more lift for my wj - JeepForum.com
post #1 of 3 Old 09-01-2010, 08:03 PM Thread Starter
04chevy2500
more lift for my wj
who ever can help i just put on a 4inch rough country lift on my jeep and put 33nittos on it, im not happy with the size i want it bigger, im thinking about 4linking the rear and trashing the three link setup, i have a commplete 4link setup for a fullsixe chevy rear imma fit it to my wj,any help i want to put another 4inches on my jeep with coil spacers and then raising up the coil cup any ideas, do they make 8inch spring for a wj ive done a couple axel swap and straight axel conversion on chevy fullsize with leaf spring never messed with coils thoe can any one help, money is a lil tight right now and i got alot of parts laying around so i want to buld what i can thanks for all the info
04chevy2500 is offline
post #2 of 3 Old 09-06-2010, 10:45 AM
stumpman1
If you have leaf springs you can put some bigger shackels on it. I have a 89 YJ and i had 3.5 inches and I liked it but I wanted bigger so I went to Quadratec.com and got some bigger shackles and now i have 6 inches or you can go to a local 4 wheeldrive shop and get them to flip the leaf springs on top of the axle. That is just some suggestions i have.
Michael
stumpman1 is offline
post #3 of 3 Old 09-08-2010, 04:15 PM
DRogalOlBlue13
You would have to go with a custom coil, but that isn't the best idea because you throw off a lot of the front and rear end goemetry. the best route is to go to a 6.5" lift, and do some fender trimming. This way you can fit 35s. But any way you go, re-gearing will be needed, and if you are on a budget, then start small... save, and move up from there. WJs are very expensive to build correctly, and it is better to do it right!
Best of luck,
Drew
2002 WJ- 2.5" Rusty's lift + KOR .75" spacer. Nitro Shocks. 265/70 Hankook Ats on 16X8 Soft 8s
DRogalOlBlue13 is offline
4inch lift with 1 inch body lift and 35s 00jeepsahara Jeep Picture Requests 21 05-17-2011 08:03 PM
2.5" lift, with 32's or bigger. no body lift. JURKFASE Jeep Picture Requests 0 06-17-2010 10:27 AM
xj's with 33-10.50's on 4.5" of lift(or any lift) savvypower Jeep Picture Requests 15 12-15-2009 11:54 AM
sus lift and 2' bodYj with a 4 inchy lift and 33 inch tires chino Jeep Picture Requests 0 02-23-2008 10:03 AM
YJ with 31" wheels/15x7/lift/no lift Barrio Jeep Picture Requests 4 01-28-2008 07:49 PM
