My 92 YJ Build - Page 13 - JeepForum.com
 4Likes
post #181 of 583 Old 01-22-2013, 08:06 PM
Slim93
Nice work man,I couldn't stop reading.
You're making me fell like a lazy ***.
Slim93 is offline
post #182 of 583 Old 01-23-2013, 06:17 AM Thread Starter
trailrider787
Thanks man, I still get lazy from time to time also. Welcome to the forum as well.
trailrider787 is offline
post #183 of 583 Old 01-23-2013, 07:32 AM
90consuela
I'm an aspiring welder myself...just got a little lincoln mig. It doesn't matter how much "how-to" you watch. You just have to practice! Awesome build!!!
90consuela is offline
post #184 of 583 Old 01-23-2013, 07:38 AM
Louie4
How many self locking nuts do you have from the kit? I know a few of them thread into the box itself.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #185 of 583 Old 01-23-2013, 07:44 AM Thread Starter
trailrider787
Yeah, practice is the key. I've been fortunate that alot of the projects I've done so far include a little here and there, so it keeps me practicing. Thanks And hope to see some of your projects with the Lincoln.
post #186 of 583 Old 01-23-2013, 07:49 AM Thread Starter
trailrider787
It came with one that is actually for a small bolt made for the anti sway bar bracket. The other two were not part of the bracket unfortunately. The top two long bolts are the ones I need them for. The bottom 4 re use the threads in the frame and the threads in the box. I'll pick some up at Home Depot or ace and be done with it. I poured all the stuff out of the bag on my work bench, so I'm positive I didn't misplace them. May take half a day off Thursday or Friday to work on it. Getting ancy with it being in pieces and multiple projects going at one time.
post #187 of 583 Old 01-27-2013, 07:28 PM Thread Starter
trailrider787
Got the lock nuts from ace hardware and finished up mounting the new MORE steering relocation bracket. Still can't get the steering shaft to meet up with the box so it either needs to be extended or a new one is needed.
Also got the shackles and new springs put back on. The new hangers and the boom shackles actually should work better in not letting my springs invert again. Slow progress but its coming along.
Next is to start setting up spring perches, shock mounts, and sway bar brackets on the new xj d30.
post #188 of 583 Old 01-29-2013, 07:31 PM Thread Starter
trailrider787
Got everything measured for the spring perches. Tacked them in to place. Shock mounts should be tricky though with the lower c gusset. Haven't decided what I'm going to do with them yet.
post #189 of 583 Old 01-29-2013, 07:38 PM Thread Starter
trailrider787
Close up of the driver side perch. And also the bottom plate for the dynatrac u bolt flip. Drilled new holes to go with moving the axle forward one inch.
post #190 of 583 Old 01-29-2013, 08:44 PM
Louie4
Looking good. Take a piece of cardboard and make a little cut out to fit the contour of the tube and gusset. Then transpose that to the shock mounts and weld them on.
What do your mounts look like anyway?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #191 of 583 Old 01-30-2013, 03:35 PM Thread Starter
trailrider787
I'll get a picture of them, I have two kinds. Good idea on the cardboard. I'll have to try that. I thought about just welding them up higher to avoid all the angles. Id have to relocate my uppers, install new ones I mean, and probably still get new shocks also. But don't need to spend more money right now, so I'll try the cardboard.
post #192 of 583 Old 03-02-2013, 08:35 AM Thread Starter
trailrider787
Ok so I've finally had some time to get back at it. This morning I've installed the rock lock sway bar. I had to modify the plastic bushings that insert into the cross brace on the frame, but it fits good. Next step is to weld on shock mounts to axle and finishing welding the spring perches. I'll have to place the axle under the jeep before I can fabricate some tabs for the sway bar to attach to.
post #193 of 583 Old 03-02-2013, 12:18 PM Thread Starter
trailrider787
More progress, so I got my shock mounts modified and welded on. I also finished welding the spring perches. After that I got the axle under the jeep, and fabricated some sway bar mounts. Welded them up good and removed the axle back out from under the jeep. So next thing is to paint the axle and diff cover and fill it with fluid, and bolt it in. From there it should be simple to install new shafts, new hubs, brakes, etc.
image-3829564527.jpg   image-1860217548.jpg   image-694704536.jpg   image-676723197.jpg   image-667968675.jpg
post #194 of 583 Old 03-02-2013, 12:21 PM Thread Starter
trailrider787
Forgot to mention that I may be buying new front shocks. Because I made it easy on myself when welding up the shook mounts, I lost 3 inches of length. So my thoughts are to buy the MORE offroad hoop extensions, and either modify my shocks at the top or buy new ones that have the top eye instead of a stud. I should fave up my own hoops like many on here, but I don't have a tube bender, so if anyone has any ideas let me know?
post #195 of 583 Old 03-02-2013, 07:55 PM
'92 vegas YJ
Im a big fan of the WFO hoops. I run them. They're pure BEEF and are also cheaper than the MORE's.
http://www.wfoconcepts.com/pr/13-Tal...3203/3458/3713
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is online now
