My 1946 CJ2A - Page 6 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > My 1946 CJ2A
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 04-15-2007, 11:08 AM   #76
Jeepfreak81
Took it for it's first road drive last night... needs adjustment someplace, it like to pop off out the right exhaust in third gear, and sometimes at idle...
New front bumper, Orig W/S frame with Plexi W/S and more body work done, I also statred sandblasting the grill... Down to the last 2 layers of paint out of ~7
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline   Reply With Quote Quick reply to this message
Unread 04-15-2007, 11:29 AM   #77
Camo Deere
It's looking great!
Good luck with adjusting and all, it's coming out really nicely.
Camo Deere is offline   Reply With Quote Quick reply to this message
Unread 04-15-2007, 12:52 PM   #78
jayhawkclint
1970 CJ5
Jamaican me jealous, mon.
Lookin' good! Pretty soon the woman will be asking you to take 'er out on the town in that.
My '70 CJ5 Build Thread:
http://www.jeepforum.com/forum/f8/my...thread-359375/
jayhawkclint is offline   Reply With Quote Quick reply to this message
Unread 04-15-2007, 01:52 PM   #79
Jeepfreak81
She had already ridden in it once... BUT here is an update from getting ready to take her for a ride today
So despite all the hard times my G/f - future Fiancee and I have had the last few months (not with each other) in life, I have always used working on the flatty as an outlet. So I put it on the road officially last week as EVERYTHING pointed to the drivetrain being in sound shape, and took it for its first drive last night with Adam, we went about 4 miles last night and it ran PERFECT.
So Today I go to pull i out of the garage to take some pics and get it ready to take my g/f for a spin..
I fire it up and withing seconds BANG rattle rattle...
went from being happy and having something good happening to this...
I cannot say anymore... nor how POed I am.
Unread 04-15-2007, 02:49 PM   #80
jayhawkclint
1970 CJ5
BTDT... I know nothing anybody can say will make things better right now. I might be able to help, though. Sent you a PM over at www.earlycj5.com
Unread 04-16-2007, 08:32 AM   #81
Jeepfreak81
got it, the local motor is $150, I will likely do that as I can trade some parts I have for it and get the cost down to no out of pocket expense, and they are parts I don't need or won't use anyway. Shipping is minimum of $95 on that motor from you using my work tariff and bringing it in collect. The local engine is free and may run, but I probably will go through it to be safe if I can find parts reasonably... at least re-ring it and some new bearings and a hot tank. It was actually the spare motor for my chassis...
I guess I will finish the body work and make it LOOK pretty anyway....
Unread 04-16-2007, 04:14 PM   #82
ronprice
Was reading all your new post and was thinking you may be able to make the Blessing on the 5th. Hope you dont get discuraged. I've been dealing with simular problems with my toyota I have been working on for a year and a half. My troubles is finding a good trans. but I can change it realy fast now after a cuple of times.
Family of 5<Myself and 4 girls. Out numbered and dont care that I leave the seat UP.
-OIIIIIO-
ronprice is offline   Reply With Quote Quick reply to this message
Unread 04-22-2007, 11:30 AM   #83
Jeepfreak81
How many parts can you destroy in a Dauntless at one time?
The answer is somewhere in this pile... I quit counting....
Lifters cracked in half (2-3)
3 severely bent pushrods
one broken rod
block broken under intake
hole in side of block
cam in minimum of 3 pieces
Broken valve train
and thats about where I stopped....
The motor appears to have recently been rebuilt too.... :roll: I think they screwed something up when they did... the cam shows NO wear on the lobes.
Unread 04-22-2007, 05:33 PM   #84
ronprice
Looks like the New cam exploded. Then in the process of that ,Over centered the cam loab and over pushing the push rod. The valve was stuck open to far now and the piston came up and smashed into the valve. That caused the piston to brake and take the rod with it. The rod broken then fell to the side and hit the block. Thuss the hole in the block. Simular events to rest of engine I would say. Now the good news. If you can find the manufacture of the said Possible new cam, You may contact them and send them the said cam . They may find a defect and help you out. Worth a try.
-OIIIIIO-
Unread 04-23-2007, 09:10 AM   #85
atomicmoose
Just call me Moose
atomicmoose's Avatar
Wow, sorry to see this...
atomicmoose is offline   Reply With Quote Quick reply to this message
Unread 04-23-2007, 10:12 AM   #86
jayhawkclint
1970 CJ5
I'd bet timing chain before cam. Didja take the cover off yet?
Unread 05-03-2007, 10:41 PM   #87
Jeepfreak81
If you count the lifters... one is missing, I never found it. If you look at the one piston, a rod bolt is snapped on it... If you look at the cam lobes... well some are gone... Block is destroyed.
Unread 05-03-2007, 10:43 PM   #88
Jeepfreak81
Unread 05-04-2007, 06:37 AM   #89
paroxysym
2007 WK
that blows dude... time to drop in something alittle bigger...
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline   Reply With Quote Quick reply to this message
Unread 05-04-2007, 08:14 AM   #90
Jeepfreak81
You haven't drive a 225 V6 have you? That was MORE then enough for a flatty. an SBC or something would simply be stupid overkill. I already have my SBC YJ for that.
