My 92 YJ Build - Page 18 - JeepForum.com
 5Likes
post #256 of 598 Old 06-11-2013, 09:12 AM
'92 vegas YJ
Originally Posted by trailrider787 View Post
Anyone messed with a transfer case mounted parking brake?
So i know i'm getting ahead of myself, but i've noticed that while parked in the driveway yesterday, my jeep wanted to roll while in gear. i of course put a chock behind one of the wheels. I removed my parking brakes from the 8.8 after i destroyed the driver side due to a stud that had un-screwed itself a while back
I was looking at the parts mike version that is made for the np231 with advanced adapters slip yoke. this would work well with my plan later on to either upgrade to the atlas 2speed or the teralow kit. i think this may get bumped to the top of the list for the next upgrade since i hate having to chock the wheels everytime i park on a hill.
Im interested in this as well. I've been researching it a little. It seems every kit out there is so expensive. I've though about trying to make one
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is offline
post #257 of 598 Old 06-11-2013, 10:30 AM Thread Starter
trailrider787
Yeah the ones on parts mike is 350 which is high. I know tom woods sells their own version and parts mike as well but dont list the prices. keep me posted on what you find. Making one would be sweet, but mounting to the yoke would be the tricky part. I wonder what the biggest fourwheeler disk you can get is that is cable actuated. I'm going to keep researching as well, maybe someone has a good makeshift one.
trailrider787 is offline
post #258 of 598 Old 06-12-2013, 06:31 PM
Louie4
Ask NHfireYJ about his. He recently installed one. See post # 67:
http://www.jeepforum.com/forum/f12/a...35/index5.html
By the way, my jeep is rolling more often. I have it in gear and the 8.8 parking brake on (which sucks). I will tighten the parking brake but I do need something better.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #259 of 598 Old 06-23-2013, 06:11 PM Thread Starter
trailrider787
Update. Got everything re-wired including spot lights, ARB compressor, and the rear locker. Also wires up the front locker as well. Took it for a test run and everything worked well. Have some slight vibrations going on, but don't know what it is yet. Going to get the wheels re balanced cause they need it.
Also found a place to flex it out and measure for modifying the frame where the drag link will hit on the passenger side and also measured for moving the bump stops forward. Went ahead and cut the frame out. Going to use some quarter inch plate or 3/16" plate to gusset everything.
post #260 of 598 Old 06-23-2013, 06:16 PM
Louie4
Wow. You just dove right in on that. I'm curious to see how the plating goes.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #261 of 598 Old 06-23-2013, 06:38 PM Thread Starter
trailrider787
Yeah, I knew I was going to have to do it when I did the steering. I wish I had my old front springs on cause I would have been able to get better measurements. But this will have to do. I plan to plate the inside and outside of the frame, and then weld in some plate on the underside to fill it all in. I believe it will be stout enough. The new front springs are stiff as crap, I can't wait for them to sag a little bit, it will cushion up the ride.
post #262 of 598 Old 06-23-2013, 06:42 PM
Louie4
Mos def. Any chance you can plate the top of the frame too? I know it would be more work with removing the fender but it may be a good idea.
Just a thought though.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #263 of 598 Old 06-23-2013, 06:50 PM Thread Starter
trailrider787
I think I may be able to get to it without removing the fender. It's a good idea and I didn't think about doing it, but I will probably do it now. Good idea!!
post #264 of 598 Old 06-24-2013, 05:07 PM
Louie4
It's obvious that I calculated the bending moment on the frame based on the yield strength of the steel, cross-section, and applied forces...duh.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #265 of 598 Old 06-24-2013, 05:27 PM Thread Starter
trailrider787
Wow you are lame, but dr Thompson would be proud!
post #266 of 598 Old 06-24-2013, 06:24 PM
Louie4
Ole' Sid Vicious would be.
By the way, we'll be at Brewfest this weekend while y'all are lounging on the beach in Destin.
Hey, when are we going to Tybee?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #267 of 598 Old 06-24-2013, 06:45 PM Thread Starter
trailrider787
Sweet! Whenever you want to go. Although, I really could care less about dealing with my sister.
post #268 of 598 Old 06-24-2013, 07:24 PM
Louie4
Oh yeah, I forgot her and Dave were down there.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #269 of 598 Old 06-25-2013, 05:56 PM Thread Starter
trailrider787
So I started on boxing in the frame where I cut out a section to clear the drag link. I had some left over 1/4" plate so I'm using that up first. My plan is to make two half sections and then weld them each to the frame that will end up boxing it in. For some reason the pictures won't load so I'll keep trying. Got both half sections made but need to finalize everything up and weld it to the frame.
post #270 of 598 Old 06-25-2013, 06:58 PM
Louie4
Keep trying to load them. I want to see how it turned out.
Edit: Nevermind. You'll need to wait till Thursday.
http://www.jeepforum.com/forum/f6/an...e-weekend.html
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
