My 92 YJ Build - Page 2 - JeepForum.com
post #16 of 557 Old 04-29-2012, 09:50 PM
abc_was_here
Im liking your build man!
1995 Jeep YJ Lifted 5in, Locked Front/Rear 4.88s, Ford 8.8 swap, OBA, 19lbs injectors, 4.0 TB, 35x12.5 Goodyear MTRs, 4 cylinders of fury
My YJ build thread: http://www.jeepforum.com/forum/f22/abcs-yj-build-1296743/
abc_was_here is offline
post #17 of 557 Old 04-30-2012, 12:42 AM
jclauson
Can we get some more info on that cage?? I like
1990 YJ w/ lots of home made sh*t
check it out
http://www.jeepforum.com/forum/f22/hysterias-90-yj-build-1190617/
jclauson is offline
post #18 of 557 Old 05-05-2012, 07:05 AM Thread Starter
trailrider787
It's the rockhard 4x4 cage. It comes in sections or basically separate pieces. Came bare so I had to paint. I got the tub and frame tie in, but they make it to where you can build it like you want. I liked the clamps cause I could do it myself. Didn't know how to weld at the time. My busy bought a gen right cage and he paid a grand more than I did cause he had to have it welded and painted. I like my option for the time being.
trailrider787 is offline
post #19 of 557 Old 05-06-2012, 08:10 PM
Louie4
Rickety Wrecked Son!
Louie4's Avatar
Steven, I can't believe you didn't tell me about your build thread earlier...you d*uche.
It is better than all those text. The only thing is those pics are humongous...fix it. BTW, when are you going to post pics of the new sleeves and gussets?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline
post #20 of 557 Old 05-14-2012, 05:27 AM Thread Starter
trailrider787
Yeah sorry, haven't gotten the pictures figured put yet. The phone takes big ones. Still need to get everything up to date. Should be soon.
post #21 of 557 Old 05-30-2012, 04:30 PM Thread Starter
trailrider787
thanks, still working to get everything up to date
post #22 of 557 Old 05-30-2012, 04:37 PM Thread Starter
trailrider787
Here are some pics after the 1" daystar BL and the teraflex tummy tuck. very pleased with this so far while wheeling. taken some good hits and hasn't bent yet. 1/4" thick works better than that stock piece of crap.
post #23 of 557 Old 05-30-2012, 04:38 PM Thread Starter
trailrider787
I also did a 1" motor mount lift to make the tummy tuck work.
post #24 of 557 Old 05-30-2012, 04:43 PM Thread Starter
trailrider787
here are some pics of the rock hard 4x4 roll cage after i received them. before i painted them. sorry my thread is going to be a little out of order until i get up to date.
post #25 of 557 Old 05-30-2012, 04:45 PM Thread Starter
trailrider787
here are two pieces after painted.
post #26 of 557 Old 05-30-2012, 04:47 PM Thread Starter
trailrider787
1" extended bump stops. neither the front or the rear hit right now after install, but i plan on welding some stops on axles at some point.
post #27 of 557 Old 05-30-2012, 04:49 PM Thread Starter
trailrider787
M.O.R.E. rear shock relocation brackets, because i plan to make use of my existing rubicon express shocks, while also raising the shock tabs on the 8.8 for clearance.
post #28 of 557 Old 05-30-2012, 04:53 PM Thread Starter
trailrider787
ford 8.8 with brakes off and shafts pulled. brackets to haven't been cut off yet.
post #29 of 557 Old 05-30-2012, 04:55 PM Thread Starter
trailrider787
notice the bottom of the pumpkin where i made a cheap skid plate with some metal i had laying around. second stab at welding after welding the tubes to the pumpkin.
i did this because i saw my buddy lou's hang up multiple times on rocks and stop him in his tracks. it's worked well so far.
post #30 of 557 Old 05-30-2012, 04:58 PM Thread Starter
trailrider787
dad's hobart. I like borrowing tools he hasn't ever used.
