Monsonman's '98 Cajun Crawfish Build - Page 2 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Monsonman's '98 Cajun Crawfish Build
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 03-18-2013, 09:55 AM   #16
monsonman
Originally Posted by dayriesw View Post
About time....
What did you do with hat g2 rear dif cover?
it sold on here in about 30 minutes. a guy on here was about 5 minutes from work so we met up and he took it.
My ARB compressor arrived over the weekend so i will be getting started on my switch panel.
i will be shooting for something similar to this
i thought about putting it above my head but i got a new cb last week and i just didnt have the room to do what i wanted to do.
monsonman is offline   Reply With Quote Quick reply to this message
Unread 03-19-2013, 07:59 AM   #17
monsonman
also last week i ordered currie's ultimate steering kit. gerald is hoping the tie rods will be in this week so they can ship out soon!
Unread 03-19-2013, 09:12 AM   #18
dayriesw
dayriesw's Avatar
Sweet. I want to see that and compare it to mine.
Jeep LJ on 37s : Build - http://www.jeepforum.com/forum/f22/i.../index125.html
Jeep Comanche: Build coming soon.
dayriesw is offline   Reply With Quote Quick reply to this message
Unread 03-19-2013, 10:18 AM   #19
monsonman
anyone have any ideas on how i could fasten the sheet metal to the inside of the dash cover?
Unread 03-19-2013, 10:33 AM   #20
dayriesw
dayriesw's Avatar
If I remember correctly, my lower switch panel is factory installed with 4 screws on the corners. Could you bend up the sheet metal to fit that "bolt pattern" and screw it in (don't know if the early tjs were the same)?
Unread 03-19-2013, 12:06 PM   #21
monsonman
i was wanting to semi-permanantly build the switch panel into the dash bezel so that wouldnt work. but it seems like it may take a lot more work to get it like i want so i may just epoxy it to the dash bezel and if i ever need to change it i will just have to replace the whole dash bezel.
Unread 03-21-2013, 07:52 PM   #22
LA-Sahara
Did you already cut out the ashtray spot? Could have screwed it to that. That's how my switch plate is, but its only half the size. (Takes place of the ashtray)
LA-Sahara is offline   Reply With Quote Quick reply to this message
Unread 03-21-2013, 09:07 PM   #23
monsonman
yeah i cut it out. i needed the space for my switches. i figured out what im going to do though and should be done with it this weekend.
stay tuned!
i may not get a whole lot done tomorrow because John Daly is in town playing the web.com tour this weekend
Unread 03-22-2013, 09:55 AM   #24
dayriesw
dayriesw's Avatar
The front axle looks good. Is the jeep ready to wheel?
Unread 03-22-2013, 11:40 AM   #25
monsonman
getting there. i got my arb compressor in the mail, hence im working out my switch panel. also, i should be receive some steering beef from savvy here in the next week or so *crosses fingers*
after that i will be ready to go i think. i'll be needing some new tires too but by the time i have a free weekend to wheel i will probably have some. im thinking creepy crawlers 35x12.5x15
oh and i hooked up my passenger side parking brake cable last night. the other one (brand new) busted after i engaged it
talk about a pain in the *** job that it.
Unread 03-22-2013, 11:15 PM   #26
dayriesw
dayriesw's Avatar
Ha. Sounds like I might beat you to driving mine again before you with yours.
Unread 03-25-2013, 07:21 AM   #27
monsonman
mines drivable, i think
Unread 03-25-2013, 07:24 AM   #28
dayriesw
dayriesw's Avatar
Mine is not even close
Unread 03-25-2013, 09:02 AM   #29
monsonman
so what are you driving while your jeep is in pieces?
Unread 03-25-2013, 09:26 AM   #30
dayriesw
dayriesw's Avatar
2010 nissan altima, ~2005 mountain bike and running shoes.
