Moabrubi's Rubicon - Page 22 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Moabrubi's Rubicon
Unread 07-26-2013, 10:26 PM   #316
IEcrawlerTJ01
Nice. I have a slightly used one I have posted for salefor 700. You got a smokin deal
[CENTER]SAVVY,CURRIE,GOODYEAR
Nuff said...[/CENTER]
IEcrawlerTJ01 is offline   Reply With Quote Quick reply to this message
Unread 07-26-2013, 10:38 PM   #317
Moabrubi
Funny thing is I find all this crap not even looking for it. I've been browsing CL looking for an old beat up Willys or CJ to restore to factory condition and come across all this stuff for real good deals.
Should be sweet on the LJ. Tested it out and it works really good, not as fast as my 9.5TI but it will do the job great.
Moabrubi is online now   Reply With Quote Quick reply to this message
Unread 07-27-2013, 08:35 AM   #318
AngryTJ
Originally Posted by Moabrubi
$600 brand new. Craigist baby! My pops got it for his LJ.
Nice find. I got my 9.5ti off eBay with a broken clutch lever for $400! It doesn't free spool but I just use the controller to pull line until I fix it
[SIZE="5"][COLOR="Blue"]Follow me on Instagram @ Tarantula_TJ[/COLOR][/SIZE]
[URL="http://www.jeepforum.com/forum/f22/angrytjs-97tj-05-rubicon-build-1271051//"][SIZE="4"][B]
Tarantula_TJ Build[/B][/SIZE][/URL]
AngryTJ is offline   Reply With Quote Quick reply to this message
Unread 07-27-2013, 09:40 AM   #319
Moabrubi
Nice, when I got my 9.5ti the seals failed and it rusted crazy bad on the inside. Motor worked but everything else needed to be rebuilt. Thats why I cover it now.
Unread 07-27-2013, 09:55 AM   #320
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Its all about that smitty!.... warn...psshhhh
My Build Thread
gst95dsm is offline   Reply With Quote Quick reply to this message
Unread 07-27-2013, 10:09 AM   #321
B52dude
Beautiful TJ, man! Very inspiring.
[QUOTE=Ripper3494;10936705]i think we should chase him around with yjs, its like being chased by zombies, slow, crippled but for some reason still scary as heck lol[/QUOTE]
Red Jeep Club #614
B52dude is offline   Reply With Quote Quick reply to this message
Unread 07-27-2013, 02:49 PM   #322
Moabrubi
Well for those of us without D35s we need the durability of Warn winches to yank ourselves out all the time. Now that you got that 8.8 you better invest in one
Thank you sir!
Here's where we are at on the new sway bar brackets. They are really nice and a piece of cake to install. I bent the swaybar bracket on the drivers side 2 years ago so that one took a little longer to get lined up correctly since you use the original brackets to clamp the new ones to.
2 years ago oopsie.
Lytle_Creek_Dec_2010_Sway_Carnage by Moabrubi, on Flickr
I just cut the factory sway bar bracket a tad as seen in the photos. I may go back and cut them all the way but it seems like they will be a PITA to remove cleanly.
Sb Brackets 1 by Moabrubi, on Flickr
SB Brackets by Moabrubi, on Flickr
Gotta keep those balljoints nice and cool...
SB Brackets 3 by Moabrubi, on Flickr
Sb Brackets 2 by Moabrubi, on Flickr
So now I wait. The tie rod flip insert is supposed to be Monday so I'll have to do that later. Wheeling tomorrow!
Unread 07-27-2013, 03:20 PM   #323
gst95dsm
gst95dsm's Avatar
Nice clean work man!
My Build Thread
Unread 07-31-2013, 09:44 PM   #324
Moabrubi
That'll keep the tie rod out of harms way a lil better.
Unread 08-01-2013, 05:49 AM   #325
AngryTJ
Nice
Unread 08-03-2013, 09:36 PM   #326
Moabrubi
Today I decided it was time to make sure all the bolts were tight. Good thing I did, they needed it! Especially this one!
http://www.youtube.com/watch?v=SYyCU...ature=youtu.be
It had red loctite and I torqued it to spec. This time I added some more loctite and torqued the ever living piss out of it. If it becomes an issue, I will mount it in double shear. Mounting it in double shear is a bit of work but I think it will be worth it. I already know how I'm going to do it if I end up having to.
Time will tell.
Unread 08-03-2013, 09:49 PM   #327
gst95dsm
gst95dsm's Avatar
Seems like a common issue, Stock track bars... FTW. Glad you caught it!
My Build Thread
Unread 08-03-2013, 10:01 PM   #328
Moabrubi
Yup sure does. No way I could run a stocker though.
The way I see it, it gives me an excuse to upgrade the Jeep and spend some garage time.
Unread 08-03-2013, 10:40 PM   #329
aw12345
Is a known issue, I cut the JJ off and used a heim instead in double sheer.
aw12345 is offline   Reply With Quote Quick reply to this message
Unread 08-03-2013, 10:56 PM   #330
Moabrubi
I kinda wanted a double shear trackbar anyway. Never was a fan of single shear. Not a huge fan of heims either, the ones I have experience with squeaked ALOT.
