Monsonman's '98 Cajun Crawfish Build - JeepForum.com
post #1 of 394 Old 01-10-2013, 08:26 PM Thread Starter
monsonman
monsonman's Avatar
ok i guess it time to start a build thread. my name is Vohn and im from Lafayette, La. ive had a couple of CJs but eventually made my way to a 98 TJ a few months back by trading a 1 ton CJ5 i had. the jeep was mostly stock when i got it with a some kind of 4-5" franken lift using disgusting drop brackets .
here is what it looked like when i got it, im sure some of you will laugh because as some of you know, my twin brother (bmosing) also has a chili pepper red TJ.
Unfortunately, the PO removed the "Hillbilly" sticker before i got it!
i really hated the huge flares so after it being at my shop for 15 minutes i cut them.
So a couple of months after acquiring the TJ, i threw an aussie in the front and some 33" km2s my brother had lying round and went wheeling.
i found some weaknesses pretty quickly...my passenger side lower CA as it turns out had worn out the threads connecting the 2 halves and after one good bump it slipped right out which led to noodling my driver side upper
also, my power steering pump was destroyed so the first thing i did when i got back home was order a high performance pump from PSC and some new upper control arms. im going to use some non adjustable lower CA's my brother had lying around for now. as you can see its nice having 2 TJs in the family
'05 LJ Rubicon Build:
'98 TJ- build:
instagram: @vohnsonthemonson
monsonman is offline
post #2 of 394 Old 01-10-2013, 08:33 PM Thread Starter
monsonman
monsonman's Avatar
so after getting the new pump in and adding a cooler, i filled up the PS reservoir and the next day found all the fluid dumped out on the shop floor. found it was leaking out the back of the steering box. i figured that either the steering box is what ruined the pump or vise versa so i decided the box had to go too. and knowing that i eventually want hydro assist i got back on the phone with PSC and got the extreme steering box.
'98 TJ- build:
post #3 of 394 Old 01-10-2013, 08:40 PM Thread Starter
monsonman
monsonman's Avatar
next step was to address the ticking time bomb known as my rear axle.
G2 built 44 rear w/ 4.88s, arb, and disc brakes.
during the swap, i hacked off the drop brackets and went back to the factory locations with new uppers and lowers from IRO.
i found a LP30 front locally that has 4.88 gears and a spartan that im going to run for now until i can figure out what my final front axle solution will be.
that puts us to about where i currently am. ive got the old 30 out and have the passenger side brackets cut off (do you have any idea how much i hate those drop brackets?!)
'98 TJ- build:
post #4 of 394 Old 01-10-2013, 09:05 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
About time you put a thread together.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #5 of 394 Old 01-10-2013, 09:25 PM Thread Starter
monsonman
monsonman's Avatar
i know i know. figured you drop in to harass me about it!!
'98 TJ- build:
post #6 of 394 Old 01-14-2013, 02:24 PM
bmosing
bmosing's Avatar
Let's finish up that front end, eh?
My Jeep:
bmosing is offline
post #7 of 394 Old 01-23-2013, 02:13 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
So what is wrong with this sick puppy that your bro was referring to?
16 Taco
dayriesw is offline
post #8 of 394 Old 01-23-2013, 03:38 PM Thread Starter
monsonman
monsonman's Avatar
we went to install the front axle last night and the control arms were too wide for the factory brackets. if you remember it had those ghey drop brackets and im thinking they pinched the factory ones
Did i mention I HATE those drop brackets? they are off the jeep and they are still rustling my jimmies.
'98 TJ- build:
post #9 of 394 Old 01-23-2013, 03:54 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
This is the 30 from Ron right? I don't know if I ever saw it, just it's replacement.
16 Taco
dayriesw is offline
post #10 of 394 Old 01-23-2013, 04:13 PM Thread Starter
monsonman
monsonman's Avatar
yeah but im talking about the brackets on the frame. i ordered a set of IRO adjustables because they are less wide than the others by about a 1/2". should do the trick
'98 TJ- build:
post #11 of 394 Old 03-04-2013, 08:51 PM Thread Starter
monsonman
monsonman's Avatar
alright, so after quite some time away from the jeep, i finally found the time last weekend to get the front axle in.
i still have a few bugs to work out, death wobble being one of them
im going to start with alignment and check the steering stabilizer.
also i was trying to get a hold of gerald at savvy today. i was inquiring on the when-abouts that the ultimate steering kit will be back in stock. he said 2-3 weeks so i guess i will wait it out unless someone can convince me that the difference between the ultimate and the currectlync is not enough to wait it out.
'98 TJ- build:
post #12 of 394 Old 03-05-2013, 08:27 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Start with a dry steering test for the death wobble. It was rarely steered me wrong... sorry for the pun. I run the correctlync with not problems at all. I have no clue about the other.
16 Taco
dayriesw is offline
post #13 of 394 Old 03-05-2013, 02:49 PM
speedracer1305
Have you looked into ruff stuff's steering? Great setup and great price.
speedracer1305 is offline
post #14 of 394 Old 03-06-2013, 09:40 AM Thread Starter
monsonman
monsonman's Avatar
thanks for the tip i went back through all the control arms and noticed the passenger upper bolt was quite loose. after an alignment, no more death wobble .
heres a picture showing its first time being back at home since last august after the wheeling trip.
although i have considered it (i do like the price), i want to stick with currie. its what everyone i ride with is running with no issues and i have no problem following the crowd on a proven system. ive heard mixed reviews on ruffstuffs inverted "T" as well
'98 TJ- build:
post #15 of 394 Old 03-06-2013, 10:29 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
About time....
What did you do with hat g2 rear dif cover?
16 Taco
dayriesw is offline
