My Brute Build in Dubai - Page 8 - JeepForum.com
post #106 of 280 Old 09-03-2013, 10:57 AM
freaknajeep
1971 DJ
Originally Posted by Oman Jeep View Post
Also - the DJ's are so short to start with - would be cool to just close the wheel arches out and add a short-bed and make it an extended cab short bed truck that still has the sliding front doors. Moving the back axle all the way back like that would allow for wider axles / much bigger tires and still keeping that door function.
With the Brute build, I'm planning on ways of having additional door mounts on the bed rack so I will be able to drive 1000 km from home on the highway with the full doors, and then remove them and stow them while driving off road.
Being able to just slide them back and carry on would be easier!
If you look at my build thread "special delivery" on the last page someone photoshopped for me pretty much that exact thing..only with a brute bed...it kinda looks like a messed up hummer...lol...if you haven't checked out my thread I would love it if you did...cheers
Be carefull while Hugging the Trees...They leave dents on your Jeep....
Shhhhhh I'm not crazy...It's just the voices in my head
freaknajeep is offline
post #107 of 280 Old 09-03-2013, 04:48 PM Thread Starter
Oman Jeep
Oman Jeep's Avatar
Just looked it up... if you have the total length of the DJ body or something to give a sense of scale, and a good quality picture - I could put the Brute bed on to-scale for you and colour match it so it looks right
Oman Jeep is offline
post #108 of 280 Old 09-04-2013, 01:06 AM
oalali
How much up and down travel will you have ?
oalali is offline
post #109 of 280 Old 09-04-2013, 07:15 AM Thread Starter
Oman Jeep
Oman Jeep's Avatar
Should know that in a few days when I have time to work on it - visitors in town at the moment!
Simple answer - "Lots."
post #110 of 280 Old 09-04-2013, 02:33 PM Thread Starter
Oman Jeep
Oman Jeep's Avatar
Just a cellphone pic - but - teardown in progress
That ARB back bumper sure came off quicker than it went on
post #111 of 280 Old 09-04-2013, 08:44 PM
Benw455
1977 CJ7
Nice work.
Benw455 is offline
post #112 of 280 Old 09-04-2013, 11:15 PM
oalali
Is it a good idea to put the battery that low ??
oalali is offline
post #113 of 280 Old 09-05-2013, 12:36 PM Thread Starter
Oman Jeep
Oman Jeep's Avatar
Rapidly approaching the point of no return!
post #114 of 280 Old 09-06-2013, 12:57 AM
TheDoc25
Look at all the sand and where it has crept into every space available.
Do it!!!! Rip the tub off......
TheDoc25 is offline
post #115 of 280 Old 09-06-2013, 09:22 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Are you reusing the aev highline?
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #116 of 280 Old 09-06-2013, 04:05 PM Thread Starter
Oman Jeep
Oman Jeep's Avatar
Re-using the hood, but ordered new replacement front fenders from AEV as they were buckled in the hard landing that prompted the frame replacement.
post #117 of 280 Old 09-06-2013, 06:20 PM Thread Starter
Oman Jeep
Oman Jeep's Avatar
Shouldn't be much of a problem. Optimas are sealed, and water isn't the best conductor of 12V. Will fully grease up all the terminals for added protection. The rear winch is also connected directly to the battery so if those terminals are exposed to the same water as the battery - it's no different.
post #118 of 280 Old 09-08-2013, 01:50 AM Thread Starter
Oman Jeep
Oman Jeep's Avatar
point of no return coming right up...
And a preview on the suspension parts / front axle truss...
post #119 of 280 Old 09-08-2013, 01:51 PM Thread Starter
Oman Jeep
Oman Jeep's Avatar
The tub doesn't quite fit the new chassis... think it will need some minor modifications to get it to sit right... ;-) Can see how much longer the Jeep will be though as the front edge of the tub is lined up! Now to support it, and cut the back end off, and drop it down into the correct position!
post #120 of 280 Old 09-09-2013, 02:24 PM Thread Starter
Oman Jeep
Oman Jeep's Avatar
Rough cut for the back of the tub - now to remove more spot welds and more carefully remove specific parts, then get the doors mounted again along with the windshield, and then can set the rear wall into place. Before we know it this thing will start looking like a truck! Think we can call this the point of no return!
