My Brute Build in Dubai - Page 15 - JeepForum.com
post #211 of 280 Old 07-13-2014, 03:47 AM Thread Starter
Oman Jeep
Oman Jeep's Avatar
Originally Posted by TumTum3 View Post
Sweet tent on the raptor. Subbed
Thanks!
It will be usable on the Brute too when it's all done - but the Raptor has a nice width for having that up on the roof. :-)
One step closer :-)
Oman Jeep is offline
post #212 of 280 Old 07-13-2014, 07:42 AM
TheDoc25
Glad your back on the brute. I have just finished swapping mine over to RHD after returning to OZ.
Hope you will have time to do the build and update as you carry on,
TheDoc25 is offline
post #213 of 280 Old 07-20-2014, 09:46 AM Thread Starter
Oman Jeep
Oman Jeep's Avatar
It's a bit cramped in the workshop today so not the best picture angle this time - but the Brute is now sitting on it's 37" tires.
Still got to finish the back bump stop plates and then we put the bed back on and find out if anything needs trimming. :-)
post #214 of 280 Old 07-20-2014, 12:02 PM Thread Starter
Oman Jeep
Oman Jeep's Avatar
A bit more CAD work for tonight:
A friend's Jeep has similar bump stops set up in the front, and has managed to actually bend the plate they are welded to. After seeing that - I've drawn up a reinforcement plate to be welded on.
Securing a car on a trailer using the body / chassis can be a bad idea - especially if the straps don't have snap-hooks on them. As the car bounces on the suspension while it's on the trailer, those straps are going slack and pulled tight again, repeatedly. If you're really unlucky, the hooks can fall out. That won't happen with these tie-down tabs welded to the axle housing. These front ones fit up flush against the swaybar mounting points.
And the rear ones are simply on the axle tubes.
post #215 of 280 Old 07-20-2014, 02:51 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Thanks! I guess the key is just finding a way to make what you enjoy doing into a profitable exercise... that way you're naturally good at it, it doesn't feel like work, and you don't even notice the overtime. I do insane hours and I enjoy it.
Solid advice right there.
What is it that you do?
Michaelgoesrawr is offline
post #216 of 280 Old 07-20-2014, 03:23 PM Thread Starter
Oman Jeep
Oman Jeep's Avatar
I do CAD Design work :-)
post #217 of 280 Old 07-23-2014, 03:32 PM Thread Starter
Oman Jeep
Oman Jeep's Avatar
Lots of goodies just arrived in the container :-)
Genright Fuel Tank, Ranger Power rear window, Pace Edwards power tonnau cover, universal bedrug kit, BedRug TJ interior kit, some Mopar goodies, Mac's Custom Tie down tracks, and various bits and pieces.
Somehow all this stuff will fit on the tiny Jeep :-)
post #218 of 280 Old 07-24-2014, 10:25 AM
Vathenum
Looks great so far!
Vathenum is offline
post #219 of 280 Old 07-24-2014, 10:30 AM
Tonellin
Glad your back at it..one of my favorite builds on the forum. Great work!
06 LJ Rubicon
http://www.jeep-owner.com/index.php/topic,748.0.html
Tonellin is offline
post #220 of 280 Old 07-27-2014, 09:46 AM Thread Starter
Oman Jeep
Oman Jeep's Avatar
Here she is! Sitting on 37 inch tires with the bump stop mounts all done and the bed and fenders re-installed. Next step - install fuel tank and check clearances of the custom suspension and crazy shock absorbers against the tank. It arrived just in time
This is quite possibly the first photo of two Brutes side by side in the Middle East
And this is quite possibly the second photo of two Brutes side by side in the Middle East
Also note: Pace Edwards electric tonnau cover box - ready to go on the Brute when it's all done
Front Bump Stop Mounts massively reinforced - after seeing a similar design for the bump stop mounts on the Blue Brute had bent the spring perches slightly. The Blue Brute is missing it's front fenders as it undergoes the same improvement.
The Rear Bump Stop Lower Perch in place. The tube hanging down from above it represents the length of the bump stop at full compression. This will be removed and replaced by the actual bump stop. A lot of options were explored but this worked out to be the best location to keep them in-line with the shock absorbers (so that landings are the same as articulation - e.g. one at a time or both hitting together) and also as close to the axle tube as possible.
post #221 of 280 Old 07-27-2014, 09:55 AM
tyvanwie
Absolutely beautiful.
tyvanwie is offline
post #222 of 280 Old 07-27-2014, 09:57 AM
chmo
Brutal
Sent from AutoGuide.com Free App
"The more I know, the more I realize how much I don't know"
chmo is offline
post #223 of 280 Old 07-27-2014, 11:42 AM
Tonellin
amazing work...that pic of the two brutes together is awesome
06 LJ Rubicon
Tonellin is offline
post #224 of 280 Old 08-01-2014, 10:34 PM
TheDoc25
Who owns the second one. Was that an import or built in UAE?
TheDoc25 is offline
post #225 of 280 Old 08-17-2014, 11:24 AM Thread Starter
Oman Jeep
Oman Jeep's Avatar
A new friend of mine The truck has been here a while but it just recently changed hands.
The Brute conversion was done in the states, not sure who by, and the suspension was done by another garage in the UAE (Mebar) and the engine swap to a V8 was done by another garage (the guys that use the AEV name with no affiliation to AEV).
