Moabrubi's Rubicon - Page 14 - JeepForum.com
post #196 of 825 Old 05-08-2013, 02:43 PM Thread Starter
Moabrubi
what happened to your stock moabs? No offense but I like those better
Sold them. I like them too but they werent worth the cost difference.
I would have needed spacers.Also tires for 16" wheels are way more expensive. IIRC it was $100ish more a tire for a 315/75/16. I actually paid less for these 35s then my old 32" coopers.
Sent from my SCH-I535 using JeepForum
Moabrubi is offline
post #197 of 825 Old 05-08-2013, 03:13 PM
AngryTJ
I hear ya. 16" wheels are way over priced
AngryTJ is offline
post #198 of 825 Old 05-09-2013, 09:48 PM Thread Starter
Moabrubi
Rokmen TT showed up today .
Like all Rokmen products this thing is top notch quality. It only took an hour to install. I'm really happy with this skid and am glad I picked this one.
I had to trim the exhaust hanger. Remember in the LoPro instructions where I had to cut and drill a hole to fit the 2 pieces together? Well it just so happens those dimensions worked absolutely perfect with the Rokmen skid and moved my exhaust away from the passenger UCA mount.
19 1/2" to the belly pan. Not bad.
I highly recommend the Rokmen skid. Sure it's not as flat as some others, but the install was the easiest thing I've done to the Jeep. The skid fit so good that I was able to thread the bolts by hand all the way. All I need to do is paint it and I'm good to go. Engine skid should be shipped in 2-3 weeks. Ordering my TW driveshaft tomorrow too. I have a $100 gift certificate that I won at a rock crawl event last year.
Doing a shakedown run at Gold Mtn. on the 25th. If nothing on the Jeep goes wrong then the plan is to hit John Bull and Holcomb as well. It would be nice to have my engine skid by then to have some peace of mind though.
Moabrubi is offline
post #199 of 825 Old 05-09-2013, 10:02 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
19.5 is nice man, your rig must be sitting pretty high! Is your frame to ground 22?
gst95dsm is offline
post #200 of 825 Old 05-09-2013, 10:32 PM Thread Starter
Moabrubi
Yep. Rokmen skid is 2.5" deep. I expect the rig to settle a little but IMO it's about perfect on 35's right now. I can tell you for a fact that a Jeep with a 5.5" RE lift on 33's sits taller then mine with 4" springs, 1.25"Bl and 35s. Even when it settles a bit, 19" is plenty of ground clearance for what I plan to do with this rig.
Moabrubi is offline
post #201 of 825 Old 05-09-2013, 10:46 PM
gst95dsm
gst95dsm's Avatar
Looks like a nice piece! And yeah 19" is what I would have, completely flat at my lift height! So you're doing good as long as you don't feel it's to high and tippy for where your wheeling and what your doing.
gst95dsm is offline
post #202 of 825 Old 05-09-2013, 10:59 PM Thread Starter
Moabrubi
I don't think it will be. The guys I wheel with regularly are just as tall or taller then me and they never have any issues with being tippy. Taller rigs seem to work better down here, I've talked to a few guys who had the LCG thing going and they ended up throwing some taller springs in. Plus I got the suckdown winch for the steep climbs .
Moabrubi is offline
post #203 of 825 Old 05-09-2013, 11:08 PM
gst95dsm
gst95dsm's Avatar
Right on, I agree dragging your under belly all over everything isn't really cool. I've ruined myself after all this time being this low, whenever I get in a taller rig I get anxious, but most every rig I wheel with is usually taller than me and it never seems to be an issue. Oh and just one more time.... COME TO MOAB!!!!
gst95dsm is offline
post #204 of 825 Old 05-09-2013, 11:31 PM Thread Starter
Moabrubi
Haha I wish! My dog is having puppies soon so only day trips for a while.I really want to run some harder trails next time I go though. If there is a Jeepforum Moab wheelin trip in June 2014 I am in for that one .
Moabrubi is offline
post #205 of 825 Old 05-09-2013, 11:34 PM
aw12345
My yellow one has 19" under the belly. 20.5" under the frame at 3.5" of lift and 35" tires. My other one has 23" under the flat belly with 40" tires
aw12345 is offline
post #206 of 825 Old 05-09-2013, 11:39 PM Thread Starter
Moabrubi
Your running a Teraflex skid on the yellow one right? Or did you build that one?
Moabrubi is offline
post #207 of 825 Old 05-10-2013, 12:33 AM
aw12345
Modified terraflex skid, bought used one for a older TJ years ago for 100 bucks and made it work after I braced it up
aw12345 is offline
post #208 of 825 Old 05-12-2013, 12:29 PM Thread Starter
Moabrubi
Alright guys, more newbie questions here. So I needed to pull my springs to center my tires at full bump. So I pulled the springs and installed my bumpstops and shocks to center the tire in the wheel well. In doing so I found I have some other issues. I really didn't think to check any of this putting it all together. Oh well, live and learn I guess.
So here is the problem. I am going to bottom out the shock before I reach full bump:
Here's how far I am away from full bump.
Here's how close I am to the gas tank with the shock bottoming out where it is.
Here's the tire in the wheelwell. This is with the shock fully collapsed and the bumpstops as you see above.
So I pulled the shocks to get to actual full bump. Diff cover hit the gas tank. However, even if my shocks worked with this setup, wouldn't I get coil bind? The bumpstops seem awful short. I thought this was supposed to work together as a kit. Guess that's what I get for assuming.
Fat diff cover hitting the gas tank at full bump with shocks not installed. I know to fix this I just need to shorten my wheelbase, but the question is can the springs even compress this much without getting coil bind?
Also my control arms are set really long, I probably have over 2" of thread showing between both JJ's on the lowers and quite a bit on the uppers.
Any help would be greatly appreciated. I'm a bit stumped as this is my first time doing anything like this. Do I need longer bumpstops? I don't think longer bumpstops are the answer since you can see how far I am away from stuffing that tire in the wheelwell. Think i need different shocks? Do I need both?
I hate having to ask, but I can't find any real solutions. . At least I got the front dialed in without any issues.
Moabrubi is offline
post #209 of 825 Old 05-12-2013, 12:58 PM
aw12345
Shorter shocks or outboarding them seems to be the answer. On the springs the only way to find out if they will bind is to try and fully compress them by flexing the suspension. Do you have a cherry picker?
Also loosing the shock bracket extenders and trimming the lower spring bucket will help since it will extend the shock a bit more
aw12345 is offline
post #210 of 825 Old 05-12-2013, 01:21 PM Thread Starter
Moabrubi
I'm 2.5" away from touching the bumpstops. So I would need some pretty short shocks and lose quite a bit of downtravel correct? I really don't want to do that, but I didn't want to spend the $ on outboarding either. I guess I got the wrong shocks, although on the box they say TJ 4" lift.
Don't have a cherry picker or any means to flex the suspension with the springs installed.
Moabrubi is offline
