My 1946 CJ2A - Page 3 - JeepForum.com
post #31 of 284 Old 01-27-2007, 04:01 PM Thread Starter
Jeepfreak81
Jeepfreak81's Avatar
Originally Posted by doug_1994
Update????
Nothing as of yet, I bought a radiator and roll bar and I need to have the lower hose outlet moved before I can do anything at this point The roll bar needs to be cut down a hair to get it to fit on the 2A wheel wells.
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #32 of 284 Old 02-14-2007, 08:21 AM Thread Starter
Jeepfreak81
For the first time in over 20 years.... My CJ rolled under its own power!!.... a 225 is quite peppy in a 2A....
It was 10* so I put a meat thermometer in the radiator to keep track of that as I have no gauges in it yet (need to fix the dash) and I think the points need adjusted/cleaned/replaced but boy did it run well. Still have a LOT of issues to work out, but now that I know the mechanicals seem sound, I can really work on the appearance stuff and not feel bad.
Ignore all the wetness on the radiator, I spilled, as well as when I first fired the motor I forgot that the power steering lines had been removed...
post #33 of 284 Old 02-14-2007, 08:27 AM
atomicmoose
Just call me Moose
atomicmoose's Avatar
Nice work. Can't wait to see this project progress.
atomicmoose is offline
post #34 of 284 Old 02-14-2007, 08:31 AM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
I found another one the other day. Clean and painted body with frame and rear axle... the list goes up...
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #35 of 284 Old 02-19-2007, 12:32 PM Thread Starter
Jeepfreak81
Picked up my top
It is a WILLYS OVERLAND military arctic hard top, not in bad shape other then the peeling paint and broken windows. The Olive Drab is under the white still...
Figured I better go pick it up as now I am starting on body work and can make fitment better....
post #36 of 284 Old 02-19-2007, 08:32 PM
doug_1994
doug_1994's Avatar
Originally Posted by Jeepfreak81
Picked up my top.
Cool top.
I had one like that on my GPW, with doors, but gave them away like a dummy (19 at the time).
Did you get doors also?
Doug
doug_1994 is offline
post #37 of 284 Old 02-19-2007, 10:42 PM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
Great job. Can't wait to see the finished product.
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #38 of 284 Old 02-20-2007, 08:54 PM Thread Starter
Jeepfreak81
Cool top.
Doug
Attachment 27008
Attachment 27009
Yep I have the complete top doors and all, I likely will be fitting and mounting the top this weekend so I know everything will fit properly after the bodywork and paint.
Jayhawkclint, I see you found one of my build threads Hopefully I will make it to one of the ECJ5 runs with it... I want to meet everyone, not to mention wheel with you all.
post #39 of 284 Old 02-20-2007, 11:36 PM
jayhawkclint
1970 CJ5
I've got one, too:
http://www.jeepforum.com/forum/showthread.php?t=359375
In da meantime, I might have some fuel and/or money over at the wasteland. Dunno, haven't checked in a while.
post #40 of 284 Old 02-26-2007, 07:52 PM Thread Starter
Jeepfreak81
more pics... I forgot them....
Working headlights, parking lights, need to add resistance to run the turn signals, brake lights work too, I just have to get a new brake switch mine is broken
post #41 of 284 Old 02-26-2007, 08:03 PM
jayhawkclint
1970 CJ5
Sweet! Starting to look like a jeep again. How's that Dauntless running?
post #42 of 284 Old 02-26-2007, 08:14 PM Thread Starter
Jeepfreak81
Tonight it was backfiring a lot, either I didn't get the carb sealed up well when we took it off to fix the broken bolt, or it needs a tune up badly. I think its a combination of a lot of it. I reset the timing tonight and it was still backfiring out both ends once in awhile. I really need to get an oil pressure gauge on it to really see whats going on with it too, its not burning oil or knocking, so that is a good sign. I really need to get a temp gauge on it too before I damage something. Its 20* out, so the 10-15 minutes I ran it should have been ok.
Those are LED's all the way around (except the headlights) even with an LED flasher though there isnt enough load to cycle the signals. I also need to dim the parking lights down. I am going to have a 6V parking light and there are diodes wired in so when the 12V flash comes you can see the difference.
post #43 of 284 Old 02-26-2007, 09:27 PM
jcochran
looks great man
jcochran is offline
post #44 of 284 Old 03-11-2007, 06:19 PM Thread Starter
Jeepfreak81
Had a pretty day today, so I went for a ride... then got some more work done.
Adam came down and did some more patching, his welds look so much better then mine.
Lots more bodywork to go....
post #45 of 284 Old 03-11-2007, 06:26 PM
Lostj
Lostj's Avatar
Looks like fun
Im looking to get a cj3a (or b) soon to restore , im hoping ill learn alot from it.
00'TJ
74'CJ5 For Sale
Lostj is offline
MY new old 46 cj2a JeepRocks86 Jeep Builds 14 03-08-2011 04:33 PM
304 v8 in a cj2a sega2010 Jeep Picture Requests 4 05-17-2010 03:35 PM
