My 92 YJ Build - Page 41 - JeepForum.com
 5Likes
post #601 of 610 Old 05-31-2017, 04:49 AM Thread Starter
trailrider787
Side shot of rear axles. Welded in some 2" bump stop cans with some aluminum bump cans from synergy. I'll have to measure after flexing it out for the bump pads on the axle side. Also got the shocks and driveshaft mounted up. I was able to do away with the shock relocation brackets from MORE off-road due to the rear being stretched. I also used an 1310/1350 u-joint to mate my DS to the 60 yoke. Eventually I'm sure I'll have my DS's rebuilt with all 1350's, probably when I do my teralow conversion on the tcase
trailrider787 is offline
post #602 of 610 Old 05-31-2017, 04:59 AM Thread Starter
trailrider787
Started on the front 44. Mocked everything up and tacked on the perches. Removed it and welded up the perches and shock mounts. I ended up re using the cutoff driver sway bar mount and welding it on. I used the existing track bar mount and drilled a hole for the passenger side away bar mount. I left the sway bar mount for a spot to mount the ram assist. Got her painted and ready for install.
post #603 of 610 Old 06-01-2017, 07:12 PM Thread Starter
trailrider787
Here is the front bolted up with new ball joints and Reid racing knuckles. Glad I went with these as the stock JK knuckles would have had the tie rod going though the springs.
post #604 of 610 Old 06-01-2017, 07:17 PM Thread Starter
trailrider787
Here is a shot with the lockout hubs, shafts, and breaks installed. I used the old driver sway bar mount, ground it down and welded it up to match the location of the passenger sway bar mounting to the track bar bracket. I won't be using a track bar obviously, but the mount will be perfect for mounting the fixed end of the ram. Modified the drag link with a synergy JK adjustable end, better pics to come. Also ordered a new hose kit for then new ram assist as my hoses were not long enough.
post #605 of 610 Old 06-01-2017, 07:26 PM Thread Starter
trailrider787
Back on four wheels temporarily again. Just a few items to cover. While I was waiting on the new ram assist hose kit, I mocked and welded up the fixed end side to the track bar bracket. I had to grind down the Reid racing knuckle stops as with them stock the steering throw was 6". A stock JK has 6.75" lock to lock, as was the new ram assist, so I ground them down to where I had 3.5" either direction so 7" lock to lock. PSC says that the ram assist should be the limiting factor and not the stops, or it could damage the axle and then possibly rip off the outer knuckles.
post #606 of 610 Old 06-01-2017, 07:29 PM Thread Starter
trailrider787
Here is my to-do list. I've broken into days hoping it may encourage me to work some in the evenings after work. Not working so well with the wife and kid though.
Day 5
- setup ram assist
- tighten and grease steering
- paint drag link
Day 6
- replace front DS U Joint
- replace rear wheel studs
Day 7
- hook up brakes
- fill front pumpkin
- check rear pumpkin
- install new axle vent tubes
Day 8
- trim out rear wheel wells
Day 9
- run air lines to axles
Test Drive
- grease everything
- retighten u bolts
- measure for bump stop pads
Day 10
- fab up bump pads
post #607 of 610 Old 06-19-2017, 04:36 AM Thread Starter
trailrider787
Got a few things done this Father's Day weekend. The night plan hasn't worked out so well. Got the front end all done minus the DS and hooking up the brakes. Also got the rear wheel studs replaced. Keeping my updated to do list here.
YJ To Do List
Day 6
- remove engine skid plate
Day 7
- hook up brakes
Day 8
- trim rear spring perches and retighten u bolts
Day 9
Test Drive
- retighten u bolts
Day 10
- fab up bump pads
Day 11
- install teralow kit
post #608 of 610 Old 06-19-2017, 05:51 AM
Louie4
Is this the Tera Low kit you've had forever?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #609 of 610 Old 06-19-2017, 01:54 PM
Toyojay
1979 CJ5
VERY nice!! Have read thru all of it! You pulled the factory axles from the JK to build them?
What's going in the JK?
1979 Jeep CJ5
Being un****ed by PO!
4.2 3SPD
Toyojay is offline
post #610 of 610 Old 06-19-2017, 05:34 PM Thread Starter
trailrider787
Unfortunately yes...just no time, and never got around to it. Just need to pull the dang trigger and do it. It will probably sit on the list for longer cause I'm going to want to drive it soon once I get the other stuff in order. Plus I want to see what the 4.88's will be like before the change to a 4-1 TC.
