Monsonman's '98 Cajun Crawfish Build - Page 7 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Monsonman's '98 Cajun Crawfish Build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 04-23-2013, 08:11 AM   #91
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Looks good. I bet you won't have a problem out of that linkage again.
06 WK Hemi Overland.. stock DD
87 MJ project on 37s.. Waggy axles, 6 speed, flipped D300 and Bobbed 10" so far. 3 link coming soon.
Sold:
05 LJ.. Low and on 37s
79 FSJ.. 360/4speed on 38s
85 CJ-7 Renegade
Buy my AEV Pintler TJ Beadlocks. See the classifieds.
dayriesw is offline   Reply With Quote Quick reply to this message
Unread 04-23-2013, 10:35 AM   #92
monsonman
monsonman's Avatar
i better not
monsonman is offline   Reply With Quote Quick reply to this message
Unread 04-23-2013, 10:39 AM   #93
dayriesw
dayriesw's Avatar
1987 MJ Comanche
If you can attend...
http://www.louisianaoffroad.com/thre...land-la.43242/
Sold:
85 CJ-7 Renegade
Unread 04-23-2013, 12:45 PM   #94
monsonman
monsonman's Avatar
i wont be able to. buddy's wedding that weekend, sigh
Unread 04-23-2013, 07:34 PM   #95
G Beasley
Wheeling or a wedding ? Tough call ...
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 04-24-2013, 08:41 AM   #96
monsonman
monsonman's Avatar
very tough indeed.
Unread 04-30-2013, 07:06 AM   #97
monsonman
monsonman's Avatar
Got work on the jeep a little bit yesterday. I had one of those pesky "surprise issues" last week after buttoning everything up on the anti rock. The jeep jumped to 2000 rpms at start up and stayed there. I had been planning on cleaning the throttle body and IAC anyways so I figured now was a good time. So I followed this write up and got it done.
http://www.jeepforum.com/forum/f9/cl...mmies-1114849/
I was actually very surprised at how clean the IAC module was inside, it had almost no gunk in there. So I cleaned everything best I could anyways.
One thing interesting was that the breather hose from the throttle body to the MAP sensor had a split up the middle. Can anyone shed some light as to whether this could have been the culprit?
I sealed up the tear and put everything back together and cranked her up. After a few cycles of startup up it seems to have come back down to a nice idle around 800-900 rpms. I test drove and everything seems to check out however I think it needs a little more run time before I'm convinced its "case closed" and not another vacuum leak somewhere else
Unread 04-30-2013, 09:14 AM   #98
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Mine idles at what seems to be on the gauge 600-700 rpms (but this is from memory).
Sold:
85 CJ-7 Renegade
Unread 04-30-2013, 09:32 AM   #99
monsonman
monsonman's Avatar
well there happened to be a spare chilli pepper tj laying around the shop so i hopped in it and checked and bryn's seems to run steady at right under 1k
when i slow down to stop it drops to 500 which seemed pretty low but would eventually rise
Unread 04-30-2013, 10:00 AM   #100
dayriesw
dayriesw's Avatar
1987 MJ Comanche
It's nice to have a spare TJ floating around in running order. I need to get that mod.
Sold:
85 CJ-7 Renegade
Unread 04-30-2013, 10:26 AM   #101
monsonman
monsonman's Avatar
too bad its only a one way mod. sorry Bryn!! ha!!
Unread 04-30-2013, 10:32 AM   #102
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I figured I would pick up one in a year or so and DD it till I could rat rod it... You could always sell your "extra" TJ for parts. It has nice fenders.
Sold:
85 CJ-7 Renegade
Unread 05-01-2013, 02:46 PM   #103
bmosing
bmosing's Avatar
hey.....what's going on in here??
bmosing is offline   Reply With Quote Quick reply to this message
Unread 05-02-2013, 08:59 AM   #104
monsonman
monsonman's Avatar
nothing
Unread 05-02-2013, 09:05 AM   #105
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Sorry, I forgot to mention I'll take the tire and wheels if you part it out.
Sold:
85 CJ-7 Renegade
