My 1946 CJ2A - Page 4 - JeepForum.com
post #46 of 285 Old 03-13-2007, 08:06 AM
ronprice
ronprice's Avatar
When the weather breaks we will have to get together an give that a good trail run. Make plans to go to the Jeep blessing in May. and our club is welcoming any new members. I may be putting on a trail run in the middle of April here in Harrison and your welcome to join in.
Family of 5<Myself and 4 girls. Out numbered and dont care that I leave the seat UP.
-OIIIIIO-
ronprice is offline
post #47 of 285 Old 03-14-2007, 06:53 PM Thread Starter
Jeepfreak81
Jeepfreak81's Avatar
Originally Posted by oreo
Looks like fun
Im looking to get a cj3a (or b) soon to restore , im hoping ill learn alot from it.
there is a 3B near me... but I have never had the cajones to talk to the owner, sits behind a mechanics' garage.
The 2A may not be done, but they YJ is running.... which blessing? I went to the Jeep Holy Opener in Flint last year....
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #48 of 285 Old 03-27-2007, 06:09 PM Thread Starter
Jeepfreak81
Gotta re-do the blackpipe booty fab steering with these parts from a local guy... Found my extra gauges that will look right at home in the CJ, don't think I will use the YJ tach though, as I think the Sunpro tach is pretty neat on the column, electric fan etc...
added a triple gauge pod so I can monitor the motor, the temp sender had to be booty fabbed for now though. OP is 40 cold idle 15-20 hot idle... better then expected :rock: (spec is 33 @2300 RPM I easily have that)
I ditched the extended shackles it had for some YJ shackles.
got some more parts, early YJ guages, but doubt I will use the tach...
dash patched and ready to cut for gauges
Tailgate chains reattached
Shift knob I had laying around... either I will paint it, or I will use this WW2 grenade from my Great grandfather....
Start of the bondo on the rear... need to sand it and smooth it again...
post #49 of 285 Old 03-27-2007, 06:27 PM
ronprice
ronprice's Avatar
It is the BLESSING OF THE JEEPS in Mesick Mi. on May 5th. Put on by the Cadillac Jeepers http://cadillacjeepers.com Check out the web site. The run I may put on looks like it will be in Mat now I may try to get one put together for April if things work out. Here in the Harrison up towards Houghton Lk. there is alot of great wheeling spots
-OIIIIIO-
ronprice is offline
post #50 of 285 Old 03-27-2007, 06:28 PM
timothy_1987
Your 2A has really come along. It will sweet when its done. I wish kept the Willys Truck we had. But it needed alot of work (rust bucket).
Tim
2006 Jeep TJ Golden Eagle
4" Fabtech Lift 33x12.5 Pro Comp
More to come
timothy_1987 is offline
post #51 of 285 Old 03-28-2007, 09:05 PM Thread Starter
Jeepfreak81
More stuff done...
Started fixing the steering...
Started installing the fan
Then we ran out of welding wire...
I also worked some more body work on the rear 1/4, but it was drying slowly as it was chilly tonight
post #52 of 285 Old 03-29-2007, 07:17 AM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
Wow! Tons of progress. I love the way your guage panel turned out.
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #53 of 285 Old 03-30-2007, 07:36 PM
ronprice
ronprice's Avatar
If you go to the blessin you will have to check out my front disk brake conversion I did on mine ,with the closed nuckle front axle. For less than $75.00
-OIIIIIO-
ronprice is offline
post #54 of 285 Old 03-31-2007, 08:22 AM Thread Starter
Jeepfreak81
I like it too, the early YJ gauge is almost a perfect match, but is a great update over the stock one, with the trip meter etc... That will help a lot until I can get a fuel gauge and stuff... I may just get other gauges to match the speedo in the long run (I need electrical the mechanical don't work with the motor well, unless I can find a place to put the HUGE temp sender with the mechanical). The front radiator support my buddy finished for me, and the radiator is mounted and is very sturdy, and its a very simple mount, that uses the stock flatty radiator mounts, but keeps it independent of the grill.
The rear quarter is looking really smooth, but I think I need to get a better air sander, my electric palm sander just isn't doing what I need it too.
The steering is going to be interesting, I will get a picture to explain, but it will function very well with the winchmount I plan on putting on.
post #55 of 285 Old 03-31-2007, 09:55 AM
jayhawkclint
1970 CJ5
Get yourself a pneumatic straight line and a roll of sticky back paper. Use 80 grit to shape and 340 grit to smooth. Work diagonally. You'll never get it flat with a palm sander. I got my straight line from a local discount store similar to Harbor freight. I've done two restos with it now and it is still going strong. Aternatively, you could buy a cheap board sander and do it by hand. Still uses the same paper, but it is a lot harder to make the scratches disappear because it doesn't ocsillate like a pneumatic.
post #56 of 285 Old 03-31-2007, 10:12 AM Thread Starter
Jeepfreak81
I have one... but because I don't have a garage I hve never wired in my 220 air compressor to run it I am going to have to bite the bullet and wire it into the basement and run a REALLY long hose... or just sand in the driveway
post #57 of 285 Old 03-31-2007, 11:11 AM Thread Starter
Jeepfreak81
Radiator support just needs paint, we may gusset the corners too though
moving the rather large power saggy box level so the draglink doesn't hit the tie rod anymore.
he rear quarter, needing sanded, another layer, then sanded again.
Factory W/S frame being prepped to receive 1 piece glass...
post #58 of 285 Old 04-03-2007, 12:38 PM
jayhawkclint
1970 CJ5
That rear quarter is a section that I especially recommend using a pneumatic straight line. I don't think you'll ever get it even with that palm sander. Point it vertical and move it around the corner without pausing. Try to remove that bow support if possible.
post #59 of 285 Old 04-07-2007, 12:58 PM Thread Starter
Jeepfreak81
Got this off ebay for it...
Couple more vids..
post #60 of 285 Old 04-07-2007, 02:26 PM Thread Starter
Jeepfreak81
Needed more Triangulation....
Should I or Shouldn't I? They have been laying around for about 4 or 5 years...
MY new old 46 cj2a JeepRocks86 Jeep Builds 14 03-08-2011 04:33 PM
304 v8 in a cj2a sega2010 Jeep Picture Requests 4 05-17-2010 03:35 PM
