My 93 2.5 low output build - Page 116 - JeepForum.com
post #1726 of 2401 Old 08-26-2013, 12:28 AM
Dake
Dake's Avatar
I think I may upgrade it to the ubolt style if I replace it tho, thoughts on this?
I did this. I just drilled the threaded holes and used the Ford ubolt style from the help section at Oreilys.
Waiting on my Rough Country lift to sag!
Dake is offline
post #1727 of 2401 Old 08-26-2013, 01:42 AM
AZdEvilYJ
Post deleted
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
AZdEvilYJ is online now
post #1728 of 2401 Old 08-26-2013, 07:12 AM
WidowYj91
I'm upgraded my rear a while back, no more problems!
WidowYj91 is offline
post #1729 of 2401 Old 08-27-2013, 12:21 AM
ashland82391
Would u joints that are loose in the clips cause vibrations?
ashland82391 is offline
post #1730 of 2401 Old 08-27-2013, 01:58 AM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
Yes sir they would!
zte87 is offline
post #1731 of 2401 Old 08-27-2013, 02:52 AM
ashland82391
Yes sir they would!
Hmmmm, maybe that's why I still have vibes from my front shaft. Can I put ubolt straps on the yoke on the transfer case side?
post #1732 of 2401 Old 08-27-2013, 07:37 AM
WidowYj91
Yea I'm pretty sure you can.
post #1733 of 2401 Old 09-01-2013, 01:27 AM
Specter1911
Not sure if I over looked it but what did you use to paint your hinges and grill?
Specter1911 is offline
post #1734 of 2401 Old 09-01-2013, 09:21 AM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
My hinges where painted with just black satin spray paint, the grill was rattle can bed liner!
zte87 is offline
post #1735 of 2401 Old 09-02-2013, 08:46 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
To her out on the bds maiden voyage and was very impressed with out the springs handle. They yield a very comfy ride and seem to flex great!
zte87 is offline
post #1736 of 2401 Old 09-03-2013, 01:55 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
So this won't happen till march but I planning on buying a loaded g2 44. It will come with 5.13 gears/arb locker with 30 spline chromo shafts, on the down side the axle reuses the Dana 30 knuckles and bearing but oh well. At the same time I will be buying a arb and matching gear set for my 8.8 along with a arb compressor and if the funds allow a Tera 4.1 case. Any way I just felt like sharing some near future plans for my jeep that is all!
zte87 is offline
post #1737 of 2401 Old 09-03-2013, 02:00 PM
Schaef81
I've come to realize that buying a loaded axle like you plan on is more times then not more cost efficient then building one. And better yet you can drop it right in
BDS - Spartan - AtoZ Fabrication - Borgeson HD - USA Standard - BFGoodrich
Schaef81 is offline
post #1738 of 2401 Old 09-03-2013, 02:25 PM
try2holdmywheel
Why not just go with a D60 in preparation for an LS and be done with it.
'69 Bronco
try2holdmywheel is offline
post #1739 of 2401 Old 09-03-2013, 03:19 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
Because I think I am sticking with 37s and a 44/8.8 should hold up fine with ls.......
zte87 is offline
post #1740 of 2401 Old 09-03-2013, 03:40 PM
abc_was_here
Can you go any deeper gear than 5.13? Might be something to consider.your jeeps taking another huge step!
1995 Jeep YJ 4.0L swap, locked up 4.88s D30 8.8, 35s
1992 Jeep XJ 4.0L 5 speed 3.73, 33" boggers
abc_was_here is offline
