My adventures into YJ ownership - JeepForum.com
post #1 of 186 Old 02-20-2013, 10:26 AM Thread Starter
Ken3783
The YJ money pit
I originally bought this 95 YJ in Pensacola, FL in 2010. It had several issues that had to be taken care of right away. After $1500 in tires,
rear brake repairs, new radiator, tie rod end replacement, it was finally drivable, as the first drive home in pouring rain almost got me killed
in a head on collision.
Ken3783 is offline
post #2 of 186 Old 02-20-2013, 10:43 AM Thread Starter
Ken3783
More repairs
Had to replace the rear crossmember as it was rotting away. Dropped the fuel tank, lifted the body partially
off the frame and welded the new part in place.
207466_1980405513291_6167331_n.jpg   198865_214573625223887_7313740_n.jpg   196860_1980534956527_4654622_n.jpg   205323_1980533236484_1559650_n.jpg
Ken3783 is offline
post #3 of 186 Old 02-20-2013, 10:55 AM Thread Starter
Ken3783
Relocated the radio from the dash into the center console and blanked off the old radio hole in the dash
and added an aux input adapter for the radio.
IMAG0220_zpsde4b58ff.jpg   IMAG0221_zpscfafa997.jpg   338966_274534902561092_7930476_o.jpg
Ken3783 is offline
post #4 of 186 Old 02-20-2013, 11:07 AM Thread Starter
Ken3783
After several attempts to fix the soft top, I opted for a used hard top. Found one for $300 off of CL that wasn't too bad off.
Had to fabricate new support arm brackets and buy new support arms.
Ken3783 is offline
post #5 of 186 Old 02-20-2013, 11:31 AM Thread Starter
Ken3783
Found some full steel doors for $150 off CL and began cleaning them up and repainting them. The silver that is on
the jeep is not stock by any means so paint matching took quite some time but I manage to find the right stuff. Also
replaced the chrome handle with new black handles from Quadratec.
328132_276674429013806_2150012_o.jpg   291242_281973961817186_5779438_o.jpg   338422_283083411706241_7044184_o.jpg   289745_286272231387359_802266049_o.jpg
Ken3783 is offline
post #6 of 186 Old 02-20-2013, 11:50 AM Thread Starter
Ken3783
Finally got the funds together to get a better lift going. 5" BDS lift with 1" boomerang shackle lift. It was an excellent setup and had
everything I needed for the complete setup with braided brake lines and Fox shocks, etc etc. The old lift was an extreme pain to remove
and even required creating a special tool to remove the old shackles off. Also did the SYE kit, new front and rear driveshaft
(custom built at a local shop).
327615_371130472901534_1449510544_o.jpg   465605_390554327625815_1049270609_o.jpg   333947_390554477625800_1440606769_o.jpg   462098_393008280713753_9969435_o.jpg   IMAG0202_zps84799858.jpg
Ken3783 is offline
post #7 of 186 Old 02-20-2013, 11:57 AM Thread Starter
Ken3783
Finally got warm enough to finish the hard top. So I set it up and Raptor lined the top and flat blacked the interior of it.
Also decided to do the top section of the doors as well.
IMAG0039_zps9a273b5a.jpg   IMAG0033_zps40557101.jpg   169381_499210283426885_252918062_o.jpg
Ken3783 is offline
post #8 of 186 Old 02-20-2013, 12:01 PM Thread Starter
Ken3783
Decided that the rear bumper mounts were too weak, so I fabricated my own and had a buddy of mine weld them up.
477205_477551528926094_782140594_o.jpg   475544_477551468926100_1652280936_o.jpg   411315_478941928787054_1092532035_o.jpg   338861_487917594556154_1485733913_o.jpg
Ken3783 is offline
post #9 of 186 Old 02-20-2013, 12:05 PM Thread Starter
Ken3783
Bought a Kargo Master roof rack of a friend, but his Jeep is a TJ so I had to make my own mounts for the windshield.
856473_604054096275836_94077307_o.jpg   841132_604054116275834_31335536_o.jpg   858634_604054112942501_1425579016_o.jpg   IMAG0205_zps1799b772.jpg   IMAG0211_zps1ecc36ed.jpg
Ken3783 is offline
post #10 of 186 Old 02-20-2013, 12:13 PM Thread Starter
Ken3783
Currently working on cleaning and repainting the cage and basket of the roof rack. Also had a friend weld on some steel
to mount the jerry can mounts I purchased awhile back. I have 2 mounts, 1 for each side, mounted in the back of the basket.
Still a work in progress.
Ken3783 is offline
post #11 of 186 Old 02-25-2013, 11:49 AM Thread Starter
Ken3783
Was missing a 1 of the 4 bracket mounts for the basket to the cage so i had to make my own since local hardware
shopping yielded no results. Got some donor steel off the old transfer case skid plate drops. Cleaned them up, bent them
to size and painted.
860512_610476945633551_1711540163_o.jpg   861467_610073302340582_1005275946_o.jpg   858844_610073879007191_1119789319_o.jpg
Ken3783 is offline
post #12 of 186 Old 02-25-2013, 12:01 PM Thread Starter
Ken3783
Assembled the basket. Mounted the jerry can mounts on the steel in the back that my buddy welded on for me. Attached said
jerry cans. The wife and I installed the basket on to the cage at 8 or 9pm. It was sleeting at the time which made the process enjoyable.
860389_610071105674135_655199598_o.jpg   859495_610072332340679_2119177451_o.jpg
Ken3783 is offline
post #13 of 186 Old 02-25-2013, 12:10 PM Thread Starter
Ken3783
This is the finished setup for time being until more funding becomes available. Getting ready to be re-stationed in Sitka, AK.
Also had some diamond plate rear corner panels laying around so my buddy and I installed those with some 3M double-sided
molding tape and attached the roof rack rear cage mounts through the plating and through the upper section of the tub above
the lights. We also put a steel plate in the inside of the tub attached the rack mount bolts for additional strength and security.
The rear cage mounts also required trimming to work with the flush mounted rear lights.
861056_610070049007574_1236882676_o.jpg   830446_610070585674187_1511255122_o.jpg
Ken3783 is offline
post #14 of 186 Old 03-03-2013, 12:16 PM Thread Starter
Ken3783
8.8 swap
Found this at a pick and pull while I was searching for an upgraded alternator. So I will be getting this ready while
I search for the front axle for the correct gearing.
487186_613519425329303_1064937860_n.jpg   1050_613519395329306_1234696236_n.jpg   540928_613519401995972_1523389361_n.jpg   859414_613519845329261_1548415923_o.jpg
Ken3783 is offline
post #15 of 186 Old 03-07-2013, 02:43 PM Thread Starter
Ken3783
136 amp alternator swap
Wired up the new alternator directly to the battery with 2ga wire and a 150 amp circuit breaker just before the battery terminal. It was mostly a direct bolt on with the exception of the power wire clocking shroud on the back. Had to shave it down in places for the 2ga terminal lug to fit in, but easy enough. Also had to place the belt onto the alternator before placing it in its bolt holes and use a breaker bar as a crow bar to get the bottom adjustment bolt in. Took longer than I initially expected but most of that was due to the weather, 32 degrees, rain/snowing off and on, high winds. It was a bad time to do it but I wanted it done.
Ken3783 is offline
