#1 | |
My 94 YJ, SOA, 100"WB, 37's
Some Poser Shots:
![]() ![]() ![]() ![]() ![]() Gotta get some better trail shots, the snow needs to stop falling for that to happen though! Stats: 1994 Wrangler YJ 4.0L, 5spd, 76k miles D30, 4.88's, Warn Alloy Inner and Outer Shafts, ARB Locker Ford 9" Rear, 4.88's, Moser 31 spline Shafts, ARB Locker NP231, AA SYE, Tom Woods Driveshaft Modded 3" Superlift Springs, SOA, 100" Wheelbase MORE Shackle Reversal Custom 3/4ton High-Steer SkyJacker Anti-Wrap Bar Poison Spyder Rocker Knockers and Corners w/ Flushmount LED's BlueTorch Fab Front Bumper/Stinger Ramsey Patriot 9500 Smittybilt Rear Bumper/Swing-out Bushwhacker Flares 37x12.50x16 Swamper TRXUS MT's on 16x8" MT Classic Locks Kilby OBA Setup Lemmme know what yall think! -Nick
#2 | |
JF Administrator, eh?
Hello, my name is Vance and I am a Jeepaholic. Its better to be naked with your friends, than to be clothed with your enemies #1 From street to trail, '88 YJ on 38" tires does it all well #2 Silver 2006 TJ Unlimited, zombie ready as the daily-driver .. and now a Kawasaki KLR650 DualSport bike TEOTWAWKI |
#3 |
Not so great, seems to like to eat Drivers side ujoints and outer stub shafts.
Theres no point going to a D44, as its the same size ujoint. Thanks for the click free too! |
#4 |
I have been running a full-width Chevy D-44 front for ~7 years now. The only issue I have had is with mud eating everything up. I haven't had any breakage on trail due to a fairly rigorous maintenance after each major off-road tour. My brakes (front and rear) need to be changed twice a year (on average) because of the fine clay-based mud around here.
#5 |
Ive snapped 3 outers and taken out the drivers side balljoints once, all wheeling in the snow, not even on the rocks.
#6 |
Hate to say it - but - you might want to consider half-ton or greater strength in axles (you already are there in the back). My friend tried to swear by the stock front 1/4 ton rated axle with his 35" tires - he snapped U-joints like toothpicks. He got so good at replacing axles and joints that he had it down to under 15 min start to finish.
A good waggy Dana44 could help you out.
#7 |
Keep in mind, one of those outers was a Warn Alloy. The problem lies in the WEAK outer/ujoint section, thats what keeps failing. A waggy 44 uses the same size 297x joint as im running already in my WARNs. So there would be no upgrade at all.
The only way for me to upgrade would be a D60 or 9" Front, but i have to keep it stock width to pass inspection here, as it is my DD. |
#8 |
can you show some pics on how you mounted your high lift jack. i have the same bumper and want to do that.
2003 white rubicon on 37s http://farm4.static.flickr.com/3374/3258900652_92376a0a33_o.jpg |
#9 |
I have the smittybilt bumper/carrier, i used a left-over bolt hole and put a bolt through the inside facing out with a nut on it, then 2 rubber gromits, one on each side of the jack.
The bottom rests on the swingout, i have a rubber base on my hi-lift that helps hold it in place. ![]() Im going to build a large "wing-nut" to screw on and hold it to make for easier removal. |
#10 | |
http://www.durtyrok.com http://www.armyparatrooper.org http://militaryjeepers.com |
#11 |
Recently changed a few things, im digging the new look.
Black flares, Red Doors and Red Rock Rings. ![]() ![]() Wheeling: ![]() ![]()
[CENTER]**Daily Driven** [URL="http://www.jeepforum.com/forum/showthread.php?t=696168"]My 94 YJ, SOA, 100" WB,37" MTRs on 15" Eaton 32Bolt Beadlocks[/URL] March 2009 JF YJ Of The Month JeepFest 2009 Runner-up Best of Show YJ See Dan at [URL="http://www.ruffstuffspecialties.com/catalog/index.php"]RuffStuffSpecialties[/URL] for all your Fabbing needs! And check out [URL="http://www.shopjeepparts.com"]Z & W Offroad[/URL] for Cheap prices and quick shipping on all your Jeep needs[/CENTER] |
#12 |
well i hit up the beach today with the top and doors off and snapped a few pics:
![]() ![]() ![]() ![]() hope you enjoy!
#13 |
Thats a good lookin YJ man!
![]() Caleb
2000 Jeep XJ; Heated Leather; 5.5 w/ACOS; 32's BIGHORNS; RK 3 Link; RE Monotubes; Rock Sliders; Rustys TC Skid; Front & Rear Recovery; Cobra CB; Flo-Pro Exhaust; Airaid; Surco Rack; HD Steering Crossover; IRO Adjustable Track Bar; SOLID d30 Cover; Recessed Winch Bumper; Gorilla Silver Back Series Winch; Hella 500 Lights...
#14 |
Great looking YJ
l _____ /l ,[____], l---L –[]lllllll[]- ()_)-()_)--o-)_) |
#15 |
Good job man. Clean, not too overdone...very tasty.
![]() Can you give me some details...I'm planning a build on a YJ and gathering info what exact springs are you running? What did you do to get the 100" WB? What steering? Stock steering box or upgraded? What did you do for the gas tank? thanks!! Branon
Former TJ owner...present YJ owner |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
