My 1946 CJ2A - Page 12 - JeepForum.com
post #166 of 285 Old 10-04-2008, 01:47 PM
ronprice
ronprice's Avatar
I havnt been checking up on thing in a while and I say the WILLYS is looking great . Seeing it on the go is awsome. You will have to bring it up to Rocks & Valleys and wheel it with my WILLYS. We are working on the park most weekends and for a little help with building some wheeling can be done , or wait till spring for the opening.
Family of 5<Myself and 4 girls. Out numbered and dont care that I leave the seat UP.
-OIIIIIO-
ronprice is offline
post #167 of 285 Old 10-05-2008, 10:03 AM Thread Starter
Jeepfreak81
Jeepfreak81's Avatar
Thanks!
I need to have my tow rig fixed and then I can bring it up, that will probably be spring. I can't drive it up there. If I knew FI I could do it myself
I just put the tarp on WIth the THULE load bars in place... and it FITS!
That makes me happy.
I also picked up a better tongue lock, and that mixed with it being chained to the tree should make it difficult enough to take no one will.
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #168 of 285 Old 12-02-2008, 11:04 AM Thread Starter
Jeepfreak81
WOOT!!!
post #169 of 285 Old 12-02-2008, 04:09 PM
homeboy1991
Thats one kool jeep man and congrats on the magazine
homeboy1991 is offline
post #170 of 285 Old 12-02-2008, 05:05 PM
xsnalex
1994 ZJ
congrats on the magazine, great build.
xsnalex is offline
post #171 of 285 Old 12-03-2008, 08:00 AM
JaikYJ
I just read all 12 pages and that makes me want to find an old flat fender to build with my dad. I like the look of it all black and that was a really good choice on the skinny tires.
I loved the side pipes you had on there too.
The hard tops for those things are so ugly that they are cool. I can wait to see where you go with this thing. Great build.
87 YJ(sold), 97 TJ(sold), 99 TJ(daily)
03 R1 (fun)68 Mustang Coupe(summer)
67 Fastback(resto)
JaikYJ is offline
post #172 of 285 Old 12-03-2008, 01:48 PM
96cherokeeclass
Well it took me 2 days on and off to read through this thread at work, it was a rollercoaster. wow he's got that thing rolling it looks great... oh no a hole in the block, I'll never see this thing done... WOA what a girlfriend, new engine...
Great build, love the radio.
- 07 WK - CRD
96cherokeeclass is offline
post #173 of 285 Old 01-02-2009, 05:29 PM Thread Starter
Jeepfreak81
Picked up this nice little D30 for the front a few weeks ago... mostly new parts, VERY clean $50 and the correct gearing with 11" brakes
I have been pretty sick for a couple weeks and have not had time to do the D30 swap. Adam came over today to help me throw it under and hopefully prep for the winch that should be arriving Tuesday (and hopefully can find time to mount it for Snowfari)
Got most of it done today, but had to order brake lines and bead glue. Also need to locate a longer (not drop) pitman arm to make use of my new found turning radius.
The width is a nice match with the 2" wheel spacers on the rear. It puts the tires out just enough to protect the body.
We have to break down all my tires and transfer 3 of them to wheels that have safety beads and use bead glue on them. The 4th needs just broken down and bead glue put on, then I need to calibrate my tire deflators and put together spare parts and a tool kit to take.
Tomorrow my brake lines should be in, and we can install the new lines and bleed the system.
While underneath today Adam discovered my rear u-joint is toast, and we have to make up a new front shaft because the D30 uses a large u-joint compared to the flatties original one.
I hate last minute wrenching for a wheeling trip. Even more so when we are not positive how we are getting it there :sonicjay:
post #174 of 285 Old 01-02-2009, 06:34 PM
Codyf12
nice jeep
wish i had those kinda skills
Codyf12 is offline
post #175 of 285 Old 01-03-2009, 01:17 AM
evoGibson
awesome rig dude, hope i can score a flatty one day
1999 xj, bone stock-current
1998 xj, 2" on 33's-past
1994 yj on 31's-past
evoGibson is offline
post #176 of 285 Old 01-03-2009, 12:47 PM Thread Starter
Jeepfreak81
More from today....
Originally Posted by Mclovin View Post
I would get a spare solenoid for your winch.. they're around 70 bux and they're prone to going bad.. i fried mine but only because im dumb and got the controller wire tangled up into the winch cable
If they are that expensive and prone to going bad, I will try to figure out a more reliable way.
Some more pics from today... Adam convinced me to check the wheelbearings and I am kind of glad I did now, the drivers side wheel seal was shot, so tomorrow some new seals should be arriving, and I am going to replace that bearing just for peace of mind.
All that is left for now:
Replace rear u-joint (1/8" of play)
Finish installing new brake lines and bleed
install new wheel seals, grease whel bearings, and re-assemble.
Install winch and winchplate maybe.... if the winch arrives.
I should be able to air down sufficiently now. Got some different wheels from Adam and he switched the tires to them for me. These have a safety bead and I also used bead glue to help eliminate leaks when aired down. The slightly wider rims really changed the look of it (other then the rusty white paint)
post #177 of 285 Old 01-03-2009, 05:28 PM
Lifesgoodhere
sweet 2a! I sorta wish I had one...but I have close enough. Good luck on the winch. I just now went back in my archives and looked at your Jeep in JP...congrats on that! If you haven't already, check out my build/restoration sometime. Cheers!
A Jeeper for life
Lifesgoodhere is offline
post #178 of 285 Old 01-09-2009, 07:57 AM Thread Starter
Jeepfreak81
New Stance! Hope the winch makes it, it is out for delivery right now :naughty:
CJ2A is mobile and ready to go... if the winch comes today I may just get it on
Need to make a bearing adjustment and minor brake adjustment I think... but I KNOW i just set a world record changing a wheel cylinder... 30 mins from wheel on to changed cyl and wheel back on... 1 hour includes bleeding the brakes by myself and driving around testing and taking pics.
Does sweet doughnuts with it's new found turning radius... weird it turns sharper one way then the other, need to check steering stops.
post #179 of 285 Old 01-09-2009, 11:24 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Originally Posted by Jeepfreak81 View Post
That is such a pretty picture!!!
Worth putting in a frame!
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #180 of 285 Old 01-09-2009, 11:28 AM Thread Starter
Jeepfreak81
Thanks, I have ton's like this, I do a bunch of amateur digital photog stuff. My whole living room is Jeep themed, I ran out of places for pictures so now I have one of those Kodak digital frames on the DVD rack that cycles through all the ones I couldn't fit
MY new old 46 cj2a JeepRocks86 Jeep Builds 14 03-08-2011 04:33 PM
304 v8 in a cj2a sega2010 Jeep Picture Requests 4 05-17-2010 03:35 PM
