My Brute Build in Dubai - Page 6 - JeepForum.com
post #76 of 280 Old 08-17-2013, 09:16 PM
rubidriver
I know some foreign countries require amber turn signals and most DOT regulations are that way too, but why not use your red brake light as the blinker like we do in the states?
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #77 of 280 Old 08-18-2013, 01:53 AM Thread Starter
Oman Jeep
Oman Jeep's Avatar
Technically our regulations call for amber turn signals but there are many American cars on the roads here with red turn signals... (amber is still the vast majority) I just like that with an amber turn signal there's no confusion. With the red turn signals while tapping the brakes it can be a bit like wtf... especially if the third brake light has gone out.
After spending a fortune on all this custom fabrication and bodywork however, I want the best tail-end lighting I can get to make sure nobody runs into it.
So... technically I could be okay with red turn signals but I'd prefer them being in amber and it's more by-the-book that way.
Oman Jeep is offline
post #78 of 280 Old 08-18-2013, 06:43 AM
tsstoudt
Can't you get amber bulbs for the clear lenses?
ΜΟΛΩΝ ΛΑΒΕ
tsstoudt is offline
post #79 of 280 Old 08-18-2013, 10:46 AM
rubidriver
My experience with amber bulbs in clear lenses are poor. The color shows up very weak.
post #80 of 280 Old 08-18-2013, 02:30 PM Thread Starter
Oman Jeep
Oman Jeep's Avatar
The ones I'm looking at are LED boards in nice billet housings - that will look good even if they protrude out from the body - where as the factory housings that take bulbs would just be plastic lenses in reflector housings that are flush in the body so they wouldn't have given any care to how the back side looks.
It would be like this:
as opposed to this:
So it's all up to the manufacturer if they would be willing to do me a board with amber LEDs on it
post #81 of 280 Old 08-18-2013, 05:22 PM
Ken Cooke
Subscribed
Ken Cooke is offline
post #82 of 280 Old 08-20-2013, 05:18 PM
rusty762
The combo lights look cool, have to see some more pics of the Ranger window but I like having access to the bed and just being able to open it on the trail. I ran my rear window open the whole time I was on the trail and wished it was twice the size!
Rusty
If I had eight hours to chop down a tree, Id spend six sharpening my axe.- Abraham Lincoln
Have you hugged a Firefighter today?
rusty762 is offline
post #83 of 280 Old 08-22-2013, 02:40 PM
Originally Posted by Oman Jeep View Post
Tail Section extension almost done - a little more work on the passenger side and some more seam welding to finish up.
Here you can clearly see the winch mount and trailer hitch.
Reinforcement plates and bumper mounts.
Rear view - frame is looking quite long now!
Do you think that there could be enough room to locate a 37" spare tire under the bed if the rear winch mount and second furthest rearward crossmember were removed or modified? Also assuming that a custom gas tank would need to be made ahead of the rear axle like on other trucks.
????? is offline
post #84 of 280 Old 08-22-2013, 05:07 PM Thread Starter
Oman Jeep
Oman Jeep's Avatar
A 35" tire maybe... a 37" would definitely be tight... I'll be taking detailed measurements on the whole frame in about a week or so when it's sitting on axles in the stock positions, so I can set up the suspension for the new long arms based on those measurements, and then design my mid-tank. At that point it will be easy to see if a tire will fit. Will check for you.
My plan is to do a swing-out tire carrier bumper for the spare. I will also be making attachment points on the underside of the roof rack to hang a second full size spare under the rack but floating high above the tonnau. It will render the rear view mirror useless, but will keep access to the bed area nice and easy. The top side of the rack will have a pop up tent as I've mentioned earlier.
The rear of the frame will have a 24.5 gallon Genright tank, another Warn winch, and if there's space, a second battery mount beside the winch.
post #85 of 280 Old 08-26-2013, 06:56 AM
redrelyt12
I'm in on this before I can't catch up!
I never make the same mistake twice - it's more like three or four times.
Build - http://www.jeepforum.com/forum/f22/unlimicon-build-1477723/
redrelyt12 is offline
post #86 of 280 Old 08-26-2013, 03:36 PM Thread Starter
Oman Jeep
Oman Jeep's Avatar
So... we have an air conditioned build room and we're back to making progress
I think these control arms will be hard to break.... so far I've bent stock ones, sheared stock ones in half, and destroyed bushings in aftermarket ones... this time we're going for massively over-specced
Front suspension mocked up so we can design everything to clear at maximum compression so we know nothing will hit. Once we're all mounted up - will set the frame at a stock ride height so we have the axles in the stock position, and then design the new control arms to put the axles in the same position. Hopefully when we are all done, and the body goes on, the axles will be in the correct position
Back axle in position - waiting for the shocks to be mounted.
6-pak shocks - telescopic top and bottom for extra travel while the body of the shock with all the valving floats in the middle. Feels good to see them on the frame
The plan is that this weekend, we'll be 3D scanning the frame, AND the underside of my old Jeep which still has the drivetrain fitted, and then designing the suspension layout in CAD so it doesn't hit anything. Will move the factory lower control arm mounts towards the middle of the frame for a "factory" look, and then make custom brackets for the uppers, and then the axle housings will have trusses that will incorporate the control arm brackets. Having all this in CAD will then let me design the sub-fuel tank in the mid-frame later, knowing it will clear everything... Will also help in the cage design knowing where all the body mounts are.
post #87 of 280 Old 08-27-2013, 12:15 AM
ashland82391
I have to say, those are the ugliest shocks I've ever seen lol. Hope they preform well!
ashland82391 is offline
post #88 of 280 Old 08-27-2013, 01:43 AM Thread Starter
Oman Jeep
Oman Jeep's Avatar
It's a different look that's for sure
But it's all about the functionality / flexibility - and given there's more travel to go and the stock control arms are maxed out - I think they will achieve that once we replace the arms with long-arms.
I'm excited to drive them but as you can see there's a long way to go still
post #89 of 280 Old 08-27-2013, 01:07 PM
Jcool
1993 XJ Cherokee
subbed, love Brutes
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_) 1993 Jeep Cherokee Sport 4.0L
Jcool is offline
post #90 of 280 Old 08-27-2013, 02:09 PM
JeepJohn92
1988 XJ Cherokee
This thread is so crawled. I have a feeling there's more images than Im seeing, is it just my computer or me? I want to see this beast for what It really is.
Colorado Jeep Club Member #343
Built not bought.
JeepJohn92 is offline
