettajeep
1947 CJ2A
Found out the birthday of my motor....
Pre WW2 block, Ford GPW head all in a post war Jeep
'74 Cherokee 401
post #35 of 72 Old 08-09-2013, 07:49 PM
freaknajeep
1971 DJ
Dude so I'm guessing you only sold the truck build....lol. got some stuff done on the daily dj but yours looks way better than mine at the moment...lol
Be carefull while Hugging the Trees...They leave dents on your Jeep....
Shhhhhh I'm not crazy...It's just the voices in my head
freaknajeep is offline
post #36 of 72 Old 08-09-2013, 08:32 PM Thread Starter
berettajeep
1947 CJ2A
I don't know both of your DJ's look sweet.
'74 Cherokee 401
post #37 of 72 Old 08-09-2013, 08:35 PM Thread Starter
berettajeep
1947 CJ2A
Looky what I did....
No fuel system hooked up, the old nasty spark plugs and old used wires, no cooling system hooked up, no muffler.
'74 Cherokee 401
post #38 of 72 Old 08-09-2013, 08:47 PM
freaknajeep
1971 DJ
Thanks...I'm knee deep in cancer h--l at the moment...and it seems the rain gods have it out for me...
post #39 of 72 Old 08-18-2013, 09:01 PM Thread Starter
berettajeep
1947 CJ2A
Well I rebuilt the Carb and I hooked up the cooling system then I yard drove it with my 6 year old!!!
Have a video I need to edit first.
'74 Cherokee 401
post #40 of 72 Old 08-19-2013, 04:17 PM Thread Starter
berettajeep
1947 CJ2A
This was yesterday. After this video I swapped out the steering box for a actual 2A box. ( the "new" one has a horn and is about an inch shorter then the one that was in there, plus it is much easier to turn.)
'74 Cherokee 401
post #41 of 72 Old 08-24-2013, 11:44 AM Thread Starter
berettajeep
1947 CJ2A
Wiring schematic for starting my Jeep.
'74 Cherokee 401
post #42 of 72 Old 09-15-2013, 09:21 PM Thread Starter
berettajeep
1947 CJ2A
'74 Cherokee 401
post #43 of 72 Old 09-20-2013, 08:05 PM Thread Starter
berettajeep
1947 CJ2A
Traded for a hard top...too bad I would need a 2A windshield to make it work.
2013-09-19 20.38.01.jpg   2013-09-19 20.38.14.jpg   2013-09-07 15.57.24 - Copy.jpg   2013-09-15 22.38.10.jpg
'74 Cherokee 401
post #44 of 72 Old 09-29-2013, 08:59 PM Thread Starter
berettajeep
1947 CJ2A
Lets see...
I bought a heat riser kit for mine cause the bushings were very worn. Took the manifolds to work and sandblased them. My intake had a cracked ear on one of the bolts that was welded bad who knows how long ago. Has pin holes in it.
My exhaust manifold had a lovely crack in it to. Good thin I work in the same building as a machine shop and a very professional welder.
Made a 2A top fit my 3A windshield. Not pretty but does what it needs to.
More done too but I am trying to finish it quickly and cant recall everything I have done.
IMG_20130924_210615.jpg   IMG_20130924_213239.jpg   IMG_20130924_225332.jpg   2013-09-28 19.09.44.jpg   2013-09-28 20.57.27.jpg
'74 Cherokee 401
post #45 of 72 Old 09-29-2013, 10:30 PM
straightsixjeep
Great job, the top looks really good cleaned up!
straightsixjeep is offline
My CJ2A truck build. (Lots of pictures) berettajeep Jeep Builds 43 06-08-2017 07:04 PM
1948 CJ2A Finish Build 4.3 Vortec, T19, Dana 20, Kernerator Jeep Builds 1 10-24-2015 05:57 PM
Cj2a build, Frame Up CDW_327 Jeep Builds 133 11-29-2011 02:02 PM
MY new old 46 cj2a JeepRocks86 Jeep Builds 14 03-08-2011 04:33 PM
304 v8 in a cj2a sega2010 Jeep Picture Requests 4 05-17-2010 03:35 PM
