My 93 2.5 low output build - Page 7 - JeepForum.com
post #91 of 2401 Old 12-15-2011, 10:31 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
I have't been over 45 mph with it so i can't really say yet but at 45 mph is a nice quite and warm ride! But so far I am loveing it.
zte87 is offline
post #92 of 2401 Old 12-15-2011, 10:47 PM
ashland82391
one more question. where did you get it and how much?
ashland82391 is offline
post #93 of 2401 Old 12-15-2011, 10:53 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
I got it from softtopper.com and since I went with the dark tint windows the total was a round 570 to my door'
zte87 is offline
post #94 of 2401 Old 12-15-2011, 11:48 PM
91BoD
Correct zte87
GL-5 gear oil has oodles of E.P. (extreme pressure) additives. These additives are corrosive to soft metals such as brass, bronze, and some aluminum. Causing your oil to literally eat your syncros.
GL-5 contains the most E.P. additives followed by GL-4 with 30-50% less and then GL-3 with 25-40% less then GL-4.
Your best bet is to use factory specified GL-3 gear oil - weight is not very significant. Use lighter in colder weather heavier in hotter weather if you are picky about it.
Or 30 weight motor oil - The E.P. quantities vary GREATLY, best to stick cheap, less chance of additives.
Or Manual transmission specific oil such as Penzoil syncromesh or Redline MTL - They are rated at the lower end of GL-4 for E.P. and most have friction modifiers that produce the correct coefficients of friction for syncros.
I hope this was helpful
Edit: Some definitions
API Category GL-3 designates the type of service characteristic for manual transmissions and spiral-bevel axles operating under mild to moderate to severe conditions of speed and load. These service conditions require a lubricant having load-carrying capacities greater than those that will satisfy APL GL-1 service, but below the requirements of lubricants satisfying the API GL-4 service.
API Category GL-4 designates the type of service characteristic for spiral-bevel and hypoid gears in automotive axles operated under moderate speeds and loads. These oils may be used in selected manual transmission and transaxle applications.
API Category GL-5 designates the type of service characteristic of gears, particularly hypoids in automotive axles under high-speed and/or low-speed, high-torque conditions.
91BoD is offline
post #95 of 2401 Old 12-16-2011, 03:13 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
So today I installed some led tail lights and man was it a pain...it took me for ever to figure out why everything was working but my blinkers! Turned out it was my relay so I just swap the blinker and hazard really and all was good! Over all I am real happy with how it turned out.
image-3388164596.jpg   image-3688633168.jpg   image-2301939304.jpg   image-3900581172.jpg   image-1579648639.jpg
zte87 is offline
post #96 of 2401 Old 12-16-2011, 03:16 PM
SnowYJ
1988 MJ Comanche
are you on turdy fives now?
I go to college and I drive a Jeep.
SnowYJ is offline
post #97 of 2401 Old 12-16-2011, 04:08 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
No just 33 mtr!
zte87 is offline
post #98 of 2401 Old 12-17-2011, 01:00 AM
SnowYJ
1988 MJ Comanche
Nice! Im swapping to some 33 inch mtrs tomorrow haha
SnowYJ is offline
post #99 of 2401 Old 12-19-2011, 08:55 PM
ziloh22
sweet build
2012- Gecko JK Rubicon Unlimited- building...
2007 JK Rubicon Unlimited- 3.5 RK X Factor 37s-SOLD
1995 Gecko YJ with a TJ Front- 35s
ziloh22 is offline
post #100 of 2401 Old 12-20-2011, 01:03 AM
karlo
Great job. The led tail lights looks cool.
karlo is offline
post #101 of 2401 Old 12-21-2011, 10:18 PM
ashland82391
How do you plan to light up your license plate or do you not do any night driving?
post #102 of 2401 Old 12-22-2011, 06:36 AM
HurricaneRZA
they have LED license plate bolts... works like a reg bolt but lights up the license quite nicely too
Originally Posted by YoureverydayXJ View Post
This is the most metal thing I have ever heard.
Originally Posted by doublins View Post
I always get people coming over and saying things like "I wish I knew how to do that," etc- but they don't realize- at some point I didn't know how to do it either- I had to figure it out.
HurricaneRZA is offline
post #103 of 2401 Old 12-22-2011, 08:26 AM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
Yeah I planed on getting some bolt lights....they are only 10 dollars before shipping on amazon! Yesterday I picked up some 2.5 clear flush mount lights to mount next to the tail lights, I don't think they will really help me see when backing up but will At least let people know when I am.
zte87 is offline
post #104 of 2401 Old 12-23-2011, 09:10 AM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
So today I ordered the light bolts for the license plate as well as some new hood hinges.....mine are worn out and rattling bad!
zte87 is offline
post #105 of 2401 Old 12-27-2011, 06:39 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
I got my light bolts today for the plate what do you think of the out come?
zte87 is offline
