Mountain Unlimited - Page 6 - JeepForum.com
post #76 of 110 Old 10-25-2013, 02:03 PM
try2holdmywheel
Originally Posted by JeepinAaron View Post
I hate the under hood light. I also hate having to hold a flashlight to check out something at night. So I took some Genright led lights and put them under the hood.
Really like this idea. I was thinking about putting a strip of LEDs running the length of the hood on either side. I was thinking something like these would do the job.
'69 Bronco
try2holdmywheel is offline
post #77 of 110 Old 10-25-2013, 04:49 PM Thread Starter
JeepinAaron
2003 WJ
Yea those would do the trick. The Genright LED's worked out great though, and were cheaper. I'd had them in my basement for awhile and finally wired them up.
2003 WJ Laredo
http://www.jeepforum.com/forum/f22/2003-wj-off-road-minivan-2346505/#post22320625
JeepinAaron is offline
post #78 of 110 Old 10-26-2013, 10:34 AM
try2holdmywheel
Do you have a link to the Genright ones. The ones I can find on the site are significantly more expensive. Thanks.
'69 Bronco
post #79 of 110 Old 01-26-2014, 08:54 PM Thread Starter
JeepinAaron
2003 WJ
Harlan
Well I figured it was about time the LJ hit some trails again as it has been far far too long. I planned ahead and found some childcare for the weekend and I drove up to Harlan Kentucky with my dad. I had never been there and wanted to check it out. What I hadn't planned for was 3-4 inches of fresh snow. It made things interesting for sure. Trails that would be nothing were slick as crap. We invented a new sport of jeep sledding as we slid uncontrollably down some hills.
Day one was spent on all green and blue trails. It was uneventful but fun with the snow. The only hiccup was on our way out in the dark I was driving along minding my own business, about to drive in an innocent little waterhole between some trees when BLAM the ice broke and fell into a 31" hole. I had to get strapped out due to the ice wall.
Second day we hit some more blue trails,ran trail 31 and checked out lions den. I plan on trying that when its dry. Then we hit upper grace, part of trail 15, and trail 13 which were all red. They Would have been no problem without the snow.
We stayed at Harlan campground in the cabins which I recommend. The trail map sucked and was not accurate. There are trails and intersections which were not on the map. Also the trails could be better marked.over all I loved it and will be back.
2003 WJ Laredo
post #80 of 110 Old 01-27-2014, 07:02 PM Thread Starter
JeepinAaron
2003 WJ
Here is the evidence of the ice hole. I think I could have driven out if I didn't have to push all of the 4" thick ice blocks.
2003 WJ Laredo
post #81 of 110 Old 01-27-2014, 08:40 PM
redrelyt12
Time for a winch! Or an Amazonian girlfriend?
I never make the same mistake twice - it's more like three or four times.
Build - http://www.jeepforum.com/forum/f22/unlimicon-build-1477723/
redrelyt12 is offline
post #82 of 110 Old 01-28-2014, 06:01 AM
84jeepcj7rock
That makes for some interesting recovery.
84jeepcj7rock is offline
post #83 of 110 Old 01-28-2014, 07:57 AM Thread Starter
JeepinAaron
2003 WJ
Yea, especially not wanting to get wet because it was 17 outside. Water got in the Jeep and its 10 where I live, carpet is frozen still.
2003 WJ Laredo
post #84 of 110 Old 02-07-2014, 08:56 PM Thread Starter
JeepinAaron
2003 WJ
So I've been watching KOH online and felt the need to get something for the Jeep. My driver side rear tail light bit the dust. The brake light works, tail lights don't, changed the bulb and it didn't fix it. So time to upgrade. I looked at several options. I don't think the Savvy lights will work with my Exogate because the hinges are bigger and my stock tail lights barely fit, the Savvy ones look taller. I almost got the ORO litedots, but they aren't DOT approved and I'm not big on the round. So I stuck with the stock look and bought these LED's from quadratec. These lights are more than $100 cheaper than the other options and include the new flasher module.
I couldn't find any info on anyone else using them so I guess I will be the guinea pig and see how they work.
2003 WJ Laredo
post #85 of 110 Old 02-09-2014, 03:46 AM
contdevelop
Nice LJ.
contdevelop is offline
post #86 of 110 Old 02-09-2014, 07:28 AM
Jankoid
Good luck with that.
Jankoid is offline
post #87 of 110 Old 02-09-2014, 05:50 PM Thread Starter
JeepinAaron
2003 WJ
I walked it, the trees seem to be the issue in making it so tight, and that big arse boulder. When I try it I'm going to ditch my top, doors, and lay down the windshield.
Have you ran any of the harder trails there? I'm definitely looking to try harder things next time I go when its not snowing.
2003 WJ Laredo
post #88 of 110 Old 02-13-2014, 09:19 PM Thread Starter
JeepinAaron
2003 WJ
Tail light update: Quadratec has their LED's on back order so I switched to the ORO because I need them sooner than later for state inspection. But of course they are somewhere stuck in transit due to the snow storm.
Here is a so so night picture. My wife got a new camera for christmas I was playing with while letting my dog out. As the storm cleared the moon came out and provided some light.
2003 WJ Laredo
post #89 of 110 Old 02-13-2014, 09:29 PM
Jankoid
I've done most of the trails there, but Lions Den isn't one of them. I highly suggest you stay away from Lions Den. Body damage is inevitable on that trail, plus it is hard to get out if you get stuck.
Jankoid is offline
post #90 of 110 Old 02-18-2014, 04:56 PM Thread Starter
JeepinAaron
2003 WJ
So I had aired down the tires on my wife's liberty for better snow performance climbing our driveway. Today I am airing them back up, get to the 4th tire and stop to check air pressure. The compressor stops, then won't start back. Seems like the thing is dead which is pretty frustrating since this is my second compressor since running ARB lockers. This compressor lasted 1 year and 4 months, during that life span it filled up MAYBE 16 tires. Guess I'm going to see if I can get it warrantied and look for a different set up for filling tires.
2003 WJ Laredo
2010 JK mountain bluenevil123 Jeep Builds 1 02-07-2012 09:05 AM
A mountain biker's XJ capturecolorado Jeep Builds 2 11-10-2011 07:56 PM
Let's see your Mountain Bikes sandjunkie Jeep Picture Requests 18 06-23-2010 08:05 AM
Berry Mountain SimonTuffGuy Jeep Builds 5 05-22-2006 06:17 PM
New Red Rocky Mountain JeepinJake Jeep Builds 4 08-29-2004 05:10 PM
