My Brute Build in Dubai - Page 13 - JeepForum.com
post #181 of 280 Old 10-29-2013, 05:28 PM
JJeeper09
Since you are already building arms and brackets, why didn't you 4-link?
What will you wheel base be? Those arms just seem to be a lot of work for little gain as far as performance. You still have a limiting track bar, and stock coil bucket location.. Seems if you are going to do all the work, might as well got the extra to do it right..
Cool build!
JJeeper09 is offline
post #182 of 280 Old 10-30-2013, 06:32 AM Thread Starter
Oman Jeep
Oman Jeep's Avatar
Cool build!
The reason for keeping the factory style 4-link + panhard bar was because of the open space in between the frame rails. The Triangulated setups make that space useless for the most part. The goal is to have a secondary fuel tank on the drivers side of the shaft, and the exhaust, electric cut-out muffler bypass (volume control :-) ) and maybe an air tank on the passenger side. Also - the wheelbase is extended to 117" so the tail wiggle effect of the track bar compressing on a hard bump shouldn't be such a problem.
The advantage of going through the trouble of doing it - better geometry through longer ranges of wheel travel - better ride - better impact absorption. When you catch air (not something I make a big habit of but it was an unintentional launch off of a dune that bent the old frame and initiated this whole project!) - the short arms end up on a sharp downwards angle. When the nose comes down and makes contact with the ground - the direction of the impact is along the direction of the arm. This transfers the energy to the chassis and the shock absorbers don't play such a big role. With the long arms, the arms will be flatter - which in turn means they won't be at such an extreme angle when they extend - and that means on the impact the shock absorber can dampen things better. In addition I'll be adding King bump stops - we just haven't got that far yet.
For fun - note the size of the stock arms on the floor on the left in the above pic.
Oman Jeep is offline
post #183 of 280 Old 10-30-2013, 07:18 PM
heb80
i like it
heb80 is offline
post #184 of 280 Old 11-11-2013, 08:12 AM
chmo
curious ...
this year (two weeks ago) I had unexpected registration renewal trouble ... the regulatory authorities have finally come to the conclusion that 6->8 engine conversions are ALL not allowed anymore (new and EVEN already registered old).
I barely slid through this year ... next year my proudly and correctly modified toy can only pass with an "exception" or miracle :screwy: :what:
What is affecting you as well: my same as last year 3" lift was too high ... I had to "lower" it ... but nobody said anything by how much.
Slowly loosing motivation and interest with my previously beloved Jeep here
Sent from AutoGuide.com Free App
"The more I know, the more I realize how much I don't know"
chmo is offline
post #185 of 280 Old 11-15-2013, 03:26 PM Thread Starter
Oman Jeep
Oman Jeep's Avatar
Originally Posted by chmo View Post
curious ...
It's never been easy... Always need those exceptions.
It does seem that Dubai's a bit easier than Abu Dhabi tho.
post #186 of 280 Old 11-15-2013, 08:47 PM
Cuder
You need to tell Abu Dhabi to get with the times of Dubai. Tell them to quit being Democrates.
My Build Thread:
Cuder is offline
post #187 of 280 Old 12-10-2013, 07:57 PM
machine0020
Updates?? Lol. Next time I'm in Dubai, I have GOT to see this....
Red Jeep Club #534.
machine0020 is offline
post #188 of 280 Old 01-10-2014, 10:14 PM
jherrington
jherrington is offline
post #189 of 280 Old 01-23-2014, 01:50 PM
TheDoc25
Hey Laurie any updates??? Xmas over, new year over. Nice cool weather even sneak pics of your control arm brackets will do...
TheDoc25 is offline
post #190 of 280 Old 02-05-2014, 12:25 AM
jbjorgen
jbjorgen's Avatar
Jonesin' for an update too.
jbjorgen is offline
post #191 of 280 Old 02-05-2014, 12:45 AM
zerocool1
very nice!
When all else fails... Hit it with a hammer!
zerocool1 is offline
post #192 of 280 Old 02-20-2014, 06:17 PM
TheDoc25
I'm hanging for an update".........
TheDoc25 is offline
post #193 of 280 Old 02-20-2014, 07:18 PM
aftex99
I like the way this is turning out. I have to follow
aftex99 is offline
post #194 of 280 Old 04-29-2014, 01:52 PM
Discostu004
what happened...
what's happened to this thread? haven't seen any updates. hope everything is ok with the build AND the builder
Discostu004 is offline
post #195 of 280 Old 04-29-2014, 02:12 PM
chmo
The author has not logged in since his last post mid of November
chmo is offline
