My Brute Build in Dubai - JeepForum.com
post #1 of 280 Old 07-12-2013, 07:20 AM Thread Starter
Oman Jeep
Oman Jeep's Avatar
AEV BRUTE build in Dubai
So I figure now is a good time to start the build thread on my Brute - the majority of the parts have finally arrived!
First - an intro on what we have got planned - the whole goal is to make the Jeep much more user-friendly for longer trips. That means replacing the 4 jerry cans with an in-built second tank, more accessible cargo that can be better organised, and more comfortable cabin.
The build will take a 2001 Wrangler and do the Brute conversion, with custom long arm suspension using MetalCloak parts. I'm already starting with on board air, air locker in the front, Ected in the rear, SwayLoc etc etc... And the 6-pak shocks will be complimented with King 2" gas bump stops.
The refined part of the build - will be on two levels - firstly the interior is going to see quite a lot of leather and alcantara trimmings and a lot more noise insulation than it's ever had. Recaro seats may also be done too. The other refinements will be the expedition preparedness like the dual tanks with electric transfer pump, dual battery. The roof top tent. Also a swing-out tire carrier on a custom rear bumper. Taking the hard work out of it all.
The HiTech aspect - it's going to have Garmin in-dash GPS integrated to the OBD-II system. Park sensors. Camera systems front / rear / underneath. Power Sunroof. Power drop down rear window. Power normal windows. Add to that radar based blind spot monitoring system. Already has power retracting running boards. Also some of the technology that will be used to make the parts - using scanning equipment and CAD to do the suspension pieces, design the roll cage, and make the rear bumper and cargo rack (and perhaps re-do the front bumper).
And now some pictures!
This is the Jeep as it stands today:
Photoshop goal:
Unboxing some parts!
Should take a while to wear these bushings out
Oman Jeep is offline
post #2 of 280 Old 07-12-2013, 08:03 AM Thread Starter
Oman Jeep
Oman Jeep's Avatar
Frame is now cut! After the weekend it will be welded up again in its extended length, and then we worry about the tail section. After that, we throw axles and shocks under it and take measurements on where we will be placing the long-arm bracketry.
This is the cutting template - shows you where to section the frame. It's used on both sides, and you cut on the straight edge of the rear-most zig-zag holes.
This is the rear extension sub-frame - which includes the rear winch mount and the trailer hitch connector.
This is the alignment template for when it goes back together. It has the same holes as the cutting template and access holes for you to tack-weld it in place. This ensures the stretched frame is straight and correct.
This is the section of frame rail that will go in the extended part of the frame.
The cutting template clamped in place for the holes to be drilled.
The frame is now cut - and repositioned on the jack stands using the extension templates. They will then come off again while the inner reinforcements are put on. Then the extension pieces are loosley put in place, re-attach the extension templates and begin welding!
Some of you may notice no pictures of the interesting bit - when it gets cut - but there IS video and I'm working on it
post #3 of 280 Old 07-12-2013, 08:48 AM
wwch99tj
Looking forward to seeing this thing come together!
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #4 of 280 Old 07-12-2013, 09:06 AM
G Beasley
Awesome start so far , I look forward to watching this build. .
G Beasley is offline
post #5 of 280 Old 07-12-2013, 10:38 AM
sjones26573
Sub city
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #6 of 280 Old 07-12-2013, 10:41 AM
rusty762
Nice, looking forward to this build.
Rusty
If I had eight hours to chop down a tree, Id spend six sharpening my axe.- Abraham Lincoln
Have you hugged a Firefighter today?
rusty762 is offline
post #7 of 280 Old 07-12-2013, 10:53 AM
rubidriver
Subbed, although none of the pics work for me.
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #8 of 280 Old 07-12-2013, 10:55 AM
sjones26573
Pics are the most important part
Jeep-Owner.com
post #9 of 280 Old 07-12-2013, 11:00 AM
chmo
subbed
"The more I know, the more I realize how much I don't know"
chmo is offline
post #10 of 280 Old 07-12-2013, 02:48 PM
TanMan99
This should be awesome!
TanMan99 is offline
post #11 of 280 Old 07-12-2013, 03:29 PM Thread Starter
Oman Jeep
Oman Jeep's Avatar
I sure hope so!
post #12 of 280 Old 07-12-2013, 03:30 PM Thread Starter
Oman Jeep
Oman Jeep's Avatar
They're hosted on my Facebook for now - are you on a work connection that blocks facebook?
post #13 of 280 Old 07-12-2013, 03:57 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
I thought I'd never see you again, your last post was ages ago
My builds:
and
or follow us on
spyder6 is offline
post #14 of 280 Old 07-12-2013, 04:24 PM
rubidriver
Pics work!!! This is awesome. I never really liked how short your TJ looked with the highline, no offense. This will be epic.
post #15 of 280 Old 07-12-2013, 07:13 PM
contdevelop
Subscribed! This looks interesting.
contdevelop is offline
