My 93 2.5 low output build - Page 56 - JeepForum.com
post #826 of 2401 Old 02-18-2013, 06:54 PM
ashland82391
Well sorrrrrrrrry! I don't live on this site!
Lol I work third shift with amazing wifi and I'm at school during the day with good wifi, nothing better to do lol
ashland82391 is offline
post #827 of 2401 Old 02-18-2013, 08:52 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
Originally Posted by Rubicon0311
Have you ordered your Metalcloak **** yet??
I sure did cant wait for the armor to show up!
zte87 is offline
post #828 of 2401 Old 02-18-2013, 08:54 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
I got my new beefier/longer/serviceable woody shaft and installed it! That is all!
image-2094299965.jpg   image-2745992555.jpg   image-833002535.jpg   image-1188456138.jpg
zte87 is offline
post #829 of 2401 Old 02-19-2013, 06:30 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
I got the Yukon ultimate 8.8 kit installed to day and I must say I am digging the new rear track width I gained from it! . On a side note I decided to check the ring gear bolts and every one of them was hand tight I got them all torqued down to spec along with the bearing caps glad I caught that now before I toasted toasted a r&p. can't complane tho since I didn't pay my buddy that set them up! On a side note I bought to new unit bearing to go with the new front shaft that way my trail spares have there on set of bearings on them which will make changing them a piece of cake on the trail! I plan on ordering axle tube seals for up front tonight!
image-1524070766.jpg   image-4204371718.jpg   image-4039890362.jpg   image-824884927.jpg   image-1620749681.jpg
zte87 is offline
post #830 of 2401 Old 02-19-2013, 06:37 PM
Rubicon0311
I think you should leave the Jeep the way it sits. Just go wheel the crap out of it.
Rubicon0311 is offline
post #831 of 2401 Old 02-19-2013, 06:43 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
No thanks lol Ii would to at least have my 35s back on before I hit the dirt lol! Does 3.5 lift and 35s count as a lcog build?
zte87 is offline
post #832 of 2401 Old 02-19-2013, 06:46 PM
CDW_327
Looks good! How did you gain track width? Are those shafts longer?
CDW_327 is offline
post #833 of 2401 Old 02-19-2013, 06:51 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
The c-clip eliminators add 1 inch per side according to there web site! It a pretty noticeable difference none the less!
zte87 is offline
post #834 of 2401 Old 02-19-2013, 07:02 PM
Rubicon0311
I'll accept it
post #835 of 2401 Old 02-19-2013, 07:22 PM
CDW_327
LCG is a dumb term. It's better to go off the hight of the top windshield frame rather then lift hight. I you can have the lowest overall hight measured from the highest point of the jeep (aka top of the windshield frame) on the biggest tire possible you should have a good CG.
CDW_327 is offline
post #836 of 2401 Old 02-19-2013, 07:33 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
So confused......I thought the whole lcog was about stuffing the largest tire possible with the lowest amount of lift possible?
zte87 is offline
post #837 of 2401 Old 02-19-2013, 07:41 PM
Rubicon0311
Technically....yes. You are keeping the Jeep closer to the ground. That means keeping the weight down there as well. Most true LCG run full width axles so they can run bigger tires while keeping the weight closer to the ground.
post #838 of 2401 Old 02-19-2013, 07:43 PM
Rubicon0311
I could go into the physics and math of everything, but thats too much to worry about with a couple beers in my system. Full widths give you a wider stance, reducing the risk of tipping.
post #839 of 2401 Old 02-19-2013, 08:42 PM
CDW_327
I was just saying you don't have to limit yourself to the common 3" of lift to have a good stable LCG rig. If you have a decent track width, wheelbase and good weight down low you should have a very stable rig.
Anyway, your rig should be very stable with 3.5" of lift and the track width you have now. I just wouldn't worry to much about the term LCG...
CDW_327 is offline
post #840 of 2401 Old 02-20-2013, 08:15 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
I am thinking side hilling should be a lot easier now any ways! So I sold my old 35s today so I order my front seats/and rear seat cover a long with some 303 aerospace spray (uv protector) ! I also have alloy USA axle tubes seals on the way now for the front! On a side note my revolvers should be here tomorrow!
zte87 is offline
