Moabrubi's Rubicon - Page 7 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Moabrubi's Rubicon
Save up to 10% Off on Rugged Ridge Exterior Accessories - Heavy Duty JK hinge kits ARE HERE !!!Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 04-16-2013, 09:26 PM   #91
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Originally Posted by Moabrubi View Post
I'll do a detailed write up on how I do it and how it works. The only other write up I've seen is Stu's.
I don't like Stu's method at all. It may have worked well, but looks very awkward, and with my Cloaks would look even worse.
My Build Thread
gst95dsm is offline   Reply With Quote Quick reply to this message
Unread 04-16-2013, 10:05 PM   #92
Moabrubi
Its difficult to find any other way. I'm also looking at the inboard frame space right above the passenger upper axle bracket on the opposite side of the spring. There is some space in there and would definetly provide a cleaner look. I havent put the winch up there to see how it would fit yet though.
Right now im leaning toward the Stu method of mounting it on the coil bucket for ease of install, but im always open to suggestions.
Moabrubi is offline   Reply With Quote Quick reply to this message
Unread 04-16-2013, 10:14 PM   #93
gst95dsm
gst95dsm's Avatar
I'll have to start getting serious about this and do the research. I have no idea really how to accomplish this.
My Build Thread
Unread 04-17-2013, 12:37 AM   #94
aw12345
aw12345's Avatar
My bud Curtis runs it of his main winch with a short piece of winch line, is actually pretty slick and easy to disconnect from the main winch line
aw12345 is offline   Reply With Quote Quick reply to this message
Unread 04-17-2013, 12:40 AM   #95
aw12345
aw12345's Avatar
Stu's method works and especially with a 6 cyl it's pretty hard to do it any other way. With a 4 banger there is a lil more room to play with. With coilovers a center strap suffices as far as I am concerned. One of my friends had a Jeep with coil springs that was setup that way seemed to work ok but after a few weeks of owning it he lost the coil springs so it's hard to say how well it worked that way. It worth a try center strap with about 2" slack isn't that hard to rig up
Unread 04-17-2013, 05:57 AM   #96
tytec95
looks great
tytec95 is offline   Reply With Quote Quick reply to this message
Unread 04-17-2013, 05:58 AM   #97
tytec95
great work
Unread 04-17-2013, 05:30 PM   #98
Moabrubi
Since Superior is out of business, Ten Factory chromos are flying off the shelf. I got the last set of front chromos for a Rubicon from the guys at Rubicon Tested. They are a great company! Picking up the rears soon.
Sent from AutoGuide.com Free App
Unread 04-17-2013, 06:10 PM   #99
G Beasley
Jeep-Owner.com
G Beasley's Avatar
I hate reading that , and not just because I have Superiors . Hopefully the Ten Factory's will treat you well .
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 04-17-2013, 07:42 PM   #100
Moabrubi
That sucks about your warranty. I would have preferred Superior EVOs but I have full confidence in the Ten Factory stuff. Heck, they are made in the same factory that the Superior Discoverys were according to the owner.
Unread 04-17-2013, 10:11 PM   #101
Moabrubi
Originally Posted by tytec95 View Post
great work
Thanks .
So the Jeeps sitting on it's own weight again finally. I now await my Modular Under Armor to be in stock before I can really do anything else. All I need to do is install under armor, order driveshaft, adjust pinion, center axle in wheelwell, and get new exhaust routed and I will be wheeling again.
Under armor should be in stock Friday, if not I may put my new axleshafts in and tinker with the suckdown winch.
Some pics of the new springs, blingy shocks, and blingy bumpstops.
New ride height. The tires are REALLY SMALL!
Molly approves of the new suspension and half doors.
Some quick numbers off the top of my head. This is Currie 4" springs, 1.25" BL, and worn out 32" tires.
Gas tank skid: 19"
Bottom of rocker: 26"
Stock belly pan: 17"
So with the TT and 35" tires I should be sitting around 19-20" of belly clearance after it all settles .
Unread 04-17-2013, 11:24 PM   #102
gst95dsm
gst95dsm's Avatar
Well with your little bit of down time waiting for UA, move those coil buckets! Looking good man!
My Build Thread
Unread 04-17-2013, 11:57 PM   #103
Moabrubi
That's a future mod! I'm going to do the Rokmen coil/bumpstop correct and outboard the shocks later down the road.
Unread 04-18-2013, 12:06 AM   #104
_KONG_
Craigslist SCORE!
Matching half doors, uppers, mirrors, and with keys all in immaculate shape for $300 Now I need to get the mirrors Line-Xed!
Lucky! I'll give you $301 for them. Nice jeep by the way. Im partial to red though
_KONG_ is offline   Reply With Quote Quick reply to this message
Unread 04-18-2013, 12:17 AM   #105
Moabrubi
Ha I know! I always wanted half doors. This Jeep now has 3 tops and 2 sets of doors . I found the ad literally 30 minutes after it was posted and snatched them up.
Thanks, I can't wait to do some summer runs up in Big Bear!
