Moabrubi's Rubicon - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Moabrubi's Rubicon
Poison Spyder JK LED Taillight & Wiring Harness KitsPoison Spyder JK Crusher CornersPANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi
Unread 11-23-2012, 06:30 PM   #1
Moabrubi
Moabrubi's Rubicon Build
Figured I might as well start a build thread before the real building starts. Should be helpful in keeping track of stuff too. I got this jeep 2 years ago and never really took "build" pics so I will just start out with some of the wheeling pics. They might get out of order a bit, I don't have the exact dates written. Unfortunately i forget to take pictures a lot of the time!
How it sits today 5/18/13.
Current specs:
2005 Jeep Wrangler Rubicon 6spd manual
35/12.50/15 MTR/K
15" Trailready Beadlocks
Currie Antirock
Rokmen Mercenary front bumper
Rokmen steering box skid
Rokmen TT
Warn 9.5TI with synthetic line
KC Daylighters 130w
Garvin Wilderness tire carrier
Savvy Ultimate steering
Line-X Fenders and mirrors
Dynatrac front diff cover
Ruffstuff rear diff cover
Midland 75-822 CB
3' firestik
Super ultra custom backup lights
Banks catback
Black Magic brake pads with Centric Premium rotors
Black Magic Delrin door bushings
Comet Tri Band Antenna with Kenwood TH-F6A
Polk DB521 speakers with Nalin MFG dash brackets
Savvy 1.25" Body Lift
Savvy 1" Motor Mount Lift
Novak Shifter
Savvy Step Rock Sliders
Savvy gas tank skid
Powertank 10# with rollbar clamps
Savvy Aluminum Adjustable CA's
Black magic brakes JJ washers
Currie 4" Springs
Fox 2.0 Smoothbodies
Currie TJJ Front Trackbar
Currie rear trackbar with housing bracket
Currie Bumpstops F/R
Goodridge Extended Brakelines
JJ housing kit
Currie mini skids
Daystar 3/8" spring isolators
Currie extended rear sway bar links
Ten Factory front chromoly axleshafts
G2 rear chromoly axleshafts
Warn 2.5CI suckdown winch mounted on coil bucket
Rokmen TT
Tom Woods 1310 CV driveshaft
Black Magic Brakes tie rod flip and raised sway bar brackets
Savvy Corner Armor
Savvy Tub Rails
Moabrubi is online now   Reply With Quote Quick reply to this message
Unread 11-23-2012, 06:48 PM   #2
Moabrubi
Here is the first picture of it on the trails.
downsized_0530000948
The first mod to it was a swing out tire carrier by Garvin Wilderness. I have added the Jerry can carrier for the other side as well as mounts for backup lights, and a CB antenna/mount.
Jeep_Rack
After that I went up to the White Mountains for a few days of wheeling.
IMG_1307
IMG_1303
IMG_1385
IMG_1387
After that trip I decided I need to disconnect my sway bar. I ended up putting on JKS quick disconnects.
Ruby_Flex_JKS_QD_Front
I was out exploring after some good rains and didn't disconnect my swaybar. Well this happened: All of a sudden I got flex!
Lytle_Creek_After_Sway_Bend_
I used heat and a BFH to fix it. I figured since connecting/disconnecting the sway bar was such a pain I would eventually put a new antirock and front bumper that would work with it.
Lytle_Creek_Dec_2010_Sway_Carnage
I line-xed my fenders,sliders,and sliders. It holds up pretty dang well. I also put on some Cooper STT's which rock!
Jeep_LineX_6
Unread 11-23-2012, 07:10 PM   #3
Moabrubi
Poser shot:
IMG_2141
Went up to Joshua Tree NP for some wheeling. Some cool trails up there.
Cliff
Trail_Tight
Cleghorn in the snow:
Cleg_Snow
Devils hole up in Lake Arrowhead,CA
DeepCreek_TJ
Added this to the family somewhere around this time
IMG_3698
So fast forward a lot. I guess I didn't take very many pictures. I changed my front bumper to Rokmen, changed the JKS disconnects for the antirock, changed the warn engine skid to UCF, added lots of other goodies, and went to EJS 2012.
Merc_bumper
Moabpic_1
Moabpic_2
Moabpic_3
Moabpic_4
DSC_4308
DSC_4303
DSC_3944
DSC_4058
DSC_4139
Unread 11-23-2012, 07:15 PM   #4
Moabrubi
Some local wheeling: Holcomb, Dishpan, Gold Mtn. Cleghorn and John Bull
1
DSC_3879
dishpan
Flex
IMG_4954
TJ_Holcomb_Rock_Garden_3
IMG_4769
Alright... here is one of my not so smart moments.
