My 93 2.5 low output build - Page 97 - JeepForum.com
post #1441 of 2401 Old 05-30-2013, 07:52 AM
skyj
Are you still running a otk setup? If you are would you mind sharing your measurements?
And curt I don't but my buddy does......
I am still running OTK I can get you measurment but I don't think it will help you, as I am running stock replacement tre's. I would seriously mock it up with pvc then cut the dom when you got it. My drag link tube without the tre's in is 25", just for reference purposes.
build thread:
skyj is offline
post #1442 of 2401 Old 06-02-2013, 08:57 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
So I started tearing down the jeep for the 1 ton steering setup. Since I had it torn down I decided to cut and grind down the track bar mount off the axle, does any one have any take on driving with out a steering stabilizer? Any ways I will be dropping the knuckles and pitman arm off in the morning!
zte87 is offline
post #1443 of 2401 Old 06-02-2013, 09:54 PM
OlivergreenCJ7
You could just get a steering stabilizer kit for a Cj. It has a built that mounts to the axle and one that mounts to the tie rod. I would imagine you'd have some vibrations with the size tire you're running and no stabilizer.
1979 CJ7: Gone,but not forgotten
2001 TJ Sport: locked and loaded
OlivergreenCJ7 is offline
post #1444 of 2401 Old 06-02-2013, 10:49 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
I was reading that they are a band aid for other problems and that you shouldn't need one.........how ever they could be wrong haha, I have never fryer to drive with out one before so I don't know what to expect!
zte87 is offline
post #1445 of 2401 Old 06-03-2013, 12:22 AM
1preacherman
A steering stabilizer is just that it keeps the steering from being as dodgy. without it those little pulls you already feel, are much bigger pulls.
Yes they are a bandaid, to a stock jeep, but your 37s should have enough sidewall flex that that bandaid would be helpfull.
"If we lose freedom here, there is no place to escape to. This is the last stand on Earth."
Ronald Reagan
My build Thread
A proud member of the "Polite Society"; Ask me how to join!
1preacherman is offline
post #1446 of 2401 Old 06-04-2013, 07:22 PM
OlivergreenCJ7
Now that I see your new avatar I'm less excited about becoming a Washingtonian House sold, moving truck the 15th and I should be in my diggs for the summer
My best attempt at being a local
post #1447 of 2401 Old 06-04-2013, 08:03 PM
try2holdmywheel
For what it's worth, and it's not much, I am not running a stabilizer. Things are just fine for me. I've never felt like it needed one. Goes down the high/freeway just fine. I'm not sure that we're comparing apples to apples though. I'm coil sprung and have a bit more wheelbase.
'69 Bronco
try2holdmywheel is offline
post #1448 of 2401 Old 06-04-2013, 08:13 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
You should fit right in haha, say once you get settled you should come help install or remove a bl.......
zte87 is offline
post #1449 of 2401 Old 06-04-2013, 08:22 PM
Rubicon0311
I'll be moving to WA next month
Rubicon0311 is offline
post #1450 of 2401 Old 06-04-2013, 08:54 PM
OlivergreenCJ7
Will do, we could take your bl out and put it in my jeep I need one
post #1451 of 2401 Old 06-04-2013, 08:55 PM
OlivergreenCJ7
Lol, we're overtaking the state.
post #1452 of 2401 Old 06-04-2013, 09:17 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
It will be nice to having a few more fellow Jf wheelers close by!
zte87 is offline
post #1453 of 2401 Old 06-04-2013, 09:53 PM
Rubicon0311
I'm being serious
post #1454 of 2401 Old 06-04-2013, 09:59 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
I'm being serious
What area?
zte87 is offline
post #1455 of 2401 Old 06-04-2013, 10:10 PM
Rubicon0311
Everett
