Monsonman's '98 Cajun Crawfish Build - Page 7 - JeepForum.com
post #91 of 394 Old 04-23-2013, 07:11 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Looks good. I bet you won't have a problem out of that linkage again.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #92 of 394 Old 04-23-2013, 09:35 AM Thread Starter
monsonman
monsonman's Avatar
i better not
'05 LJ Rubicon Build:
'98 TJ- build:
instagram: @vohnsonthemonson
monsonman is offline
post #93 of 394 Old 04-23-2013, 09:39 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
If you can attend...
http://www.louisianaoffroad.com/thre...land-la.43242/
16 Taco
dayriesw is offline
post #94 of 394 Old 04-23-2013, 11:45 AM Thread Starter
monsonman
monsonman's Avatar
i wont be able to. buddy's wedding that weekend, sigh
'98 TJ- build:
post #95 of 394 Old 04-23-2013, 06:34 PM
G Beasley
Wheeling or a wedding ? Tough call ...
G Beasley is offline
post #96 of 394 Old 04-24-2013, 07:41 AM Thread Starter
monsonman
monsonman's Avatar
very tough indeed.
'98 TJ- build:
post #97 of 394 Old 04-30-2013, 06:06 AM Thread Starter
monsonman
monsonman's Avatar
Got work on the jeep a little bit yesterday. I had one of those pesky "surprise issues" last week after buttoning everything up on the anti rock. The jeep jumped to 2000 rpms at start up and stayed there. I had been planning on cleaning the throttle body and IAC anyways so I figured now was a good time. So I followed this write up and got it done.
http://www.jeepforum.com/forum/f9/cl...mmies-1114849/
I was actually very surprised at how clean the IAC module was inside, it had almost no gunk in there. So I cleaned everything best I could anyways.
One thing interesting was that the breather hose from the throttle body to the MAP sensor had a split up the middle. Can anyone shed some light as to whether this could have been the culprit?
I sealed up the tear and put everything back together and cranked her up. After a few cycles of startup up it seems to have come back down to a nice idle around 800-900 rpms. I test drove and everything seems to check out however I think it needs a little more run time before I'm convinced its "case closed" and not another vacuum leak somewhere else
'98 TJ- build:
post #98 of 394 Old 04-30-2013, 08:14 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Mine idles at what seems to be on the gauge 600-700 rpms (but this is from memory).
16 Taco
dayriesw is offline
post #99 of 394 Old 04-30-2013, 08:32 AM Thread Starter
monsonman
monsonman's Avatar
well there happened to be a spare chilli pepper tj laying around the shop so i hopped in it and checked and bryn's seems to run steady at right under 1k
when i slow down to stop it drops to 500 which seemed pretty low but would eventually rise
'98 TJ- build:
post #100 of 394 Old 04-30-2013, 09:00 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
It's nice to have a spare TJ floating around in running order. I need to get that mod.
16 Taco
dayriesw is offline
post #101 of 394 Old 04-30-2013, 09:26 AM Thread Starter
monsonman
monsonman's Avatar
too bad its only a one way mod. sorry Bryn!! ha!!
'98 TJ- build:
post #102 of 394 Old 04-30-2013, 09:32 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I figured I would pick up one in a year or so and DD it till I could rat rod it... You could always sell your "extra" TJ for parts. It has nice fenders.
16 Taco
dayriesw is offline
post #103 of 394 Old 05-01-2013, 01:46 PM
bmosing
bmosing's Avatar
hey.....what's going on in here??
My Jeep:
bmosing is offline
post #104 of 394 Old 05-02-2013, 07:59 AM Thread Starter
monsonman
monsonman's Avatar
nothing
'98 TJ- build:
post #105 of 394 Old 05-02-2013, 08:05 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Sorry, I forgot to mention I'll take the tire and wheels if you part it out.
16 Taco
dayriesw is offline
