Music City Flop Project - Page 399 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Music City Flop Project
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Free ARB Air Compressor with Locker PurchaBds fox ipf 2.0 racing series shocks now available at rock
Unread 05-10-2012, 09:41 AM   #5971
B2CARPEN
Jeep Junky
B2CARPEN's Avatar
65%? Don't you want to be around 80% - 90%? I like the link layout.. double tri while keeping those lowers at a lesser angle. It's nice to have the extra width of the JK axles when determining the CA bracket locations.
IndyORV
B2CARPEN is offline   Reply With Quote
Unread 05-10-2012, 09:52 AM   #5972
Imped
Balls
Imped's Avatar
You're overthinking it Brad.......
Looks good Johnboy.
OlllllllO
Float Test Build
IndyORV
If you see a dead picture link of mine and would like it fixed, please PM me the link to the post and I'll fix it. Thanks
Imped is offline   Reply With Quote
Unread 05-10-2012, 09:59 AM   #5973
Hendrix
TJ Truck?
Hendrix's Avatar
Funny thing is stock TJ D44 has a lower CA spread of 44". Half would be 22". Mine are tacked at 21" from center.
Hendrix is offline   Reply With Quote
Unread 05-10-2012, 10:07 AM   #5974
B2CARPEN
Jeep Junky
B2CARPEN's Avatar
Looks good Johnboy.
Not necessarily overthinking.. just not understanding.
IndyORV
Unread 05-10-2012, 01:25 PM   #5975
Hendrix
TJ Truck?
Hendrix's Avatar
Got the rest of the stuff ordered to finish up all the little things to make Flop a pretty solid wheeler.
Currie Motor mounts
New lower shock mounts from Ruffstuff
Tie in kits, and bushings for the trans crossmember.
Material ordered for a full length belly skid.
Still Needed:
Hydro fittings
Cooler and mount
Stick of 1 3/4 Dom for tire mount and X in cage.
Soft upper doors (black)
Unread 05-10-2012, 02:08 PM   #5976
Hendrix
TJ Truck?
Hendrix's Avatar
Pair of these babies...
The material for the skid should be ready by Monday. The stick of DOM next Thursday.
Unread 05-10-2012, 02:25 PM   #5977
Imped
Balls
Imped's Avatar
I'm in love with those shock mounts.
OlllllllO
Float Test Build
IndyORV
Unread 05-10-2012, 04:46 PM   #5978
Hendrix
TJ Truck?
Hendrix's Avatar
Should be able to focus now. I have set a deadline to make the June Run.
I have to do the following by June 9th. As you guys know I work better under pressure. Here is what HAS to go down.
Cycle rear suspension
Final weld all the link mounts
Reinstall axle
Tack lower shock mounts
Install outboard kit/cage tie ins
Tie in A pillars
Build trans crossmember/ or steal from DD
Cut out flat skid and reinforce
Install Hydro Assist, or atleast the steering gear.
Install 4.0
Install NSG370
Take to exhaust shop.
Wheel on the 16th to test.
After all that, install X in cage and harnesses.
Then the Flop is Done.
I decided to do all this at once to get it all out of the way.
Unread 05-10-2012, 05:06 PM   #5979
crazycollinz
When is the badlands run?
crazycollinz is offline   Reply With Quote
Unread 05-10-2012, 05:18 PM   #5980
Hendrix
TJ Truck?
Hendrix's Avatar
My calendar says June 22nd
Unread 05-10-2012, 05:23 PM   #5981
crazycollinz
I am goin to have to get out there for this trip. It will prolly be that last good wheeling I get to do before the twins get here
Unread 05-10-2012, 05:26 PM   #5982
mcannon111
Mash yer motor
mcannon111's Avatar
man the flop is gonna be one badass wheeler! i hope i get to wheel with you sometime!
no doors, no top, no problems
live in sc? join OffroadSC.com
The Silver Bullet
mcannon111 is offline   Reply With Quote
Unread 05-10-2012, 07:10 PM   #5983
Hendrix
TJ Truck?
Hendrix's Avatar
Thanks dude....
Unread 05-10-2012, 11:32 PM   #5984
Kodiak17
SNOZBERRIES <3
Kodiak17's Avatar
Haven't had the time to read through all this (yet). I'm barely done skimming through Imped's. But your build is awesome. I'd like to see some video of it perform, if that's possible?
Maintain, wheel, upgrade, repeat.
My build: THOR - DD/Weekend Warrior
For sale
Kodiak17 is offline   Reply With Quote
Unread 05-11-2012, 05:19 AM   #5985
Hendrix
TJ Truck?
Hendrix's Avatar
There is some video from 2 years ago somewhere in the build. But, nothing since the Mid arms. Soon my friend, soon.
I have a Gopro and others I occasionally wheel with capture video sometimes. I also have a friend that's planning on shooting a 4-5 angle video this summer of the Jeep in action for his website. He does local band covers, and music vids. He thought it would be cool to test all his skills on.
axles , bbq ribs , build , custom , hendrix , hi line , high line , hillbilly , indyorv , jk , john , lcog , music city flop , paint , rokmen , rv antifreeze , specs , stretch , tj , tjk , ucf skid , undercover fab , wobble
