My 1946 CJ2A - Page 17 - JeepForum.com
post #241 of 285 Old 10-02-2011, 08:36 AM
CDW_327
Hay man what all did you use for your power steering swap? Box, tie rods colum....
CDW_327 is offline
post #242 of 285 Old 01-22-2012, 07:36 PM
JROCK78
1974 CJ5
Awesome jeep man! I hope to find one like that to tinker with someday. Mine is too stock and in such great shape i can't get myself to put it under the knife.. kinda sad i know...
JROCK78 is offline
post #243 of 285 Old 02-01-2013, 07:44 AM Thread Starter
Jeepfreak81
Jeepfreak81's Avatar
Weird I never got a notification for this thread. It is stock NT tie rods and drag link from a later CJ, and I am running a J20 power steering box, it is way overkill, but it was laying around.
More updates.
Just scored $1000 worth of drivetrain on CL for $325 after a tip from a friend
T98/D18/Warn OD I can keep my 3.73 axles for wheeling now! 6.72:1 first and an OD!
I also went snow wheeling again at Snofari 2013
I have done this run for over 5 years without issue... this year all hell broke loose on me.
It started with backing into a ledge/stump
The day was going well and then....
A low tree combined with my heavy foot ripped the (hard to find) hardtop almost clean off, springing the door open. I got stopped and started sliding backwards on the ice and the door swung wide open on me causing me to "Tommy Boy" the door, crack the windshield, and dent/bend the passenger fender.
The funny part was someone said my exact words were "I got this!" as I broke out a cordless sawz-all. I was then asked who in the world carries a sawz-all.
Video of it happening, and the repair When I hit the tree the front wheels came off the ground.
Wheeled some more
and then my electric fan failed
So we did a redneck cooling fix
the fender, the picture doesn't show it well, but it is bent downward and the tub is bent
Culminating in the So-Broke award
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #244 of 285 Old 02-01-2013, 07:49 AM Thread Starter
Jeepfreak81
So the night I got it back home:
My buddy took over from here while I was out of town
post #245 of 285 Old 02-01-2013, 09:06 AM
1ABrian
wow excellent build. Going way back with your plow frame build, nice work! This little buggy moved that snow no problem. Cool videos. Love the wheelin pics too. Too bad bout the carnage but hey....it happens man. Looking forward to seein more progress AND more wheelin pics!!
Brian
1aauto.com
888-844-3393 EXT 153
SHOP HERE: Jeep Parts
1ABrian is offline
post #246 of 285 Old 02-01-2013, 10:30 AM
BamaJeepman21
Nice man. Just please...please don't cut it up. Sucks about the hardtop. Those are the definition of rare and easily are more expensive than the Jeep itself.
-Jack
BamaJeepman21 is offline
post #247 of 285 Old 02-01-2013, 11:13 AM Thread Starter
Jeepfreak81
Every one of these hard tops I run across are usually sub $300. I had a guy offering me one within an hour of smashing it to hell. That said I do not plan to destroy it. I saved the frame I cut off to finish the day as well. I will probably put it in the rafters and maybe pick up another one. I might try to bump it out too. My doors were already in rough shape and the latches never worked as the doors were dented and twisted pretty bad before I got it.
The tops make the jeep miserably uncomfortable, and are a pain to remove and put on. Because of that top my jeep has not been street driven in the summer for the last 2 years. With my new job I just have no time to remove it in summer and grabbing the motorcycle is that much easier.
The jeep might actually get driven this year with no top on it, if I get it put back together.
post #248 of 285 Old 02-02-2013, 09:33 AM
BamaJeepman21
We must live on opposite sides of the Jeep world. One of these days I'll find me a nice 2a, M38, M38a1, or an early CJ 5.
-Jack
post #249 of 285 Old 02-02-2013, 01:49 PM Thread Starter
Jeepfreak81
The tops are probably more plentiful here with the snow and cold we get. The top I am looking at now he is asking $200. I could have had a nice half cab had I been quicker, it was in NJ but I go that way for work all the time.
My buddy just sent me these:
T86a vs T98
4 cyl clutch of V6 pressure plate and V6 clutch laying next to it we are hoping to find a larger clutch disc to use
T98 with Buick bell housing ready to go in for a test and trim
Got the T98 crossmember cleaned up also
post #250 of 285 Old 02-03-2013, 11:09 AM
BlueTeeJay
Lookin' good.
BlueTeeJay is offline
post #251 of 285 Old 02-03-2013, 08:27 PM Thread Starter
Jeepfreak81
Test fitting
post #252 of 285 Old 02-04-2013, 08:05 PM Thread Starter
Jeepfreak81
New steering shaft on the way, mechanical fan and spacer on the way, and hope to order a column next paycheck.
This thing has really taken care of me, this is the first real money put into it. Hopefully I can get a clutch disk, I found the throwout bearing today. Looking more like a custom clutch disk will be in order, I have an email into a company mentioned by a friend.
post #253 of 285 Old 02-06-2013, 07:42 PM Thread Starter
Jeepfreak81
Well, My rear driveshaft was >< that close to breaking. Adam noticed it is twisted like a pretzel, just not broken when he was measuring it to see if I would need to shorten it.
Clutch Dynamics wants to look at my pressure plate and stuff, they think they can make me the clutch disk I need for about $100. They seem VERY knowledgeable and are genuinely nice people on the phone. They asked that I bring my old parts over, and what I have and they can get me something that will work.
Trans mocked into place with all the levers...
More showed up today:
Column should be here Friday, and Clutch Dynamics has my parts, should have a quote to me tomorrow. :rock: Summit had to special order my steering shaft so hopefully it will show up soon.
post #254 of 285 Old 02-10-2013, 12:05 PM Thread Starter
Jeepfreak81
I picked this up yesterday, he was a great guy, really took care of me when I had a trailer break down.
I'm going to try not to bang this one up. I am still confused how on every one of these tops I have looked at the door latches are broken and mangled beyond operating.
post #255 of 285 Old 02-17-2013, 08:01 PM Thread Starter
Jeepfreak81
I love Craigslist.. with a receiver mount, cheap. Front and rear winches anyone?
MY new old 46 cj2a JeepRocks86 Jeep Builds 14 03-08-2011 04:33 PM
304 v8 in a cj2a sega2010 Jeep Picture Requests 4 05-17-2010 03:35 PM
