monsonman's LJ Rubicon Build - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > monsonman's LJ Rubicon Build
JKS Flex Connect in Actions!CCOR is Hiring! Athens, GA!ZONE 4.25" combo lift for TJ available at Rockridge4w
Unread 05-11-2015, 09:35 AM   #1
monsonman
monsonman's Avatar
alright folks, i guess its time to start a thread on my new project.
my other build came to an abrupt halt after an engine fire that rendered it a total loss. i will still keep that thread updated as needed as i know some people are curious to the cause of the fire.
anyways, after looking over the internet i came across a white LJ Rubi in Austin, TX w/160K on the clock that had a price that was low it almost scared me away. but my curiosity got the best of me and i called, put a refundable deposit down on it and had my uncle who lives there go shake it down and see if it was a good buy.
it was, and a week later i was on my way up to Austin to pick up the new jeep.
in safe keeping at my uncles place
after getting it home - 315s in the rear, 305s up front
ordered 2 new fronts to match the back tires and painted the rims with plastidip.
and drove it like this for a few weeks. i think i put more miles on this jeep in a week than i put on my TJ in 3 years
also, to note, the jeep has some sort of budget 3" lift w/ fixed lowers and factory uppers, some progressive springs and bilstein 5100s all around.
also had currie currectlync steering already. great, one less $500 thing i had to buy.
monsonman is offline   Reply With Quote Quick reply to this message
Unread 05-11-2015, 09:40 AM   #2
monsonman
monsonman's Avatar
then i ordered genright aluminum hi fenders, rocker guards and rear high flares. also, stout fab steel full corners.
my goal is to be able to run my 36" irocs with the current lift it has so these parts should help
tight fit
also, scored BNIB ten factory rear chromos off the local board that i will install
Unread 05-11-2015, 09:48 AM   #3
monsonman
monsonman's Avatar
so that brings us up to speed.
last weekend i started removing the front fenders, and rockers in prep for the high lines
mocking up the genrights
the shop (toasted jeep back right) and new millermatic 211 back there as well. been learning how to weld
Unread 05-11-2015, 12:44 PM   #4
jeepster1407
Nice LJ man! Did you order the Genright inner fenders and inner mounting kit also or were you able to make it all work with out them?
_________
My Thread - http://www.jeepforum.com/forum/f22/p...arrel-3291513/
jeepster1407 is offline   Reply With Quote Quick reply to this message
Unread 05-11-2015, 01:04 PM   #5
monsonman
monsonman's Avatar
yeah i ordered the inners and the mounting kit for the battery. havent installed them yet but will likely be working on it this afternoon.
Unread 05-11-2015, 03:01 PM   #6
dayriesw
dayriesw's Avatar
Damn. Those are the fenders I might be adding soon. Cool.
Jeep LJ on 37s : Build - http://www.jeepforum.com/forum/f22/i.../index125.html
Jeep Comanche: Build coming soon.
dayriesw is offline   Reply With Quote Quick reply to this message
Unread 05-11-2015, 03:03 PM   #7
monsonman
monsonman's Avatar
getting rid of your cambell hood?
Unread 05-11-2015, 03:05 PM   #8
dayriesw
dayriesw's Avatar
No. But when I get slightly wider axles, I figured I'd need something to cover part of the wheels.
Unread 05-11-2015, 06:11 PM   #9
AngryTJ
AngryTJ's Avatar
I can't recall are those racelines and irocs from your other build?
Tarantula_TJ Build
AngryTJ is offline   Reply With Quote Quick reply to this message
Unread 05-11-2015, 06:55 PM   #10
monsonman
monsonman's Avatar
Yes sir. 36x13.50x15 irocs. I will run these for a while since I've already got them
Unread 05-12-2015, 08:26 PM   #11
monsonman
monsonman's Avatar
got some more work done on the hi fenders today. cut the inner fenders to fit around the coil buckets (and steering shaft support on the driver side). then got them fully bolted on with the inners. still have to install the battery mount and remount the various things that were attached to the factory wheel wells
but honestly this has been quite a simple and stress free install, contrary to what ive read on a few of the threads. having a high speed air saw and air socket are a must however.
Unread 05-14-2015, 02:46 PM   #12
98TJcomeonuh
Genrights look killer, how is the fit at the bottom of the tub and bottom of the fender?
98TJcomeonuh is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 07:10 AM   #13
OkLaHoMaTJ
Looking to go highline's here soon..haven't decided which route to go. Either PSC or Genrights. Curious to see how your hood trim turns out. Looking good.
My Thread - http://www.jeepforum.com/forum/f22/another-lj-rubicon-thread-1516486/
OkLaHoMaTJ is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 01:28 PM   #14
monsonman
monsonman's Avatar
I won't be cutting the hood actually. I ordered a duraflex highline hood. It's basically a knock off of the AEV hood. There's almost no information online about them so I decided I would take a chance and see how it is.
Unread 05-15-2015, 01:36 PM   #15
98TJcomeonuh
They look good, what website did you buy it from.
