MO2500's '97 TJ Build up - Page 67 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > MO2500's '97 TJ Build up
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 06-06-2011, 04:26 PM   #991
MO2500
MO2500's Avatar
No worries Brad, I needed another welding project! My welder has been unplugged for a couple months since the cage was finished and junk is beginning to pile up around it. I'm planning a lot more fab work soon though after this end of June wheeling trip.
ODonnell Motorsports
Build Thread
Instagram: @omsmike
MO2500 is online now   Reply With Quote Quick reply to this message
Unread 06-08-2011, 08:09 PM   #992
MO2500
MO2500's Avatar
Freshened up the D30 a little today. Repainted the axle housing and the diff cover. Also straightened up my passenger UCA mount and reinforced it a little as it looked like it was starting to get tweaked slightly.
New U-joints came and I installed those.
Build Thread
Instagram: @omsmike
Unread 06-08-2011, 08:37 PM   #993
JJeeper09
Very nice. i will go ahead and pull the front axle when i pull the back and work on it also and to the same thing with the upper mounts.
[URL="http://www.jeepforum.com/forum/f22/project-do-right-1147962/"][B]Rubicon Build[/B][/URL]
JJeeper09 is offline   Reply With Quote Quick reply to this message
Unread 06-08-2011, 09:25 PM   #994
mikes_muse
For the upper mount on my other jeep's front axle, I welded in a square piece of tubing, like 1.5"x1.5" or whatever fits in the mount nice and tight. Then I did as you have and welded a piece on the front too. I figured there would be no way for it to cave in at all, it had already started to before I decided to beef it up, with the square tube in there to keep it shaped.
mikes_muse is offline   Reply With Quote Quick reply to this message
Unread 06-08-2011, 10:04 PM   #995
MO2500
MO2500's Avatar
Sounds good man. I'v had the axles out from under my jeep so much it almost just seems like routine maintenance . I didn't even need to pull it this time but I didn't feel like drilling and tapping the spring pads under the jeep and it only takes like a half hour with air tools to have the entire axle out.
Yea, that's the same thing that was happening with mine. It had started to partially collapse on the front side. So I spread it back apart and welded that piece of 3/16 in there, should keep it from happening again and give the mount a little more strength.
Build Thread
Instagram: @omsmike
Unread 06-08-2011, 10:26 PM   #996
mikes_muse
Yeah, mine had tacoed in pretty good. I wasn't sure it would bend back right, but it worked like a champ. You should be good to go.
Unread 06-14-2011, 10:10 AM   #997
MO2500
MO2500's Avatar
While I'm waiting for things to finish up the front, I got to work on relocating the rear spring perches and swapping the 4" Fabtech springs for the 2.5" RC coils I have.
RC 2.5" on the left, Fabtech 4" on the right. Like I'v heard, the RC coil is every bit as long as the 4" coil extended.
Removed the coil buckets and cleaned up the frame
Nice good contact with the bump pad
The more I dig into the suspension and modify/replace the Fabtech lift I originally purchased 3 years ago, the more I regret wasting the money on it. When I started working on the coil bucket relocation I came to discover that the shocks that came with the kit are reaching full compression before the bump stops that came with the kit make contact with the bump pad. I'd like to know what they were thinking when they designed the kit
I was actually hoping to remove some bump in the rear because I have tons of room in the wheel well for more stuff but my current shocks are too long. They are 25" extended, 16" collapsed, 9" stroke. For now I'm just going to have to run it as-is since I'm not ordering new shocks till I get the 4 link finished, outboard and figure out what shocks I want for that. I thought about relocating shock mounts or something to get this to work but it's not worth the time since I'll be re-doing the suspension very soon anyway...
With the shocks at full compression, bumps still 1/4-3/8" from even making contact
Still room for more stuff at bump
Whatever, I got both sides done and springs in. This isn't ride height but with some weight on the springs things look good Looking at that exhaust makes me feel like chopping it off before the rocks tear it off...
Build Thread
Instagram: @omsmike
Unread 06-14-2011, 10:17 AM   #998
MO2500
MO2500's Avatar
Hoping to have the jeep back on all 4 tires by sometime tomorrow
Build Thread
Instagram: @omsmike
Unread 06-14-2011, 10:37 AM   #999
B2CARPEN
B2CARPEN's Avatar
Those springs look perrty! You will like RC's progressive 2.5" coils a lot! They are very flexy / long and provide a really smooth ride on and off road fo sho.
The only complaint I had was with the front 2.5" coils not holding true to 2.5" of lift after settling and adding a heavy front bumper. The rears will gain you about 3" of lift and the fronts about 2". I swapped my fronts for RC 4" coils and now my jeep sits perfectly level.
B2CARPEN is offline   Reply With Quote Quick reply to this message
Unread 06-14-2011, 11:45 AM   #1000
MO2500
MO2500's Avatar
I'm hoping for right around 3" in the rear so thats good. I only bought RC coils for the rear. I have 3" BDS coils I'm going to try in the front and see where that puts me.
Build Thread
Instagram: @omsmike
Unread 06-14-2011, 04:29 PM   #1001
JJeeper09
What did you used to move the coils? Grinder, dremel and such? Im doing this while the axle is out this weekend.
Unread 06-14-2011, 05:52 PM   #1002
MO2500
MO2500's Avatar
Yea pretty much. I cut the welds I could reach and then smacked the mount with a BFH to break the remaining welds. Then I modified the coil bucket to get them to fit the way I wanted and welded them right back on
Build Thread
Instagram: @omsmike
Unread 06-14-2011, 05:54 PM   #1003
MO2500
MO2500's Avatar
Just built these beefy things
Build Thread
Instagram: @omsmike
Unread 06-14-2011, 06:01 PM   #1004
kyle_craig
Good work on those control arms!
kyle_craig is offline   Reply With Quote Quick reply to this message
Unread 06-14-2011, 06:11 PM   #1005
JJeeper09
Want to make me a pair?
4 link , air bags , bypass shocks , coilovers , emc , koh , low rider , mid arm , pimp fabrimication , race jeep , ultra4
