Monsonman's '98 Cajun Crawfish Build - Page 2 - JeepForum.com
post #16 of 394 Old 03-18-2013, 09:55 AM Thread Starter
monsonman
monsonman's Avatar
Originally Posted by dayriesw View Post
About time....
What did you do with hat g2 rear dif cover?
it sold on here in about 30 minutes. a guy on here was about 5 minutes from work so we met up and he took it.
My ARB compressor arrived over the weekend so i will be getting started on my switch panel.
i will be shooting for something similar to this
i thought about putting it above my head but i got a new cb last week and i just didnt have the room to do what i wanted to do.
'05 LJ Rubicon Build:
'98 TJ- build:
instagram: @vohnsonthemonson
monsonman is offline
post #17 of 394 Old 03-19-2013, 07:59 AM Thread Starter
monsonman
monsonman's Avatar
also last week i ordered currie's ultimate steering kit. gerald is hoping the tie rods will be in this week so they can ship out soon!
'98 TJ- build:
post #18 of 394 Old 03-19-2013, 09:12 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Sweet. I want to see that and compare it to mine.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #19 of 394 Old 03-19-2013, 10:18 AM Thread Starter
monsonman
monsonman's Avatar
anyone have any ideas on how i could fasten the sheet metal to the inside of the dash cover?
'98 TJ- build:
post #20 of 394 Old 03-19-2013, 10:33 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
If I remember correctly, my lower switch panel is factory installed with 4 screws on the corners. Could you bend up the sheet metal to fit that "bolt pattern" and screw it in (don't know if the early tjs were the same)?
16 Taco
dayriesw is offline
post #21 of 394 Old 03-19-2013, 12:06 PM Thread Starter
monsonman
monsonman's Avatar
i was wanting to semi-permanantly build the switch panel into the dash bezel so that wouldnt work. but it seems like it may take a lot more work to get it like i want so i may just epoxy it to the dash bezel and if i ever need to change it i will just have to replace the whole dash bezel.
'98 TJ- build:
post #22 of 394 Old 03-21-2013, 07:52 PM
LA-Sahara
Did you already cut out the ashtray spot? Could have screwed it to that. That's how my switch plate is, but its only half the size. (Takes place of the ashtray)
LA-Sahara is offline
post #23 of 394 Old 03-21-2013, 09:07 PM Thread Starter
monsonman
monsonman's Avatar
yeah i cut it out. i needed the space for my switches. i figured out what im going to do though and should be done with it this weekend.
stay tuned!
i may not get a whole lot done tomorrow because John Daly is in town playing the web.com tour this weekend
'98 TJ- build:
post #24 of 394 Old 03-22-2013, 09:55 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
The front axle looks good. Is the jeep ready to wheel?
16 Taco
dayriesw is offline
post #25 of 394 Old 03-22-2013, 11:40 AM Thread Starter
monsonman
monsonman's Avatar
getting there. i got my arb compressor in the mail, hence im working out my switch panel. also, i should be receive some steering beef from savvy here in the next week or so *crosses fingers*
after that i will be ready to go i think. i'll be needing some new tires too but by the time i have a free weekend to wheel i will probably have some. im thinking creepy crawlers 35x12.5x15
oh and i hooked up my passenger side parking brake cable last night. the other one (brand new) busted after i engaged it
talk about a pain in the *** job that it.
'98 TJ- build:
post #26 of 394 Old 03-22-2013, 11:15 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Ha. Sounds like I might beat you to driving mine again before you with yours.
16 Taco
dayriesw is offline
post #27 of 394 Old 03-25-2013, 07:21 AM Thread Starter
monsonman
monsonman's Avatar
mines drivable, i think
'98 TJ- build:
post #28 of 394 Old 03-25-2013, 07:24 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Mine is not even close
16 Taco
dayriesw is offline
post #29 of 394 Old 03-25-2013, 09:02 AM Thread Starter
monsonman
monsonman's Avatar
so what are you driving while your jeep is in pieces?
'98 TJ- build:
post #30 of 394 Old 03-25-2013, 09:26 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
2010 nissan altima, ~2005 mountain bike and running shoes.
16 Taco
dayriesw is offline