Rock
Ended up putting a good dent in the muffler.
Muffler
Unread 11-23-2012, 07:17 PM   #5
Moabrubi
That's pretty much where the Jeep is today. Now that I have this thread I will actually take pictures of everything I do. I missed a lot of stuff that I have done to it. Updates come very slowly here I plan to have this rig rolling on 35's as reliably as it pushes 32's now.
Unread 11-24-2012, 08:21 AM   #6
midnight_f150
You have a sweet looking Jeep. Some awesome trail pictures I have to start taking pictures of my Jeep out on the trails. How do you like the antirock vs the disconnects? So what are you next mods you have planned for your Jeep?
midnight_f150 is offline   Reply With Quote Quick reply to this message
Unread 11-24-2012, 08:40 AM   #7
Moabrubi
Thanks. I started this build so maybe i would actually remember to take pictures of everything. I have like a 6 month gap where i cant find pictures. As far as antirock vs disconnects the antirock is 1000000x better. As you can see i got a little lazy disconnecting my quick discos which ended up with the bent sway bar link. I love the set it and forget it with the antirock, and it also feels more stable.
Next mods are probably going to be a set of savvy rock sliders and possibly do some roll cage work. I want to wear these tires out before i start lifting it anymore because Im still not 100% sure how I want to go about putting it on 35s suspension wise.
Unread 11-24-2012, 03:24 PM   #8
Moabrubi
Well in the past week some stuff has happened to the Jeep.
Did some easy wheeling at rattlesnake canyon. The plan was to go to Bullfrog but we got sidetracked and ended up taking some other road for 20 miles. Was still lots of fun.
8162914504_72232138cd_b
Also I needed to get new brake pads and rotors. I decided to try out the Black Magics. At first I didn't notice a difference but as i start to drive it more it stops MUCH better. I also replaced the rear with centric rotors and the Posi quiet pads.
BlackMagic Pads
Centric_Premium_Rotor
bmb1
Rear_Brakes_Rotor_1
I also scored a steering box for cheap. Will make for a good spare. I turned the picture but apparently it's still sideways. You can also see in the picture my old door bushings. I replaced those with the delrin ones from black magic and just like the brakes they are magic.
20121124_122927
Unread 11-24-2012, 09:02 PM   #9
G Beasley
Jeep-Owner.com
G Beasley's Avatar
Great wheeling pics . And I agree with you about the Black Magics and Delrin bushings . They are well worth the money .
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 11-25-2012, 04:57 PM   #10
Moabrubi
Thanks, I have many more but they take forever to resize and upload. I love the Black Magic's so much we are going to put them on the Rubihara as it is due for some new pads as well .
Unread 11-25-2012, 04:58 PM   #11
maztj
I starting to like the stocker looking jeeps more. your pics prove you can still do major crawling without 8 inchs of lift. nice jeep!!!
maztj is offline   Reply With Quote Quick reply to this message
Unread 11-25-2012, 06:53 PM   #12
bobthetj03
Great pics, and nice build! The Black Magic pads rock!
Bob's boring build:
http://www.jeepforum.com/forum/f22/b...build-1304260/
White Jeep club member #2003
www.norcal-jeeps.com
bobthetj03 is offline   Reply With Quote Quick reply to this message
Unread 11-26-2012, 07:16 AM   #13
AngryTJ
AngryTJ's Avatar
Do you notice a big difference with the centric rotors? Ive considered getting them all the way around and new pads instead of waiting for a new big brake kit to come out since the time frame is unknown
Tarantula_TJ Build
AngryTJ is offline   Reply With Quote Quick reply to this message
Unread 11-26-2012, 07:32 AM   #14
mj24lyons
Hey, great looking Jeep! What part of SoCal are you from?
mj24lyons is offline   Reply With Quote Quick reply to this message
Unread 11-26-2012, 08:18 AM   #15
Moabrubi
Thanks, I just pick my lines very carefully.
Thanks
Well with the black magic pads it's required to get the centric rotors. I got the centric rotors for the rear just because I figured I might as well since I had the Caliper off anyways. I'm sure that they made a difference, I wouldn't know if just the rotors made a difference because I installed all the pads and rotors at the same time. With 35's though I'm not sure how your results would be, but I can definitely tell you that there is a major improvement in braking. I believe the rear Posi Quiet pads in Blaines front and rear brake package are just stock replacements.
I'm in Rancho Cucamonga, but wheel all over the place!
