My 98 TJ - JeepForum.com
post #1 of 10 Old 07-20-2014, 04:27 PM Thread Starter
footbag828
My 98 TJ
Got this 98 jeep tj last year around October.
4.0 auto.
My first time offroad I ripped the passenger side front fender off.
Instead of paying too much to get the one new fender painted I got both of the front fenders Line-X'ed. By Line-X of Mid Missouri. They had only quoted me $150. What a good deal, I thought.
Finally I saved enough to buy a Rough Country 1.25" body lift.
If it wasn't hear enough to save for a $100 body lift, I eventually saved for a 4" Rough Country X-Series lift kit.
footbag828 is offline
post #2 of 10 Old 07-20-2014, 04:36 PM Thread Starter
footbag828
On the skid plate the frame was too rusty so we drilled through and through the top also and put some 7x1/2" bolts through to hold it up now. We also installed a Rough Country transfer case drop and an adjustable rear track bar from Rough Country.
After the lift I put on some Pro Comp 35x12.5x15 Xtreme MT tires on 15x8" Cragar rims. I got the tires used on craigslist and the rims from quadratec.
I've got a lot if other things I want to save for. Like an SYE and bigger axles and winch.
post #3 of 10 Old 07-20-2014, 04:44 PM
rdock31
Originally Posted by footbag828
On the skid plate the frame was too rusty so we drilled through and through the top also and put some 7x1/2" bolts through to hold it up now. We also installed a Rough Country transfer case drop and an adjustable rear track bar from Rough Country. After the lift I put on some Pro Comp 35x12.5x15 Xtreme MT tires on 15x8" Cragar rims. I got the tires used on craigslist and the rims from quadratec. I've got a lot if other things I want to save for. Like an SYE and bigger axles and winch.
You can get replacement nutserts from black magic brakes.
BDS - Savvy - Brown Dog - AtoZ - Metalcloak - Falken - RC
rdock31 is offline
post #4 of 10 Old 07-22-2014, 05:08 PM Thread Starter
footbag828
Hey guys I know I need an SYE, but do I need to change the drive shafts also? Front or back?
post #5 of 10 Old 07-22-2014, 05:14 PM
rdock31
Rear you will, with a sye you'll need a cv style shaft.
rdock31 is offline
post #6 of 10 Old 07-22-2014, 05:54 PM
JCJeep97
Back shaft needs to go to a CV shaft. Keep in mind that if you do a tummy tuck in the future, a shaft that is a good length now may not work post-tuck.
Tuck that thing up now and never look back. TC drops are the third worst thing in the world behind Nazis and hipsters.
My Build: http://www.jeepforum.com/forum/f22/back-black-2000-tj-build-1237980/
JCJeep97 is offline
post #7 of 10 Old 07-26-2014, 07:37 PM Thread Starter
footbag828
What is bad about the tc drop? I was thinking of the motor mount lift for now and save for other stuff. Can I get a cv shaft that will work for both with a tummy tuck and without?
post #8 of 10 Old 07-26-2014, 09:01 PM
rdock31
It just defeats the purpose of a lift..
rdock31 is offline
post #9 of 10 Old 07-27-2014, 08:21 AM Thread Starter
footbag828
Ok I see just the clearance issue. Gotcha
post #10 of 10 Old 07-27-2014, 08:25 AM
rdock31
Basically.. for most who don't do any wheeling in their jeep a t case drop is fine. But for those who do it's just another thing to get hung up on.
rdock31 is offline
