MO2500's '97 TJ Build up - Page 90 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > MO2500's '97 TJ Build up
Warn and Smittybilt Free Shipping OfferNew items recently added to Oconee Offroad15 x 8 Black D-Window Steel Wheels Set of 4
Unread 12-18-2011, 05:22 PM   #1336
TJRHD
Sweet, I am gonna go put my stocker tie rod back on and try to make a cross member out of it!!
Good job..still watching man
Don't look at my work too close or too long..
My thread redo
http://www.jeepforum.com/forum/f22/yes-i-know-im-wrong-side-crazy-thread-redux-1484068/
TJRHD is online now   Reply With Quote
Unread 12-18-2011, 06:19 PM   #1337
MO2500
Fabramicator
MO2500's Avatar
I just noticed the new "Advanced Jeep Tech" section. It's about time, hopefully it can stay clutter free with lots of useful tech
My Jeep Build
Useful tech links:
Stu-Offroad - great technical write-ups!
What's a CV shaft and why do I need one?
Driveline 101
TJ Specs
-Mike-
MO2500 is offline   Reply With Quote
Unread 12-18-2011, 07:23 PM   #1338
KevKaos
Oh yeah, that's what's going to happen.
[SIZE="4"]KevKaos[/SIZE]
[SIZE="4"]Honey Badger Wheelin'[/SIZE]
[FONT="Arial Black"][SIZE="5"][COLOR="Red"]RED JEEP CLUB # 621[/COLOR][/SIZE][/FONT]
It's not much, but check out my build thread;
[url]http://www.jeepforum.com/forum/f22/kevkaoss-05-red-rubicon-build-thread-1170741/[/url]
[QUOTE=krashnpa;12397572] I know kev was riding his tank skid and belly pretty good on some of the blacks up at RC, but he doesn't back down from the line either.[/QUOTE]
[QUOTE=squazz;13612008]so I use my original nuts?[/QUOTE]
You should, in no way, take any of this personally. It's just business. So to recap, I come in peace, I mean you no harm, and you all will die. Gallaxhar out.
KevKaos is offline   Reply With Quote
Unread 12-18-2011, 07:25 PM   #1339
TJRHD
Do you dare me to go start a death wobble thread over there??
Where did you source your bushings for your new crossmember?
My thread redo
Unread 12-18-2011, 09:26 PM   #1340
djflyy
Adventure Is Out There
djflyy's Avatar
Phenomenal idea with the x-member. I'm jealous of how tucked away you made that whole assembly. I've been thinking about building a flat skid instead of a UCF or any of the "high" skids. Figure might as well go flat to the frame rails if at all possible. Looks like you've got a great design going so far, can't wait to see more
Boston Jeep Build Thread
North Shore Jeeps Website
Originally Posted by StuddMuffinz View Post
dj, it amazes me how your jeep can always make me happy in the pants <3
djflyy is online now   Reply With Quote
Unread 12-18-2011, 09:46 PM   #1341
MO2500
Fabramicator
MO2500's Avatar
I bought the bushing halves from Ruffstuff and then made the sleeves from 1.75" x .120" wall DOM.
Bushing halves
I can hope, right
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
Unread 12-19-2011, 05:59 AM   #1342
Imped
Balls
Imped's Avatar
Going flat is EASY with the 231.
How's it drive with the new xmember setup Mike? Should be pretty tight.
OlllllllO
Float Test Build
IndyORV
If you see a dead picture link of mine and would like it fixed, please PM me the link to the post and I'll fix it. Thanks
Imped is offline   Reply With Quote
Unread 12-19-2011, 07:07 AM   #1343
Sgt.Fuzz
Yep, if I knew then what I know now I would have skipped the 1" UHC skid and went completely flat the first time around. As it is now, it's not worth the trouble or money to make the switch.
[COLOR="Blue"]My build: [url]http://www.jeepforum.com/forum/f22/fuzzbucket-build-1126577/[/url][/COLOR]
Sgt.Fuzz is offline   Reply With Quote
Unread 12-19-2011, 07:09 AM   #1344
MO2500
Fabramicator
MO2500's Avatar
I haven't driven it anywhere yet. I still need to relocate the fan shroud because the fan is making contact and I would need to adjust my pinion angle. The straight pipe under the passenger side floor board might also cause issues
I did start it and it actually seemed to idle smoother (less vibes) than it did with only the Brown Dog MML. With the MML only i think it put the motor mounts and trans mount in a bind. Couple that with the 4 cyl which is known to have more vibration and a poly bushing and I had some slight vibrations at idle. Now with the trans lifted up, the motor mounts may not be bound up anymore, and the whole driveline is supported by poly bushings. It was hard to tell though because the exhaust is ******* loud
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
Unread 12-19-2011, 08:06 AM   #1345
JJeeper09
Yeah the 241 not the case
[URL="http://www.jeepforum.com/forum/f22/project-do-right-1147962/"][B]Rubicon Build[/B][/URL]
JJeeper09 is offline   Reply With Quote
Unread 12-19-2011, 08:15 AM   #1346
MO2500
Fabramicator
MO2500's Avatar
I'd have no problems cutting holes in the tub if I could have 4:1 gearing...
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
Unread 12-19-2011, 08:34 AM   #1347
Bennettj13
I'm a big meanie head
Bennettj13's Avatar
Qftmft
::SELLING HALF OF MY JEEP::
http://www.jeepforum.com/forum/f33/?uid=152304
Bennettj13 is offline   Reply With Quote
Unread 12-19-2011, 08:48 AM   #1348
MO2500
Fabramicator
MO2500's Avatar
My tires should be getting to the terminal for pickup today.
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
Unread 12-19-2011, 10:06 AM   #1349
JJeeper09
When I redo the rear I will get it flat
Unread 12-19-2011, 10:21 PM   #1350
MO2500
Fabramicator
MO2500's Avatar
Tires didn't arrive at the terminal today. Apparently they had not moved from the location in PA since yesterday. Now it says they are in route to the destination but still says the estimated delivery date is December 19th
Hopefully I can get them tomorrow...
I didn't get any work done on the skid today. Had other things to do but plan to get up early tomorrow morning and get some more work in.
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
4 link , air bags , coilovers , emc , jeep tj , koh , low rider , mid arm , pimp fabrimication , rock crawler , ultra4
