Music City Flop Project - Page 374 - JeepForum.com
post #5596 of 7117 Old 02-23-2012, 06:43 AM
AngryTJ
Hendrix what top are you running on the flop? Is that a rampage?
AngryTJ is offline
post #5597 of 7117 Old 02-23-2012, 06:47 AM
aw12345
Originally Posted by Hendrix View Post
Yeah, as far as the flat pitman arm and stock steering box would allow. Maybe one of these days I will stretch it out with a stretch kit from TNT. Till then its about 2" over stock forward. My coils are centered on the tubes, and my shock mounts come off the sides of the lower control arm mounts.
So, no one has the torque specs for a Dana 44?
Not for the JK axles
TJ Dana 44 rubicon axle
ring gear bolts 100 ft/lbs
bearing cap bolts 80 ft/lbs
pinion nut 160- 200ft/lbs
pinion rotational torque used bearings 10-20 inch/lbs
new bearings 20-40 inch/lbs
backlash 0.005" to 0.008"
Whyen done right and it's all together the bearing preload of the carrier/ ring gear bearings should add 5inch/lbs rotational torque over the pinion rotational torque.
This should get you going John, have fun.
aw12345 is offline
post #5598 of 7117 Old 02-23-2012, 08:14 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Thanks Art.
She is opened up and clean. I was really happy to see good color in the gear oil. It's been 2 years almost since I had the diff cover off.
Little preview of the bling- bling
K.C.C.O.
Carpe Diem
Hendrix is offline
post #5599 of 7117 Old 02-23-2012, 08:54 AM
jake92321
Looked up for an 08 rubicon axles on Mitchellondemand
The front axle is the same as the tj specs
The rear axle called for the same except 135 ft lbs on the ring gear bolts.
Seems a little high to me for ring gear bolts
1999 Desert Sand TJ Sport
jake92321 is offline
post #5600 of 7117 Old 02-23-2012, 09:07 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Hmmmmm... What is it.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #5601 of 7117 Old 02-23-2012, 09:09 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
They are really big bolts.
Thanks for the specs
K.C.C.O.
Carpe Diem
Hendrix is offline
post #5602 of 7117 Old 02-23-2012, 09:17 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Seats are here....
K.C.C.O.
Carpe Diem
Hendrix is offline
post #5603 of 7117 Old 02-23-2012, 09:47 AM
Recoil
Recoil's Avatar
1988 MJ Comanche
About time
Recoil is offline
post #5604 of 7117 Old 02-23-2012, 09:55 AM
gribbles
lovin the bling, those seats look nice too
2000 TJ, 100" wb on leaves
2007 WK CRD
gribbles is offline
post #5605 of 7117 Old 02-23-2012, 09:56 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by Recoil
About time
Just for you jerrbear
K.C.C.O.
Carpe Diem
Hendrix is offline
post #5606 of 7117 Old 02-23-2012, 10:00 AM
Imped
Imped's Avatar
So today is a pretty good day.....seats and gears. Not too shabby man.
OlllllllO
IndyORV
Imped is offline
post #5607 of 7117 Old 02-23-2012, 10:06 AM
MO2500
I like those seats. Are those the same mastercrafts that Jay is running?
I went cheap on my suspension seats and while they are more comfy then the seats they replaced I'm not really happy with them. I'll probably be looking to replace mine in the next year or so.
Instagram: @omsmike
MO2500 is offline
post #5608 of 7117 Old 02-23-2012, 10:30 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Jay has reclining, mine are Rubicon fixed back, with a harness bar and stuff I could see no reason for reclining seats. I got harnesses also.
It's a happy day!
K.C.C.O.
Carpe Diem
Hendrix is offline
post #5609 of 7117 Old 02-23-2012, 10:38 AM
MO2500
Yeah I have no reason for reclining seats either. If I had them they wouldn't be able to recline at all because they will be against the b-pillar "X" brace on my cage. That's the other thing that worries me about changing my seats, I literally stuck my current seats in there and built the "X" and supports around them. I might have to tear into my cage again to replace my seats (obviously I'd need to for mounting anyway).
If you wouldn't mind, PM me where you purchased yours from and for how much. I will definitely be considering swapping the seats and upgrading my harnesses as well.
Instagram: @omsmike
MO2500 is offline
post #5610 of 7117 Old 02-23-2012, 10:58 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Morris4x4. Pm sent
K.C.C.O.
Carpe Diem
Hendrix is offline
axles , bbq ribs , build , custom , hendrix , hi line , high line , hillbilly , indyorv , jk , john , lcog , music city flop , paint , rokmen , rv antifreeze , specs , stretch , tj , tjk , ucf skid , undercover fab , wobble
my project YJ confusedYJTJ Jeep Builds 6 10-26-2010 08:04 PM
my 97 project andrew383 Jeep Builds 7 09-19-2010 01:08 PM
Jeeps stuck in a city.. Osmosiz Jeep Picture Requests 10 04-07-2009 09:49 PM
Who says ya cant flop in a mud hole!! Mr.Crowley Jeep Builds 21 01-23-2008 07:58 PM
Wet, nasty weekend in Panama City Beach... PCB CJ7 Jeep Builds 3 10-16-2003 03:01 PM
