My 93 2.5 low output build - Page 99 - JeepForum.com
post #1471 of 2401 Old 06-09-2013, 06:09 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
So I need to figure out a way to hook my steering stab back up, and on know of a kit for the tre end that will fit of 1.50 dom? I am talking about the kind that has mini u bolts on it. I tried adding 2 oz of bbs to the front tire and it didt help much :/when it start to wobble I can watch the tire wobble!
zte87 is offline
post #1472 of 2401 Old 06-09-2013, 06:13 PM
CDW_327
Steering stabilizers are over rated and don't do ****, at least on my jeep lol.
CDW_327 is offline
post #1473 of 2401 Old 06-09-2013, 07:03 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
I thought the same thing but my front end it tight/ tires are balance (at least I think)/ my toe is good/ so I guess it's back to a band aid fix :/........ And you got to keep in mind you are running 35 km2s which run small and I am runnin 37 pbr's on beadlocks which in my head is a whole other type of fruit haha!
zte87 is offline
post #1474 of 2401 Old 06-09-2013, 07:12 PM
CDW_327
Yeah your PBR's are big and mean but there's no way a steering stabilizer is going to fix any shacking or wobbles in your steering. A stabilizer is really just to tighten up the steering for when you hit a bump in the road. I've come to the conclusion while trying to fix my shaking at around 60 mph that its just the way it is because I'm running a tire with a ton of rubber and a Giant side wall. It's not going to drive like a regular vehicle with normal tires.
CDW_327 is offline
post #1475 of 2401 Old 06-09-2013, 07:18 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
I hear you there but this wobble wast there before I rotate and up graded the steering, I am just stumped.......the wobble is intermittent and start around 35 mph!
zte87 is offline
post #1476 of 2401 Old 06-09-2013, 07:21 PM
CDW_327
I hear you there but this wobble wast there before I rotate and up graded the steering, I am just stumped!
Oh I see. You can try a stabilizer but I seriously doubt it will help. Sorry lol.
How did your jeep drive on the highway with those tires before the steering upgrades?
CDW_327 is offline
post #1477 of 2401 Old 06-09-2013, 07:23 PM
try2holdmywheel
Does the wobble go away as you go faster or does it get worse? Have you tried to "unrotate" your tires to test if the wobble goes away?
'69 Bronco
try2holdmywheel is offline
post #1478 of 2401 Old 06-09-2013, 07:47 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
I havet had it over 45 yet and I plan to un rotate to see if it helps its just a lot easy at work with air tools, and cdw it throw nice and smooth on the hwy before the steering which deleted the steering stab and the rotate so I am not sure which of these to things caused it!
zte87 is offline
post #1479 of 2401 Old 06-09-2013, 07:51 PM
CDW_327
I'd say change the tire back!
CDW_327 is offline
post #1480 of 2401 Old 06-09-2013, 08:03 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
I plan on it but the spool ist that nice to the rear tires haha
zte87 is offline
post #1481 of 2401 Old 06-09-2013, 08:15 PM
1preacherman
The Spool could have caused a funny wear pattern that is causing it?
I have seen such things before.
"If we lose freedom here, there is no place to escape to. This is the last stand on Earth."
Ronald Reagan
My build Thread
A proud member of the "Polite Society"; Ask me how to join!
1preacherman is offline
post #1482 of 2401 Old 06-09-2013, 08:25 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
It could of I guess.....it Doest like like it but we know how that goes!
zte87 is offline
post #1483 of 2401 Old 06-09-2013, 08:34 PM
Rubicon0311
Just burn the Jeep, then all your problems will go away!
Rubicon0311 is offline
post #1484 of 2401 Old 06-09-2013, 09:05 PM
1preacherman
Bad Idea!!!
Ronald Reagan
My build Thread
post #1485 of 2401 Old 06-09-2013, 09:44 PM
skyj
When you took the knuckles off did you check your ball joints? My guess is bad ball joints or a hub. With as big as a tire you got that's a lot of stress on those itty bitty things.
build thread:
skyj is offline
