My 92 YJ Build - Page 3 - JeepForum.com
 5Likes
post #31 of 618 Old 05-30-2012, 05:02 PM Thread Starter
trailrider787
spring perches and shock tabs, very ugly welds, but nothing has broken so far. i've gotten better since. plan on using the pre drilled holes in the perches to move the axle back 1" later
trailrider787 is offline
post #32 of 618 Old 05-30-2012, 05:05 PM Thread Starter
trailrider787
homemade dynatrac flip kit, ended up not using the bottom plates for now. will eventually make do something different
post #33 of 618 Old 05-30-2012, 05:07 PM Thread Starter
trailrider787
axle mostly complete and painted, ready to bolt in
post #34 of 618 Old 05-30-2012, 05:08 PM Thread Starter
trailrider787
change of pace, frame tie in complete
post #35 of 618 Old 05-30-2012, 05:10 PM Thread Starter
trailrider787
smittybilt rear tube fenders did not come with very good hardware. bolts were to small and were pulling through the pre-drilled holes. i swapped out for some larger ones from home depot with nice big washers. had to drill out holes in fenders.
post #36 of 618 Old 05-30-2012, 07:11 PM Thread Starter
trailrider787
re-route my exhaust. ordered a tj front downpipe, and had to weld in an autozone piece of pipe to my four bolt flange and the new tj pipe. worked out really good.
preparing for motor and tranny skid plate. don't know if you can see it, but my oil pan is concave from a nice ole rock.
post #37 of 618 Old 05-30-2012, 07:15 PM Thread Starter
trailrider787
first go at the skid row usa motor skid plate. two bolt holes in the teraflex skid plate, and the other front support mounts to the bottom of the motor mount.
wasn't convinced on strength and design. tested by jacking up vehicle from middle of skid. also so far, rocks have taken some paint, but didn't bend anything
post #38 of 618 Old 05-30-2012, 07:22 PM Thread Starter
trailrider787
bought some smittybilt seats, the original ones were trash. i also wanted to go ahead with some harnesses for my girl, and get rid of the frayed originals.
i didn't want to spend the money on some corb's cause i didn't have it at the time. i had to remove the sliding rails to make them fit, because they were sitting to tall.
had to test fit the seats multiple times to get my driver line up right for me. came out really good. i really like the harness, very easy to latch and un-latch. seats
have proved very comfortable and durable so far. my console is rubbing them bad, so i'm going to do something different there. maybe build a custom one. girl
feels much safer when wheeling and doesn't mind getting a little sideways or three wheeling.
post #39 of 618 Old 05-30-2012, 07:26 PM Thread Starter
trailrider787
motor skid plate to wide, bent my driveshaft while in alabama wheeling at morris mountain. flex combined with skid plate equals bent driveshaft. now i have to modify skid
and get new driveshaft, tom woods time
post #40 of 618 Old 05-30-2012, 07:31 PM Thread Starter
trailrider787
cut out 1.5" out of side of skid plate. put gussets around previously notched hole i cut for the passenger front leaf spring bolt. filleted the plates on both edges
and welded both sides.
post #41 of 618 Old 05-30-2012, 07:33 PM Thread Starter
trailrider787
painted and installed, notice clearance. so far haven't had any rub, but haven't flexed it out completely yet. notice new driveshaft, tom woods. 2" od
post #42 of 618 Old 05-30-2012, 07:35 PM Thread Starter
trailrider787
tom woods driveshaft pictures, very excited, excellent service
post #43 of 618 Old 05-30-2012, 07:38 PM Thread Starter
trailrider787
decided to copy Louie4's idea with the spring plates. $50 later and i have enough to make all four. 3/16" angle, 1/4" plate, and 3/16" single for gussets.
post #44 of 618 Old 05-30-2012, 07:40 PM Thread Starter
trailrider787
first one, almost done. need holes and gussets. first was after weld, and then cleaned up and grinded down. will be better than homemade ubolt flip kit.
post #45 of 618 Old 05-30-2012, 08:54 PM
Louie4
Very nice. When are you going to install those spring plates? Did you paint them yet?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
