#1 | |
My 79 CJ5 Rebuild
I decided I wanted to rebuild an old car and what better than a CJ5. I posted this thread so my self and others can see the progress I will be making over the next couple of months. I am interested in hearing everyone’s comments and suggestions and hopefully you guys will be able to help me with any problems I will run into on the way.
O.K. here are the specs: 1979 CJ5 AMC 258 4.2L Straight 6 T150 3 Speed Tranny Dana 30 Front Axel AMC 20 Rear Axel (Boo) Dana 20 Transfer Case 35X12.50 BFG All Terrains 4 Inch Skyjacker Suspension lift Everything is in OK working order. Oil leak from every where possible, other than that motor very strong. Syncros shot in tranny. Tub and frame very badly rusted. Interior was trashed. And so my project begins. Just bought a 1979 cj5 to rebuild. Everything was in good working order, had a couple real bad oil leaks and a lot of rust tub and frame. Pictures to Follow.
It has 1,453,580 miles on 5 engines. Its been in 132 of the worlds 195 countries. VEX will be missed. 1989 YJ 2000 TJ 1979 CJ5 1979 CJ7 |
#2 |
Hey man,
Im looking forward to seeing your build and seeing some pics Good luck!
[B]My Build Thread: [url]http://www.jeepforum.com/forum/showthread.php?t=587503[/url][/B] [SIZE="2"][B][COLOR="Orange"]'98 TJ 4.0L, AX-15 5spd, NP231, RE 4.5 rear, 3"&.75" BB front, JKS discos, 33x12.50 KM2s on Rock Crawlers, 3.73s, Dana30 front, Dana 44 rear, JB Conversions SS SYE, JKS HD Tierod, Warn 8274 Winch, Front Stinger and Rear stinger w/ tire carrier, Rokmen Corners, Aluminum Radiator, LED tailights, Rock Lights, KCs, K&N airfilter, Optima Redtop, Cobra CB and a Sony soundbar[/COLOR][/B][/SIZE] |
#3 |
Before Pics
![]() ![]() ![]() My New CJ 2 TJs and YJ ![]()
#4 |
Fenders and Grill Removed.
![]() ![]() Motor as it sat. ![]() Inside ripped out ![]()
#5 |
Tub off ready to pull the drive train.
![]() ![]() ![]() ![]() Thats it for today. Check back later.....
#6 |
Good looki'n Jeep, doesn't look like you'll have too much restoration to deal with.
DON'T READ THIS! |
#7 |
Frames pretty rotted by the rear shackles. Gonna have to come up with some kind of nifty brace to weld.
#8 |
Good looking CJ. Subscribed! Looking foward to more updates/progress
1994 Jeep Wrangler YJ S 2.5L - Mostly Stock 2004 Dodge Durango Hemi - Not stock by any means |
#9 |
Sorry I havent Posted anything recently I havent had time to work on my jeep. My wife and I just had our first baby. 8.8 lb baby boy. I should be back up and runnin this week sometime
Thanks Joe
#10 |
Good looking cj. And congrats to the new addition to your family, the baby boy I am talking about.
Ron US Navy 1993-'97 |
#11 |
Cant wait to see how this turns out. Congrats on the new baby boy.
2004 TJ Wrangler 4.0 2000 Cherokee 4.0 1994 Grand Cherokee 4.0
#12 |
Ok last Sunday I removed the tranny and transfer case which both needed to be rebuilt.
Tranny pulled I was not able to work work on the jeep all week due to my baby being born so I just got back in to the garage today and this is what i discovered. My buddy must have gotten bored while I was taken care of the family because this is all the stuff he did while I was away. Tranny Before My buddy cleaning up the bell housing Tranny rebuilt. New syncros and 1st and 2nd gear. He also found time to polish up the old side steps he is really proud of this Before After He also took a whiz wheel with a wire brush and went over the entire frame to get all the surface rust off. That is where we stand now. Time to fix some of the wholes in the frame. Frame after wire brushing More to come
#13 |
Hopefully when I started my lift I have friends like yours around. He did agood cleaning and repainting that tranny as well as the side steps. Must of have been your baby shower gift.
#14 |
He loves jeeps as much as I do it probally hurt him to just see it sit there for a week with no progress. Im sure ill see a bill from him for a case of beer or two.
#15 |
Ok got a few things done yesterday. Fixed a hole in the frame by the drives side rear shackle.
Before: Welding new metal in: Ran out of argon in the middle of weld so I just have to grind it down some a put a nice weld across: All of the body mounts were real week and rotting away so I had to cut them out so I can weld new plates in Before: Buddy of mine cutting old plates out Frame with body mounts cut out Now all I have to do is get the new metal cut and drill holes in so I can weld back to frame. I also pulled the cover on both the front a rear gears inspected them and put back togehter. Painted also. Parts for the motor should be here tommorow so I will start ripping that apart when the parts get here. Thanks for looking check back later for more progress
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
