The Moaning Brunette build - Page 2 - JeepForum.com
post #16 of 329 Old 10-26-2010, 03:05 PM
99XJBeast
Just lift is 4.5inches with full packs, get some 33s off CL, and be happy.
99XJBeast is offline
post #17 of 329 Old 10-26-2010, 05:25 PM Thread Starter
jeepkid03
Winning
jeepkid03's Avatar
If only I had money for everything that you need for a 4.5". Plus I have the dirty-five.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #18 of 329 Old 10-26-2010, 06:09 PM
Strokin87
I thought they stopped using the D35 in 1996?
1996 F250 - 7.3L Powerstroke turbo diesel, TS 6 Position Chip, 3" downpipe to 4" straightpipe with 5" tip
1999 Jeep Cherokee Classic - 6.5" Rock Krawler long arm lift, sye and shaft, 33" Baja Claws(soon to be 35" STTs), JCR Stage 3 front bumper, steel rear bumper with swing out tire carrier and Hi-Lift jack, rocker guards, Cobra CB, KC Daylighters. SOLD
Build Thread:
2000 Jeep Cherokee Sport - 3" Rough Country full suspension lift, 31x10.50x15 Cooper Discoverer STTs. SOLD :(
Strokin87 is offline
post #19 of 329 Old 10-26-2010, 09:26 PM Thread Starter
jeepkid03
Winning
jeepkid03's Avatar
Nope, I wish though haha. The Cherokees with ABS still needed the Dana 35. The Dana 35 was made till the end of the production run. The only change I am aware of axle wise in 1996 was the changeover from 27 splines to 29 splines in the 8.25 axle.
-Josh
Build Thread:
post #20 of 329 Old 10-26-2010, 09:38 PM
Strokin87
Hmm, I didn't know that. Fortunately for me I have a 29 spline 8.25.
Build Thread:
post #21 of 329 Old 10-26-2010, 09:43 PM
Mike89db
Hey another CT jeeper! Only an hour away too. You've got a very clean looking cherokee. And it sounds great!
Im was in your same position not too long ago. I just bought a 99' limited about a month ago. I
1999 cherokee limited
IRO 3" lift (full 3.5" leafs/ 1" shackles), 3/4" and 1" coil spacers (stacked), RC control arm drop brackets Bilstein 5100's, AA SYE, Tom Woods driveshaft 32" KM2's.
Mike89db is offline
post #22 of 329 Old 10-26-2010, 09:47 PM
Mike89db
Forget the "I" above^^^. That wasnt supposed to be there.
On a side not, I couldnt decide which lift I wanted to go with either. I ended gettin the 3" RC AAL (boo) and 1" shackles.
Mike89db is offline
post #23 of 329 Old 10-27-2010, 02:53 PM Thread Starter
jeepkid03
Winning
jeepkid03's Avatar
Lucky... haha
Thanks! and if you are ever up in my neck of the woods let me know! Since this jeep is so clean, and has the D35, I don't really plan on doing anything crazy with it. I primarily use it for commuting to college, and sadly it sees 90% pavement. I'm giving it a 2" lift for a little more aggressive stance and more clearence for snow. Once I graduate college, I plan on getting an older XJ as a project and making it a dedicated wheeling rig while this one remains a DD.
-Josh
Build Thread:
post #24 of 329 Old 10-27-2010, 04:34 PM
cherokeej
They had the 29 splines but, have way through production they ran out of the 29's and started putting in 27's
Hang on, I want to try something
Build Thread: http://www.jeepforum.com/forum/f22/blue-genie-1110176/
cherokeej is offline
post #25 of 329 Old 10-27-2010, 05:01 PM
Mike89db
That's a good plan. I should have done that myself, but I was impatient. I've got the Dana peice of s**t too.
I'll let ya know if I'm around
Mike89db is offline
post #26 of 329 Old 10-27-2010, 05:50 PM Thread Starter
jeepkid03
Winning
jeepkid03's Avatar
I'm also going 2" because I figure I have less of a chance of needing a T-case drop, SYE, or new trackbar. 3" lifts don't ALWAYS need a new trackbar or SYE but anything is possible it seems with a 97+ XJ. Plus my 30" tires are almost brand new. If I go 2" and everything is fine, I can always add a 1" shackle and buy some cheap $99 rustys 3" coils when my current tires wear out.
-Josh
Build Thread:
post #27 of 329 Old 10-27-2010, 10:10 PM
Mike89db
I know what your saying. I had some vibrations myself after installing my lift. Up to around 30mph. Also there was this horrible grinding noise once in a while. Like nails on a chalk board type of feeling. I got some thick 1 inch tubing, cut it to 6" each and got some longer bolts/studs for a t-case drop. It took care of the vibes/grinding, but it is by no means permanent.
And you're right. Anything is possible on an xj.
Mike89db is offline
post #28 of 329 Old 10-27-2010, 11:01 PM Thread Starter
jeepkid03
Winning
jeepkid03's Avatar
^^definitely.
Just ordered:
-2" OME medium duty leaf packs (said to give about 2.25" of lift)
-leaf spring bushing kit
-D35 u-bolt kit
This is to go along with the 2" IRO coil spacers I have.
I'm also going to be purchasing Rough Country 2-3" lift shocks.
My summer plans are:
-add 1" rear shackle to OME 2" packs
-rusty's 3" front coils
-front swaybar discos
-new lower control arms
-245/75/r16 Definity Dakota M/Ts or 245/75r16 Goodyear Duratracs once my 30's wear out
This is where the build gets good. Like when you come home and your GF is sitting on the couch wearing nothing but bacon.
-Josh
Build Thread:
post #29 of 329 Old 10-28-2010, 11:32 AM
Spokes
man i wish my jeep sounded like that!!! i have a FM40 with stock tailpipe and cat and it is just a little louder than stock... might need to fix that lol
i cnt wait to c your jeep lifted, will look good!
Red 00 XJ lifted
Build -->
Blue 00 XJ Hella stock
"Lima bean" 91 XJ 5spd
Spokes is offline
post #30 of 329 Old 10-28-2010, 02:13 PM
2000BB6
LUCKY!!! i wanted an OME lift!
congrats on it
2000 XJ
2000BB6 is offline
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
2000 TJ Build - LCG First Time Build japete01 Jeep Builds 82 06-07-2012 10:50 PM
My YJ build x513x Jeep Builds 3 12-20-2011 08:38 PM
92 YJ Build up Barrio Jeep Builds 1 07-25-2008 07:38 PM
